Old 07-14-2014, 04:00 PM   #43
Racecomp Engineering
The suspension can certainly be tuned to work with the new power, weight balance, and higher COG. The car won't handle as well as it could with the FA, but it will be manageable if done right.
Just a compromise you have to make to have an assload of power at your fingers, er...toes.
- Andy
Old 07-14-2014, 05:33 PM   #44
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
Originally Posted by mav1178 View Post
My point is... what is your end goal? If it's just to be faster, there's much, MUCH better ways of doing it.
-alex
For example, just go out and picking up a C5 Z06. You'll go a lot faster, with a lot less headaches and money spent. You'll already be $10000 ahead with the Vette before you even start modding a Toyobaru.
neurokinetik is offline   Reply With Quote
Old 07-14-2014, 05:40 PM   #45
DarkSunrise
DarkSunrise's Avatar
I wonder if cooling would be an issue for an LSx track car. It's already a bit of a problem with a FI FA20.
2022 BRZ Build
2013 FR-S Build
Old 07-14-2014, 05:53 PM   #46
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Quite likely if he doesn't size the fluid radiators correctly. There are many thousands of people in this country that know the sizes he'll need, so he should be good to go on that front at least.
I wonder if he'll need a dry sump. Vorshlag can get him squared-away as far as that goes.
dradernh is offline   Reply With Quote
Old 07-14-2014, 05:53 PM   #47
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
The LSx engines hold a lot more oil and water than the FA20 does, so that reduces (note: does not eliminate) heat issues especially because it would be pulling around a lot less weight and frontal area.
bimmer635csi is offline   Reply With Quote
Old 07-14-2014, 05:55 PM   #48
Jawnathin
Drives: Toyobaru FRZ
Really like the FA20 Subaru used in our 86s but LSx engines have the best blend of size, weight, reliability, and performance. FA20 has its benefits of a lower COG/form factor, but LSx engines are pretty compact and light too.
Even if you can get an FA20 to a comparable HP level as an LS engine, I'd still take the LS engine for reliability reasons. A stock LSx is going to make as much/more as a a highly strung FI FA20. In addition to high reliability and performance, with the NA LSx you won't have to deal with heatsoak, turbo lag, inconsistencies or anything else that FI brings along with it.
Would I swap an LSx into an 86? Probably not, its a lot of work and money, would be better off buying a factory LS car to begin with (C5 Z06 has been the best bang for the buck for a very long time). But if it was as easy as checking off an option box and accepting delivery, I'd strongly consider it if I was seeking that level of performance.
Jawnathin is offline   Reply With Quote
The Following User Says Thank You to Jawnathin For This Useful Post:
hmong337 (03-21-2015)
Old 07-14-2014, 05:57 PM   #49
Jawnathin
An NA LSx will almost certainly run cooler than an FI FA20.
NA FTW
Old 07-14-2014, 06:25 PM   #50
dradernh
This.
The relative lack of fussiness has a lot going for it. Then there's the sound!
Old 07-14-2014, 11:09 PM   #51
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Although I am a huge fan of LS motors, I just don't see this being a smart path unless you're sitting on a broken FA or you " just gotta have a V8". Going from 160 whp to 200 whp with the requisite tire, brake and suspension upgrades yields huge reduction in lap times. Going to 300 whp with a conservative E85 FI tune will make it even quicker but won't gain as much as the former. Breaking the bank on a transplanted V8 and tranny package will make the car even faster but the gains on a circuit compared to the FI FA motor would be VERY driver dependent and limited only to specific tracks with straights long enough to take advantage of the additional power.
All that being said, we all know that shit breaks, especially in a track environment so if I ever have a catastrophic failure it will be a tough call between a built FA replacement versus the V8.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 08-01-2014, 03:47 AM   #52
Food
Drives: ...saving up for FRS/BRZ still
Crawford has used 285s in the rear under stock fenders, no pull, no roll, 9.5" et38. And also 275 square on other occasions (which many here in ft86club already have shown/done successfully).
Great for LSx swaps or other high hp FI FA setups
Food is offline   Reply With Quote
Old 08-01-2014, 04:25 AM   #53
s2d4
s2d4's Avatar
Lol, how many times have you been banned and came back again?
You may try Foodbro, Foodfriend, Foodmate, Foodboy etc.
Old 08-01-2014, 11:27 AM   #54
D K
Stig's dark passenger
Quirt is that you?
D K is offline   Reply With Quote
Old 08-23-2014, 09:23 PM   #55
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
At the local track a few months ago I saw LSx swapped (older) 5 series BMW. (F**k me it was fast. It was a dedicated track car,gutted,totally worked over.) I really liked the comment the owner made about the BMW Club not liking his car because "it wasn't a BMW". This made me laugh. I love it when the purists get upset.
Old 08-23-2014, 09:28 PM   #56
Captain Snooze
Drives: Red Herring
....anyone else agree and think the same? (..in that, getting a used Cayman/911/996 instead of doing a $25k LSx swap, is a good/better choice)?
As has been suggested in another thread it is not just about the money, power or practicality. It's about having something that's different that you have done to your car.
engine swap p3raltaboi Hawaii 25 06-11-2014 06:15 AM
Engine swap JDM EJ25 STI engine FRSToyota86 Engine Swaps 25 11-20-2013 01:56 AM
4-aGE engine swap on FR-S bacon_cheese_beer Engine Swaps 13 12-15-2012 03:29 PM
Engine Swap ... Macavely Engine Swaps 220 07-25-2012 03:58 AM
engine swap thread aspera Engine Swaps 231 03-15-2011 05:10 PM
