Sam Strano
Old 07-09-2014, 04:03 PM   #1275
Jawnathin
Drives: Toyobaru FRZ
Heh, these are like 90 second long courses at higher speeds. Pretty nice setup you've guys got going on. Very lucky that you have two of them.
The site in my video is the nicest one we've got, pretty happy to have it, though its likely to be gone after this year. The rest are beat up Stadium parking lots with a lot of gravel and loose surfaces.
I think the higher speed transitional stuff is the most fun kind of course. Slower, tighter stuff isn't as 'testing' I've found. It's not hard doing a 15mph u-turn and only helps high HP cars (which my other car is quite fond of...)
Anyway, I saw what you meant by the launch. Bogging down or being sub 4k RPM really hurts. These cars need to be revved out to be kept happy. When on course, I usually err on the side of more throttle and just hope it sticks. The car really depends on speed maintenance.
Jawnathin is offline   Reply With Quote
Old 07-09-2014, 06:19 PM   #1276
Jawnathin
Did you guys push inward on the strut with the top hat loosened prior to tightening everything down to try to get more camber? I know it won't be much, but more would be better for us.
I'm thinking that when I install the struts, I'll push inward on the strut, then tighten the top hats. Then when installing the crash bolts, push inward on the hub/rotor, then tighten the nuts.
Thanks.
Old 07-09-2014, 06:23 PM   #1277
markw
Drives: 2014 FR-S
I plan on jacking up the wheel at the hub when I do it.
markw is offline   Reply With Quote
Old 07-09-2014, 06:46 PM   #1278
Jawnathin
Will that work? Maybe with everything loose it'll get some negative camber out of it, but it was my understanding that our front suspension dials in some positive camber under compression. Jacking up on the hub will be upward pressure, not inward.
Thanks.
Old 07-09-2014, 06:53 PM   #1279
markw
Drives: 2014 FR-S
I'll let you know, plan on doing it this weekend.
Old 07-09-2014, 07:23 PM   #1280
Jawnathin
Thanks. Good luck.
Old 07-09-2014, 10:47 PM   #1281
TrqlessWonder
Drives: 2014 FR-S
Thanks.
Putting a floor jack on the rotor won't necessarily get you much (handier on cars that get upper and lower crash bolts) but every bit helps. If nothing else, it'll help keep it as far negative as possible while you tighten the bolts back down. Think of it more like an extra set of hands.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 07-09-2014, 11:49 PM   #1282
Jawnathin
Is it any better or worse than just pushing inward while tightening?
Old 07-10-2014, 05:49 AM   #1283
TrqlessWonder
Drives: 2014 FR-S
In our case, probably not, but you need two hands to tighten it down. So, you'll want something (friend, floor jack, something) to help hold it in place while your hands are tied up.
-Mike
#24 CS/CSR
Old 07-10-2014, 08:48 AM   #1284
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
When I installed the crash bolts, the upper part of the hub just fell in to negative camber. Gravity holds it there for you until you can snug it up.
The top of the struts is kind of the same because you only need one hand to tighten the three strut hat bolts, so you can lean on the strut rod to get negative camber if it doesn't fall in anyway.
bimmer635csi is offline   Reply With Quote
Old 07-10-2014, 09:30 AM   #1285
TrqlessWonder
Drives: 2014 FR-S
The hydraulic jack pushes a little harder than gravity does. Gravity is acting on the bolt, too, and that bolt wants to find the bottom of the hole, which is not where max negative is. That's why I use a jack anyway. It is, admittedly, a tiny benefit, though.
-Mike
#24 CS/CSR
Old 07-10-2014, 07:22 PM   #1286
Jawnathin
Got it. I've got a friend helping, so I'll just have her push inward while I tighten. I can see the benefit if you were working solo though.
Old 07-11-2014, 09:00 AM   #1287
mla163
Overthinking it
Drives: BRZ in CS
Quoted for innuendo.
mla163 is offline   Reply With Quote
The Following 4 Users Say Thank You to mla163 For This Useful Post:
DylanFRS (07-11-2014), Jawnathin (07-11-2014), Kido1986 (07-11-2014), renfield90 (07-11-2014)
Old 07-11-2014, 10:08 AM   #1288
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Is there anything in this world MORE innuendo-laden than working on a car?
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
