Old 07-10-2014, 09:19 PM   #1051
DC2R
Drives: 2014 Scion FR-S
Originally Posted by DC2R View Post
Thanks. I've been wondering. I contacted Pandora and they said "try now" an hour ago.
Just downloaded oft beta UEL stage two tune and bought ODB2 splitter. Time! to go downstairs and play
Sent from my SM-N900T using Tapatalk
If still not working I'll drive to Starbucks and try there. Unfortunately I live in middle of complex on third floor. I'd have to install a satellite dish on car roof with TPLink Wi-Fi module in the center.
DC2R is offline   Reply With Quote
Old 07-11-2014, 08:27 AM   #1052
Shady195
Drives: '13 10 Series FRS #1203
For those wondering you can download google maps locally to your device however it only lets you select a specific area size and up to 6 samples. It's a little finnicky but it does work.
https://support.google.com/gmm/answer/2650377?hl=en
Also WAZE I belive supports downloading maps locally as well as other 3rd party GPS apps like Sygic, TomTom who support full map downloads.
Shady195 is offline   Reply With Quote
Old 07-11-2014, 10:22 AM   #1053
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
I've always just assumed this is because the Ca-Fi doesn't have the best specs, or that I had a slow Class 4 microSD card, but I bought a better SD card and it's still happening, so I thought I'd ask you guys...
I listen to these hour-long EDM mixes pretty often. When I turn my car on, open PowerAmp, and press play, it usually takes about 10 seconds for the song to start. The files are probably a little over 100 MB each if I'm remembering correctly, and I'm using a class 10 microSD card that boasts read speeds of up to 90 MB/sec (so I'm sure it averages closer to 40 or 50), so these files should load pretty fast. PowerAmp is loaded into the internal Ca-Fi storage, not the SD card. Any ideas on why this is so slow? My unit is not rooted and is completely stock, haven't even updated it.
Prog is offline   Reply With Quote
Old 07-11-2014, 10:32 AM   #1054
bwthor
Drives: gray
Torque Question and Auto Tether Recommendation
Is anyone using the Torque widgets? I've set them up, and every time I reboot the unit, they disappear. Are they staying for anyone?
Also, I ran across a free auto tether app that has been working great for the last few days. It is called AutoTether for Automatica, and here is the link...
https://play.google.com/store/apps/d...ethering&hl=en
Of course, you install this app on your Android phone, and when you are in bluetooth range of your Ca-Fi, your Wi-Fi hotspot on your phone turns on automatically. There are some reviews that complained it wasn't working properly, but it hasn't missed a beat for me in the three or four days I've been using it. I'm using it on my HTC One M7.
bwthor is offline   Reply With Quote
Old 07-11-2014, 05:52 PM   #1055
DC2R
Used to work great for me but haven't been assume to get it to work in some time.....auto tether that is. Maybe I'll try the five dollar app...our bite the bullet and job the world of tasker....Maybe ittt has a function for this
Old 07-11-2014, 07:20 PM   #1056
inositle
Drives: Subaru BRZ Limited WRB
Hey everyone, I have tried to help out some of the new people by making a Google Doc with a list of common questions & solutions. I'm not sure what the best method for a collaborative document is, so I've currently set it so that anybody with the link can edit. Hopefully this will get filled out some more and maybe we can get SHIFTER to put this or something similar on the first post for new buyers.
Link Here
Cheers,
Josh
inositle is offline   Reply With Quote
The Following 7 Users Say Thank You to inositle For This Useful Post:
axelo (10-25-2014), Maniak_ (07-14-2014), Nsot (07-18-2014), Prog (07-11-2014), Pwolf (07-11-2014), riyal (07-16-2014), SilverlightPony (07-11-2014)
Old 07-11-2014, 07:58 PM   #1057
Prog
Prog's Avatar
Link Here
Cheers,
Josh
You rock man, thanks. This will be super helpful to newbies in this thread.
Old 07-11-2014, 11:02 PM   #1058
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
You know Tasker can do this and much more...
Deathalo is offline   Reply With Quote
Old 07-11-2014, 11:06 PM   #1059
Deathalo
I don't really know man, since I just use a high capacity (256gb!) flash drive hooked up to a hub on this sucker for all my music. I have an SD card in there but I don't even put my apps on there because I have experienced issues with the apps that I've moved over, so maybe the SD card slot is just not fast enough or something. My recommendation of course would be to get a slim hub and double sided tape it to the roof of your glove box, then get a flash drive for all your music.
Old 07-12-2014, 12:51 AM   #1060
DC2R
I put a slim hub behind radio, ran factory port to it, and then ran a us extension to hang out in glove box. This way you keep factory port.
Sent from my GT-N5110 using Tapatalk
Old 07-12-2014, 11:04 AM   #1061
Deathalo
Oh, I still kept my factory port, it's connected to the back side of the hub in the glovebox, so it basically follows the cord that's connected to the HU out of the glovebox and you never know it's there unless you look up into the glovebox. I tell/show people the hub and explain and they think it's pretty slick.
The Following User Says Thank You to Deathalo For This Useful Post:
DC2R (07-12-2014)
Old 07-12-2014, 01:48 PM   #1062
DC2R
Should have done that. Didn't know cable was long enough....actually I could just use extension. Lot cleaner than mine with just a loose USB extension in glove box
Old 07-13-2014, 10:38 AM   #1063
Stormalong
Drives: Firestorm FR-S AT
I'm using MacroDroid for auto tethering. Its basically the same as Tasker, but I find it easier to work with. Its not 100%, occasionally I will leave the car and find that the hotspot is still enabled even though bluetooth is disconnected, but I had the same problem with Tasker.
Phantom Electric Supercharger with Procede controller, GReddy SP Elite, CA-FI Dashlinq4
Stormalong is offline   Reply With Quote
Old 07-13-2014, 11:33 AM   #1064
DC2R
Free?
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 07:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 04:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 05:58 AM
