Old 07-15-2014, 03:32 PM   #1
Jawnathin
Drives: Toyobaru FRZ
Koni Yellow Rears - Top Hat Drill size
So I did one side of the Koni Yellow rears yesterday. Couldn't finish the other side as it was getting late. Anyway, one of the steps required is drilling the rear top hat. Koni says we should drill a 12mm hole. I don't have a metric set and I read somewhere that a 1/2" would work, so I just went with 1/2" without thinking of trying anything different. 1/2" is 12.7mm, so pretty close, the hole will have a larger radius by .35mm over the Koni shaft.
After reading more about the Konis this morning, I realize a few folks are going with slightly smaller bits, going with 31/64ths (12.3mm) or 15/32nds (11.9mm + some slight grinding/boring). Now I'm questioning whether the 1/2" bit was too large. It didn't really occur to me that the top hat would have any side load from the strut's shaft that would require an exact fit. I figured the hole was there just to get the thicker adjuster through.
Anyway, what I did has been done and there is no turning back on this top hat, but I can certainly buy another if I had to. Need some input on whether this should be a problem or not. Also would like to hear if anyone else has done 1/2" and what their experience has been. Car seems to drive just fine, no weird noises or anything, but want to prevent any future problems.
Thanks.
Jawnathin is offline   Reply With Quote
Old 07-15-2014, 04:06 PM   #2
vroom4
Its fine
vroom4 is offline   Reply With Quote
The Following User Says Thank You to vroom4 For This Useful Post:
Jawnathin (07-15-2014)
Old 07-15-2014, 05:03 PM   #3
Jawnathin
Originally Posted by vroom4 View Post
Its fine
Thanks, appreciate the input.
Old 07-15-2014, 05:11 PM   #4
vroom4
Just don't put the front lower perch on upside down.
Old 07-15-2014, 05:30 PM   #5
Jawnathin
Thanks but I'm not sure what you mean by the front lower perch. Did you mean the circular metal ring that holds the rubber gasket that sits right on top of the spring and under the top hat? The circular thing next to the triangular top hat in this photo?
I installed it the way it came off the OEM strut with the rubber facing downward on the spring. Wider part towards the bottom.
Funny enough, I actually put the rear spring perch in upside down. I'll have to uninstall tonight and flip them over. Explains why I had such a hard time with the spring last night.
Old 07-15-2014, 06:42 PM   #6
vroom4
Oops, I meant rear. Too late lol.
Old 07-15-2014, 08:40 PM   #7
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
I used a 1/2" bit as well, without issues.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 07-15-2014, 10:05 PM   #8
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
31/64" would have been slightly better, but those rubber bushings are going to deflect a hell of a lot more than the 15 thou difference between 31/64" and 1/2". You'll survive.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 07-16-2014, 09:18 AM   #9
JasperNoone
Drives: Car
You mean how it's illustrated in the Koni drawings? (though the front perch is part of the OEM shock-body, so I assume you meant rear)
Top hat on the left, UPPER spring perch on the rear. Rubber should be facing down towards the spring - you've installed the front UPPER perch correctly.
JasperNoone is offline   Reply With Quote
Old 07-16-2014, 12:17 PM   #10
vroom4
"Why is my car 2" higher in the back!?!??!"
It didnt handle very well thats for sure.
Old 07-16-2014, 03:23 PM   #11
Jawnathin
LOL, wish I had known about it prior to the 1st install. Oh well, all is fixed now.
Thanks for your input. I appreciate it.
When I was working on the car yesterday afternoon, looking at the shock and rear suspension, I'm kind of surprised there is would be any lateral load through the shaft. Rear control arm goes up and, not laterally. Shock goes up and down, not laterally. I'm sure there are SOME lateral movements in the entire rear suspension (when braking, accelerating, etc) but with all the pieces leading up to the shock, I'd be surprised if anything meaningful actually made it up the shaft.
For me, having the top hat facing 'up' looked so obvious as most spring perches sit that way on a shock. Didn't even question it until I saw how much higher it looked, then I realized the mistake and explained why I had so much trouble putting the spring on. Oh well, easy fix.
Haha, I was actually only able to finish one side that night. So it did look a little weird. Must admit, through a quick test drive, car seemed to drive fine. Rear was a little stiffer, probably because the spring was compressed more than usual, but overall it did drive OK.
Old 07-16-2014, 03:33 PM   #12
SomeoneWhoIsntMe
That's actually a good point, the shock moving from side to side doesn't have any meaningful effect on the rear suspension.
Old 07-16-2014, 07:14 PM   #13
Jawnathin
Well, the point isn't whether shock movement would or would not be have an effect but rather is the strut shaft getting meaningful force that would cause lateral movement?
Given how the strut sits in structured 'assembly' consisting of bushings, perches, springs, spring pressure, top hats, nuts, mounts, etc and the primary movement going up/down the control arm and strut, I'd just have to wonder how much lateral force actually leads up to the strut's shaft.
And if so, what level of movement generates a meaningful side effect? Given they're two separate pieces, even from the factory there is always going to be some level of 'play' between a top hat and strut.
Anyway, after seeing the responses here and doing a bit more research the 1/2" hole seems to be fine. Car was put together last night and went out for a test drive, felt good, no weird noises!
Old 07-16-2014, 07:15 PM   #14
Jawnathin
Off topic from the thread, but since I messed up...
Wrong way -
Right way -
Koni Yellow Whoes :( feldy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 05-21-2014 11:02 AM
WTB: Koni yellow struts and RCE yellow springs nlowell Brakes, Suspension, Chassis 2 05-20-2014 03:10 PM
koni yellow question sweeney208 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 02-03-2014 08:09 PM
FS: RCE Yellow, Koni struts and pre cut housing for Koni's. Dinko Brakes, Suspension, Chassis 21 12-16-2013 10:32 AM
-Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! OrbitalEllipses Mid-Atlantic 21 06-14-2013 12:10 PM
