Old 07-04-2014, 12:18 PM   #435
Zero90
Zero90's Avatar
Drives: "14 BRZ Limited - SWP
Are you able to use the header for N/A? I plan to get the ptuning kit later on but no funds yet :/.
Zero90 is offline   Reply With Quote
Old 07-04-2014, 02:15 PM   #436
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
looks like it
Darryljr11 is offline   Reply With Quote
The Following User Says Thank You to Darryljr11 For This Useful Post:
Zero90 (07-05-2014)
Old 07-07-2014, 10:07 AM   #437
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
PTUNING Turbo Kit Owners Topic
Seeing as how the ptuning turbo system is designed to be used without replacing the factory header, I would say their race header follows the same path as the stock header.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 07-07-2014, 10:13 AM   #438
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Prototype header design
Old 07-07-2014, 12:15 PM   #439
ptuning
ptuning's Avatar
Drives: White FR-S
Yes, our header will work on an NA application.
- Toan
ptuning is offline   Reply With Quote
The Following User Says Thank You to ptuning For This Useful Post:
Zero90 (07-07-2014)
Old 07-08-2014, 03:39 AM   #440
parkthetiger
parkthetiger's Avatar
Drives: 2014 Forester XT, Porsche 944
Will the header fit with the factory front heat shield like you previously mentioned in this thread?
parkthetiger is offline   Reply With Quote
Old 07-08-2014, 12:54 PM   #441
ptuning
ptuning's Avatar
Drives: White FR-S
Our header will clear the factory lower metal tray cover without any modifications to the tray or use of spacers.
- Toan
Old 07-08-2014, 02:34 PM   #442
ptuning
ptuning's Avatar
Drives: White FR-S
Here are some teaser pics of our finalized prototype PTUNING 4-1 EL Race Header. Production on the header is already under way. Multiple fixtures are currently being made for the production of this header. Please ignore the multiple small sections used in this prototype as we were continuously tweaking the individual runner lengths. The production headers will utilize the fewest number of weld joints possible.
Here are a couple of design goals we had for our 4-1 Header:
- Clears factory metal undertray without modifications or spacers.
- No extremes upturns in the header at the front of the engine means less heat transmitted into the engine compartment.
- Closest to equal length runners as possible. We purposely made runners 1 and 4 shorter to compensate for the offset exhaust ports on the FA20 cylinder heads. This ensures that the overall runner length from the exhaust valves to the merge collector outlet are roughly the same length between all cylinders.
- Rotational firing order through the merge collector for optimum exhaust scavenging.
- Double-slip merge collector. This style merge collector is uber expensive to implement. It does away with flex joints, yet still allows for proper heat expansion on a boxer engine.
- Custom stainless spring retention system to allow for heat expansion at the collector (Not shown in pics).
- Full T304 Stainless Steel construction. This includes the CNC machined head flanges, V-band connection, and 2-bolt flange.
- As always, our products are 100% made in the USA using only premium grade Domestic stainless steel.
- Toan
The Following 10 Users Say Thank You to ptuning For This Useful Post:
bjun (07-08-2014), buddy32 (07-08-2014), Darryljr11 (07-08-2014), Dinko (07-08-2014), ecko04 (07-08-2014), kanundrum (07-08-2014), mkivsoopra (07-08-2014), mnsayer (07-09-2014), OICU812 (07-08-2014), rb6freak (07-09-2014)
Old 07-08-2014, 03:20 PM   #443
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
Whats the inlet/outlet diameter of the piping?
Old 07-08-2014, 08:10 PM   #444
bjun
bjun's Avatar
Drives: white premium brz M/T
Ah can't wait! Any info on the sound?
bjun is offline   Reply With Quote
The Following User Says Thank You to bjun For This Useful Post:
Mrc@ptuning (07-09-2014)
Old 07-09-2014, 01:03 AM   #445
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
The header looks great, long awaited but great indeed. I figure since it's looking like FI is not happening for me this season that by next spring PT should by then finally have all their kit bits ie: header, lava oil cooler etc all available day one when a person wants to order. As much as I admire several other kits (actually just a few) when it comes to Turbo I really do like a lot of the details in this kit overall.
The Following User Says Thank You to OICU812 For This Useful Post:
Old 07-09-2014, 04:38 PM   #446
ptuning
ptuning's Avatar
Drives: White FR-S
We're running 41mm primaries with a 60mm collector.
- Toan
Old 07-09-2014, 04:41 PM   #447
ptuning
ptuning's Avatar
Drives: White FR-S
This header, when used with our PTUNING Turbo System will be slightly louder than the stock header at idle and cruising speeds. It will be moderately louder at WOT. It definitely sounds awesome when coupled with our 3" dual exhaust system.
- Toan
bjun (07-14-2014)
Old 07-09-2014, 04:51 PM   #448
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
any pricing/availability/dyno? I am very interested to use this NA until I turbo.
G-Man is offline   Reply With Quote
ptuning, turbo kit
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
Full Blown Turbo Kit Owners Topic King Tut Forced Induction 2637 12-27-2020 04:44 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
