Old 07-11-2014, 09:40 AM   #15
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Originally Posted by D K View Post
Haha
I guarantee you that wasnt a stock trans...
Stock, possibly no, but it is likely a beefed up OEM transmission. ST class is meant to use much of the original car. The Irish Mike's Genesis' were running stock mechanics (read: just ECU changes) drivetrain from airbox to exhaust tip.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 07-11-2014, 09:43 AM   #16
Kido1986
Dodging cones
Kido1986's Avatar
Originally Posted by Rampage View Post
I guessed that to be the reason but I believe that there are now cars FT86 cars racing with good success. Some are even competing for 24 hours and winning in Europe. Maybe they are not tuned to the extent of the DT cars but they certainly should be able to do the Pirelli World Challenge TC class where they only run for about 40 minutes twice per weekend. I wonder if that chassis is for sale.
ST Rules run the engines close-ish to OEM setups and they were trying for 300HP NA on these engines. That's no simple thing to do reliably when you consider most of 3 hours at a time will be spent at WOT.
I can't seem to find a build rulebook (just the generic one). Ernie, do you know if those are made public?
Old 07-11-2014, 11:04 AM   #17
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Insanely envious of your position sir. @ErnieFrancisJr
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 07-11-2014, 11:17 AM   #18
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Originally Posted by forwallblakmail View Post
DI SEALS FTMFW!
Yeah in ST they have to go 2.5 hours but the secret to DI seals longevity is engine cooling and a proper tune. These motors run extremely hot. A oversized oil cooler is imperative.
If they raced the car in Pirelli then they would only have to go 40 minutes which would solve much of the reliability issue. The SkullCandy Nissan Altimas just switched to Pirelli and they are much more competitive there than they were in Conti ST.
I would be surprised if anyone in ST is getting 300HP out of their engines. I read an article in Road and Track or GRM a couple years ago where they were reviewing a competitive ST car and it was producing under 250HP. I don't think they have advanced to 300HP in just a couple years. I suppose I could be wrong but that seems to run contrary to the cost containment philosophy type of racing that these classes are known for.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 07-11-2014, 11:36 AM   #19
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The SkullCandy Nissan Altimas did win the BMW 200 or whatever it is called at Daytona a couple years ago. I don't think there is any way you are going to get 300 HP NA out of the FA20. I don't know the fuel restrictions or fuel cell size limitations for the ST class though since it is enudrance racing.
Old 07-11-2014, 11:37 AM   #20
sluflyer06
Drives: 2014 BRZ Ltd - DGM
Sounds like straight cut gears to me.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 07-11-2014, 12:35 PM   #21
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Also sounds like a Twin Screw SC is equipped. Innovate? I wonder if the infamous heat soak was causing issues with power delivery? Or that tip in knock specific to the Innovate SC that some tuners were previously having issues with could have eaten up the DI seals. Just guessing now since RRR will probably never release info about their reliability issues.
The Following User Says Thank You to ATL BRZ For This Useful Post:
CSG Mike (09-13-2014)
Old 07-11-2014, 05:55 PM   #22
forwallblakmail
Troll Level: Expert
forwallblakmail's Avatar
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
I don't think you're allowed to run FI on non-FI equipped cars in ST per the conti rulebook.
Nick K.
NASA ST5/TT5 #130
Southeast Region
forwallblakmail is offline   Reply With Quote
Old 07-11-2014, 06:03 PM   #23
ddeflyer
I think you might be hearing the straight cut gears in the race transmission. I don't think they are allowed to change the aspiration mode of cars. I talked to some of the teams running Civic SIs and they were saying they had sealed engines and tuned them to get about 250HP to the wheels. This was in comparison to the cars that came stock with turbos which they put restrictor plates on.
Of course maybe they changed the rules or they were blowing smoke after loosing to some Miatas? (this was after the race at MRLS in 2013)
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 07-11-2014, 06:36 PM   #24
ATL BRZ
ATL BRZ's Avatar
Hum, I must be wrong then. The car just seems really torquey in that video. I'd love to see under the hood, or even better a full build sheet.
Old 07-11-2014, 06:42 PM   #25
ddeflyer
I would guess that the torqueyness might have to do with no emissions requirements, little noise requirements, much shorter required lifespan, substantially reduced weight, customized gearing, 100 octane fuel, etc.
The Following User Says Thank You to ddeflyer For This Useful Post:
ATL BRZ (07-11-2014)
Old 07-11-2014, 10:33 PM   #26
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Well, I'm a fan.
I hope to see this car on TV.
PRO86 | WTCC | STL
Old 07-12-2014, 04:31 AM   #27
D K
Stig's dark passenger
Haha
My point exactly....
D K is offline   Reply With Quote
Old 07-12-2014, 02:21 PM   #28
ErnieFrancisJr
Race Car Driver
ErnieFrancisJr's Avatar
They told me it was a stock tranny, but with a short shift kit. It was very nice to shift though.
Ernie Francis Jr
16 year old pro driver in Pirelli World Challenge and Trans-Am.
www.ErnieFrancisJrRacing.com
ErnieFrancisJr is offline   Reply With Quote
Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 13 05-08-2014 09:06 PM
Scion to run Continental Sports Car Challenge next year Spaceywilly Off-Topic Lounge [WARNING: NO POLITICS] 4 01-23-2013 05:05 AM
Scion FR-S Testing at Laguna Seca JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 2 07-09-2012 11:04 PM
Scion FRS track testing en español :) ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 05-11-2012 02:06 PM
Scion FR-S Testing at Laguna Seca davey90 AUSTRALIA 1 03-27-2012 08:25 AM
