Old 07-09-2014, 10:14 PM   #29
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Is the raspiness bad when the primary cat is removed? I'm not super worried about being catless, but if it (UEL header) will end up sounding like crap anyway then I won't bother.
B-R-Z is offline   Reply With Quote
Old 07-10-2014, 07:59 AM   #30
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by B-R-Z View Post
That's the point of this thread chief.. Everyone is aware its against the law
If you read the thread more carefully, and some of the others like it, you'll see that not everyone is aware of it. There are clearly members who think it is okay to swap them out and just don't fully understand. Read before posting snide comments and you won't look like an ass, okay? Chief?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 07-10-2014, 08:31 AM   #31
B-R-Z
B-R-Z's Avatar
I think I emphasized in my first post that my concern was getting caught/nailed running catless which would mean I'm aware (and readers can ascertain) it's illegal to do so. And I don't feel like an ass, at all. But ok. And fine, maybe the chief was inappropriate.
Old 07-10-2014, 09:15 AM   #32
aakash
Drives: Asphalt FRS
Originally Posted by chas3wba0 View Post
It's kind of like running dark tints or no front plate... it's technically illegal and they see you rollin', but they have better things to worry about. If they tagged you for something else, e.g. speeding, then they might cite u for catless/no front plate/tint while they're at it.
spot on...I do all of those things at the same time
aakash is offline   Reply With Quote
Old 07-10-2014, 12:07 PM   #33
mid_life_crisis
And this car has two cats? So losing one I still have one so doesn't that help at all and\or make me legal?
I think you can understand my confusion.
Old 07-10-2014, 12:57 PM   #34
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Correct me if I am wrong here but if you go catless with a tune you will an inspection if the shop checks emissions via the obd port and not with a device in the exhaust. So maybe a tune will help you?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 07-10-2014, 01:08 PM   #35
cnk
Drives: '13 DGM BRZ Limited
With a tune you should be able to pass an OBDII scan and usually even a sniffer test, but you'll fail a visual inspection.
Old 07-10-2014, 01:32 PM   #36
DarkSunrise
DarkSunrise's Avatar
My understanding was that if you're catless (without spacer), you will throw a check engine light. You can get a tune to turn off the CEL, but that also disables OBD readiness. I could be wrong though.
2022 BRZ Build
2013 FR-S Build
Old 07-10-2014, 02:02 PM   #37
mweidner311
Drives: N/A
I do too! Minus the front plate not required in GA. I have 20% tint all the way around 5% strip on the front and I have a catless front pipe with Perrin Cat Back system. Got pulled over last Saturday on I75 coming home from Kentucky the day after the 4th of July lasered at 86 in a 70.
Just got a speeding ticket only I know the county Sheriff saw the illegal tint and I know he could smell the exhaust while I was sitting there idling I just think they dont give a sh*t about that stuff......
Everything is a gamble its all relative.... roll the dice dude do what you want
mweidner311 is offline   Reply With Quote
Old 07-10-2014, 02:09 PM   #38
mweidner311
Drives: N/A
One more thing
If you're looking for a safe way to get the boxer rumble as others stated run a catted uel header if your worried and add a catless front pipe to liven it up a bit (I know its more money but worth it for piece of mind and if I learned anything with my car dont go cheap you'll regret it latter and inevitably spend more money in the long run making it right).
You'll still pass every OBDII test and visual inspection chances are the people working the inspection buildings wont know its supossed to have two cats to begin with... since most vehicles only have one to begin with nothing will seem out of the ordinary...
Either way good luck!
Old 07-10-2014, 02:21 PM   #39
stevo585
Drives: White 2014 BRZ
Originally Posted by mweidner311 View Post
One more thing
I went the other way catless header and catted front pipe. I would think this would give more performance. But
stevo585 is offline   Reply With Quote
Old 07-10-2014, 02:22 PM   #40
Lischynski
Weendog
Lischynski's Avatar
Drives: 2014 Scion FR-S
One more thing
If you're super paranoid, the hi flow cat front pipes don't take THAT much away as well, but that's going over the top.
Like I said, I have no cats, and the sound is easily manageable (it's only very very loud when I'm on it), and my personal catless smell is mild. If I get pulled over, which I haven't yet, I'll shut of my car and the officer wouldn't have a clue. I even live next door to an officer and he's never minded my car.
Old 07-10-2014, 02:28 PM   #41
mweidner311
Drives: N/A
I would think so as well but did it throw a code? I would go that route myself but the o2 sensor is only right after the 1st one...
Good point! Hell the officer would probably even appreciate you turning the car off
Old 07-10-2014, 02:31 PM   #42
Lischynski
Weendog
Lischynski's Avatar
It would throw a code. He's likely doing that just for emissions. If you get a tune, and have that setup, you're most likely all set for emissions testing.
Running catless, rasp and smell pgeist Engine, Exhaust, Transmission 41 04-21-2014 07:26 AM
Anyone Running Full Catless w/Muffler Delete? djliquidsteele Engine, Exhaust, Transmission 32 08-30-2013 01:39 AM
Anyone only running a catless front pipe?? Pele86 Engine, Exhaust, Bolt-Ons 7 08-01-2013 02:35 PM
Anyone running 3" exhaust & catless header? RiskyTrousers Engine, Exhaust, Transmission 19 08-01-2013 09:09 AM
Advice on running catless Raike NY / NJ / CT / PA 5 06-04-2013 03:29 PM
