#1611 | |
Drives: Some rust bucket
#1612 |
Fat on Corn Syrup
At 6'3" and 250 lbs, I sit as low as possible with seat bottom all the way back and the seat back pretty upright. No helmet rubbing on the roof. I don't have a problem seeing out or placing the car, but I've been told my spacial awareness is pretty high. I tend to drive by feel, having already placed road variances, seams, debris and stuff in my memory once they're within say a two seconds (?) so I'm not looking at them. I don't know if that makes any sense.
Sent from a secret volcano base using trained sharks |
#1613 |
Drives: 2014 FR-S
Do the input shaft bearing on the trans while it's out. Not hard to do on Honda manual transmissions.
#1614 |
#1615 |
Drives: WR Blue BRZ
I sit as low as I can in any car I drive on track or street. Sitting higher is only necessary when you are really short like my wife. At that point she can't see over the dash so raising her seat makes sense. To me the fact that you feel you need to raise your seat to see says you're not looking far enough ahead as a driver. Also like some of the other people said sitting lower helps you feel the car better.
#1616 | |
i'm sorry, what?
Drives: Canada
one of our top talent around here drives with 1 hand..... i also know fast guy that drive with outstretched arms. I fully understand the basic ideology of proper seating position, i've been doing this for close to a decade and instructed dozens of students, but at the end of day the point is whether or not you feel that YOU'RE connected with the car. And for each individual this micro adjustment comes later on in their racing adventures. I merely pointed out an observation that I've had while owing this car. I experiment every race to try and find the combination that works, and it seems that sitting higher for me seems to connect me to the car better, that is all.
#1617 |
Drives: 2014 Toyota 86
Is a 225/40R17 to stretched on a 17x9?
I can definitely agree that a 215 or 225 can be the superior choice for track days.. My issue is i also plan to participate in quite alot of auto x were i could imagine 255/40R17 helping out, specially for local layouts, very often around go-kart'ish tracks. |
#1618 |
Depends on the tire. If a 9" rim is within the manufacturers spec then it should be OK.
#1619 |
Drives: 2013 Black FR-S
any thoughts on running pure distilled water for radiator in the summer?
#1620 |
#1621 | ||
Drives: 2013 Cayenne turbo
However, due to the colligative properties of solutions, the boiling point of water INCREASES when you put stuff in solution. For example: Quote:
Random Website Granted this is the old ethylene glycol coolant, but the same general performance can be expected from modern coolant as well. Point is, the pure water system will boil at a lower temperature and boiling coolant systems are no good.
Chris
Track, Autocross & Daily Driver build thread - SOLD Another A&DD for my VW GTI - SOLD And finally, my YouTube channel |
#1622 |
Drives: 13' FJ Cruiser TT | 13' 10 Series
About to go to my first track day with (hopefully) 1000 miles on the car, will be taking it easy and just learning the car itself since it's brand new and I'm brand new to the track. Will be attending Buttonwillow Open Test day with a friend whos a regular (he races in the GT86 Challenge thing) as well as a few other FRS buddies. Any suggestions or notes that aren't "common sense"? Planning to only do half the day so not sure how many laps I'll actually get in.
#1623 |
Drives: 2013 Scion FRS
Suspension adjustment question:
I recently installed Koni Yellow Struts, Eibach Pro-Kit Springs, and Eibach Anti-sway Kit. Current Settings: Struts Front - 1 turn from soft Rear - 1/2 turn from soft Sway Bars Front - Stiff (+248% from OE) Rear - Soft (+92% from OE) Question is: Should I put the rear Sway at full stiff (+153% from OE) and then adjust the rebound of the Koni's to adjust under/oversteer at the track? Put another way, if I have too much oversteer then should I adjust the sway bar or strut first? Thanks in advance!
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
#1624 |
i'm sorry, what?
Drives: Canada
adjust the shocks is easier
but almost doubling the bar rate will have a more noticeable effect since it's the spring rate that determines weight transfer, the rebound adjustability of a koni merely controls it.
| The Following User Says Thank You to 7thgear For This Useful Post: | nlowell (07-09-2014) |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
