Old 06-28-2014, 09:22 PM   #631
bacon_cheese_beer
bacon_cheese_beer's Avatar
Drives: Fr-S
washed my baby today!
"mr.Balloon hands, no way, get real..."
bacon_cheese_beer is offline   Reply With Quote
The Following User Says Thank You to bacon_cheese_beer For This Useful Post:
*LongFella (06-29-2014)
Old 07-01-2014, 09:58 PM   #632
Ethan
Drives: Subaru BRZ
Originally Posted by Ralph Spoilsport View Post
I keep hoping that someone will figure out how to get this right reliably and publish a DIY. Or maybe I'll get to be that guy.
Any luck with the bumper separation issue? I have the same problem. Tried new clips and that didn't help.
Ethan is offline   Reply With Quote
Old 07-02-2014, 12:52 AM   #633
CSG David
CSG David's Avatar
Typical bumper issue if you're not too careful during removal. It's kind of annoying, but if you got the finesse down, it goes back in perfectly. In terms of the intake piping, just remember to massage it to fit properly. Everything was sized so your pipes don't randomly pop out if you didn't tighten down the clamps enough.
Old 07-02-2014, 09:13 AM   #634
Suddenly...
Suddenly...'s Avatar
Drives: 2013 High AT
I love how this car looks. Any chance I can ask one of the photoshop gurus to try and shop it to look like firestorm? I would love to see how my car would look with this setup. Beautiful man, and so clean too
Suddenly... is offline   Reply With Quote
The Following User Says Thank You to Suddenly... For This Useful Post:
bacon_cheese_beer (07-02-2014)
Old 07-02-2014, 04:19 PM   #635
2ndgenhachi
Drives: 2013 fr-s, sr20 180sx
Can anybody clarify if there is a way to get the ecutek features like launch control, ffs, rev matching etc onthecarb tune for the Jr kit? I've been trying to research this but haven't found a concrete answer.
2ndgenhachi is offline   Reply With Quote
Old 07-03-2014, 02:09 PM   #636
CSG David
CSG David's Avatar
The latest EcuTek software revision contains those modules/parameters. The CARB tune was developed prior to that EcuTek software update so it does not have that programmed in. That doesn't mean you can't dial that parameter yourself...
The Following User Says Thank You to CSG David For This Useful Post:
2ndgenhachi (07-03-2014)
Old 07-03-2014, 03:55 PM   #637
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Anybody with the JR Oil Cooler kit notice oil residue building up around the extension piece (right below where the two lines come out)? Is that normal? It doesn't look like it is leaking... but it is certainly not clean...
I was away for a few weeks (got married and honeymoon) and when I started the car... did the walk around and engine check... I noticed it for the first time...
Don't have a picture yet... but can post one later if needed...
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 07-05-2014, 01:59 PM   #638
*LongFella
*LongFella's Avatar
Not the best photos, but is anybody else getting some oil build up here with the oil cooler kit?
I'm doing an oil change now, so I'll tighten the extension bolt a little more...
Old 07-05-2014, 05:42 PM   #639
*LongFella
*LongFella's Avatar
Just finished an oil change and checked the kit for any issues... Absolutely nothing wrong or any wear on any part!
I've got just over 10k miles with over half of them with this kit and oil cooler...and not one issue. Awesome! We made the right choice going with this kit!
The Following 4 Users Say Thank You to *LongFella For This Useful Post:
CSG Mike (07-07-2014), OICU812 (07-06-2014), Venator (07-13-2014), Xerious (07-05-2014)
Old 07-05-2014, 11:20 PM   #640
Avo1789
Avo1789's Avatar
Drives: Ultramarine FR-S
Originally Posted by CSG David View Post
Any time you plan on changing the factory catalytic converters, a tune will be required. Catback exhausts and aftermarket overpipes will work with the CARB tune, but any modification to those OEM factory catalytic converters will pose a little problem.
What if the only exhaust change is catted headers(such as FT86SF uel). Would it need a custom tune?
Avo1789 is offline   Reply With Quote
Old 07-06-2014, 05:24 AM   #641
CSG David
CSG David's Avatar
Yes. High flow catalytic converter is not an OEM catalytic converter. You are changing the factory OEM emissions components and therefore the flow characteristics will change.
Old 07-06-2014, 06:52 PM   #642
*LongFella
*LongFella's Avatar
Any thoughts on my oil cooler seepage issue?
Old 07-07-2014, 12:02 AM   #643
enivid
enivid's Avatar
Drives: WRB JR BRZED
Mine had a slight leak from down there and from the tubing connections. I took it all apart when I did my oil change a month ago and so far everything is clean now.
enivid is offline   Reply With Quote
Old 07-07-2014, 12:38 AM   #644
CSG Mike
CSG Mike's Avatar
Just make sure everything is tightened to spec, and you shouldn't see any seepage. It's a bit awkward to tighten without the proper tools.
*LongFella (07-07-2014)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
