Old 07-07-2014, 04:37 PM   #1471
johnnyb305mia
Drives: 14 BRZ Limited
I will post up the numbers after so u guys can see what i am saying maybe i did not use the correct wording my appologies but i can almost gaurentee my torque will drop off as soon as i switch out my exhaust yes i will gain more hp though so i understand quite clearly there are gives n takes with regards to this how much it will drop off well we shall see when im dyno
johnnyb305mia is offline   Reply With Quote
Old 07-07-2014, 06:02 PM   #1472
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Where's your previous dyno graph?
Old 07-08-2014, 01:33 PM   #1473
BadBRZ
Drives: Subaru
Originally Posted by nelsmar View Post
... I run pretty heavy on the DI injection on my own car....
care to explain?
BadBRZ is offline   Reply With Quote
Old 07-09-2014, 12:33 AM   #1474
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by Reaper View Post
im actually going to run my ducati engines exhaust INTO my tailpipe to really up the pressure. More heat and pressure means more powa right?
I think I'll make a custom header to route exhaust port 1 into 2, and 3 into 4. Tx2k here I come.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 07-09-2014, 12:44 AM   #1475
Dan@AWD
Drives: 2013 Argento FR-S
Why is everyone on this forum always trying to beat someone up?
https://www.google.com/search?q=does...spv=1&ie=UTF-8
Dan@AWD is offline   Reply With Quote
Old 07-09-2014, 02:45 AM   #1476
sw20kosh
Drives: 2013 Black FR-S
Back pressure resists airflow through the engine thus reducing the torque produced per revolution. It is especially bad on a turbocharged application as you want as little back pressure after the turbine as possible. You want this because a turbo is most efficient with a large pressure differential across the turbine blades.
If you gained torque by downsizing your exhaust it is most likely due to tuning issues or the larger exhaust was designed with flaws in it like too many bends or improperly mated flanges that caused turbulence.
Here is a tuned 2.25 vs a tuned 3" exhaust on the same motor (H22A): Bold line is 3"
2.5 vs 3" on a turbocharged miata at 11 psi: red is 3"
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
Dipstik-sportech (07-09-2014), Reaper (07-09-2014)
Old 07-09-2014, 09:46 PM   #1477
johnnyb305mia
because the scion and subaru community is a fuckin joke and nobody has better shit to do! Worse than the fuckin tc community
I hear and see what you are saying and im not talking about downsizing if you read my post ud see that i have stock exhaust and im gonna do 2.5 inch i wont even say anymore n just wait to see results like i said when i had my turbo tc and went to 3" from 2.5 i saw,power gains but a slight tq dip yes 2 completly diff cars for sure n there was def no tunning issues as i had put down 391whp stock motor on E85 in that car and i highly doubt ptunings 3" exhaust has any design flaws for that car niether did my 3"custom with vibrant 3" throuh n through which yielded more power than the ptuning set up
And to respond to the guy who asked about my dyno sheet dorry i dont have any lrint outs cuz im not a dyno wueen who worries about having the biggest **** on this forum cuz i put up a dyno sheet with numbers no i could care less if someone make more power so i dont even ask for a print out not needed car runs great n is faster than alot of ppl soo thats all that matters there will always be someone faster i build y car for me and who ever limes it cool and whoever doesnt cool as well i will be on at the end of this month n i will post results and if ppl beliebe me fine if they dont fine i know what it is and local guys can atest to that so PLP
Old 07-09-2014, 10:15 PM   #1478
Hawaiian
That guy
Hawaiian's Avatar
Is this in English?
Ultramarine mt FR-S
P&L stage 1 turbo
The Following User Says Thank You to Hawaiian For This Useful Post:
jamesm (07-16-2014)
Old 07-10-2014, 12:03 AM   #1479
Reaper
Reaper's Avatar
Drives: violent
That was painful to read.
The Following User Says Thank You to Reaper For This Useful Post:
jamesm (07-16-2014)
Old 07-11-2014, 02:16 PM   #1480
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
Where did everyone pull the water lines from? The instructions didn't quite cover that section.
crazyfrenchbiker is offline   Reply With Quote
Old 07-11-2014, 02:31 PM   #1481
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
y u dun beliebe any of words he say yu mus b joke
Ironsquid is offline   Reply With Quote
The Following 2 Users Say Thank You to Ironsquid For This Useful Post:
jamesm (07-16-2014), Reaper (07-11-2014)
Old 07-11-2014, 02:42 PM   #1482
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That is because most of the FA20Club turbo kit owners did not opt for a water cooled turbo. There are posts discussing this in the Full Blown owners thread, but I grabed the water from the hose barb on the water jacket that goes over the top of the motor near the throttle body and the back of the engine on the driver side. This method eliminates the throttle body cooling.
crazyfrenchbiker (07-11-2014)
Old 07-11-2014, 02:44 PM   #1483
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
throttle body warming
Fixed the wording for you.
Old 07-11-2014, 02:44 PM   #1484
Reaper
Reaper's Avatar
Drives: violent
^^same as me. I should put pictures of that in my build thread with how much that gets asked.
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 11:48 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 08:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
