Old 07-08-2014, 05:16 PM   #1037
Mehster
Drives: Firestorm 2013 Scion FR-S
I grabbed Sygic [https://www.sygic.com/en]. It has full offline navigation support and all the maps can be downloaded to the SD card. I think the full set of US maps was around $33. I've used it for several long road trips and it does the job.
Mehster is offline   Reply With Quote
Old 07-08-2014, 08:41 PM   #1038
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Originally Posted by SilverlightPony View Post
Most Android navigation apps require an active data connection, as they do not store the maps locally. I'm not sure about the nav app that comes pre-installed on this, as I haven't messed with it at all.
There are plenty of offline nav apps available, Waze even has that ability (it's really my favorite map app for plenty of reasons).
Deathalo is offline   Reply With Quote
The Following User Says Thank You to Deathalo For This Useful Post:
skeet (07-13-2014)
Old 07-09-2014, 12:11 AM   #1039
eliminist
On sale now, really good app.
eliminist is offline   Reply With Quote
Old 07-09-2014, 09:57 AM   #1040
DC2R
Drives: 2014 Scion FR-S
Anyone using the sub output? It's a single RCA so I used a highly rated gold plated splitter at the head unit and ran a set of RCA to sub. Voltage is VERY low. I have everything turned to max and still weak.
Think it will be a problem using a pair of the the regular speaker RCA outs and just relying on subwoofer amp to handle all crossover duties?
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 07-09-2014, 01:07 PM   #1041
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
Double checking I'm getting the right cables... I'm looking at this post:
http://www.ft86club.com/forums/showp...7&postcount=74
IIRC, you also have to tap the front speakers into the amp as well correct? Is there a plug and play option for this?
Pwolf is offline   Reply With Quote
Old 07-09-2014, 01:28 PM   #1042
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
Yeah, but the harness they give you doesn't have the amp wired in properly. Its set with an empty pin, which is incorrect. It needs to be wired in properly (go pick up a harness at best buy and you'll see the amp wired in correctly). I'll take pictures and post later.
ybotspawn is offline   Reply With Quote
Old 07-09-2014, 03:46 PM   #1043
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
I'm using the sub-output and I don't notice any difference in output with my pathetic, low-profile 8" powered sub.
Prog is offline   Reply With Quote
Old 07-09-2014, 06:31 PM   #1044
DC2R
Hmm I came from high to low converter using wires at factory amp. It was a powerful dirty signal. Was exited to get a clean RCA signal but Damn is it weak.
I'm using a powered ten so nothing crazy either...couldn't fit my 3000 watt type r setup.
Are you using a splitter?
Old 07-09-2014, 11:26 PM   #1045
Prog
Prog's Avatar
I'm using a Y-adapter, if that's what you mean. I'm not really an audiophile, so honestly, I probably wouldn't notice even if there was a difference. When I first got the sub, I was very underwhelmed with how it performed. Upgraded the door speakers and Dynamatted the doors, and now I don't even feel like I need a sub.
Old 07-10-2014, 02:02 PM   #1046
DC2R
Cool. It's enough to rattle every interior part lol.
Since last update with car home removed Pandora never starts playing songs. Just loads album art and immediately skips to next track.
Old 07-10-2014, 02:04 PM   #1047
DC2R
Wonder if this has something to do with the way T-Mobile views this traffic since they don't count against your data usage anymore...I'm tethered from a note 3
Old 07-10-2014, 02:45 PM   #1048
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Try it when connected to your home WiFi or something to try and rule that out.
I don't think it's a T-Mobile thing though.
Old 07-10-2014, 04:15 PM   #1049
Prog
Prog's Avatar
Using your phone as a personal hotspot to stream data is not included in T-Mobile music freedom "Uncarrier" thing. That data counts toward your data usage. That said, I don't think that's your issue.
Old 07-10-2014, 09:16 PM   #1050
DC2R
Thanks. I've been wondering. I contacted Pandora and they said "try now" an hour ago.
Just downloaded oft beta UEL stage two tune and bought ODB2 splitter. Time! to go downstairs and play
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 07:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 04:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 05:58 AM
