Old 07-05-2014, 05:48 AM   #1
WesleyG
Drives: 2014 Satin White Pearl GTS auto
Can someone tell me what this button does?
Hi guys, could any of you tell me what this button does?
Iv pushed it and nothing seems to happen, google doesn't return any hits, and the manual doesn't have anything about it.
[IMG]Name:  uploadfromtaptalk1404549944058.jpg
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
Old 07-05-2014, 06:27 AM   #2
BlueSTaR
BlueSTaR's Avatar
Drives: 13 BRZ Limited & 16 Hyperblue
Push it
BlueSTaR is offline   Reply With Quote
The Following User Says Thank You to BlueSTaR For This Useful Post:
Juvenile (07-05-2014)
Old 07-05-2014, 06:44 AM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
I'm guessing thats the button the get the car out of park if it is stuck in park?
Usually its a hole you have to push a key or screwdriver in though.
Also obligatory, "wouldn't have that problem with a manual"
Old 07-05-2014, 08:21 AM   #4
WesleyG
Lol I tried pushing it, just seems to be a spring loaded knob.
and yes I know it would be better if it was manual, but it's my finances car. And she can't drive manual
2014 37J 86 Auto
Old 07-05-2014, 08:25 AM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
See if it lets you out of park when you press it.
I googled pics of BRZ autos and they have the same thing except the button is flush and not sticking up. So it must be the gear shift release.
If you are really worried take it to the dealer and ask whats up with the button.
Don't worry about it and tell her to
Old 07-05-2014, 08:26 AM   #6
WesleyG
So basically it's to get you out of park without the engine running? I'll try it just now and see
2014 37J 86 Auto
Old 07-05-2014, 08:48 AM   #7
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
What happened??
Carlitoz3 is offline   Reply With Quote
Old 07-05-2014, 08:57 AM   #8
WesleyG
Yeah I tried it now, it's the gear shift release. Thanks guys
2014 37J 86 Auto
The Following 3 Users Say Thank You to WesleyG For This Useful Post:
Karigan (07-05-2014), korhun (09-07-2019), ZionsWrath (07-05-2014)
Old 07-05-2014, 02:08 PM   #9
wrb
frank
wrb's Avatar
Drives: Subaru BRZ WRB
this type of button is in almost every automatic vehicles.
usually hidden and hard to press (need a stick of some sort)
but it's useful, when you don't have a key or something's wrong with the car and you can start the car but need to move the shifter out of "P".
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA
Build Photo Album - http://bit.ly/brz_wrb
SoCal LA 86 Club Member
wrb is offline   Reply With Quote
Old 07-05-2014, 02:58 PM   #10
Candlejack
Ignorance Intolerant
Candlejack's Avatar
Drives: '13 WRB BRZ Limited
Shift-Lock. Different things can set it off; your brake light fuse being out, reverse lights, etc. It's so you actually check your car before you drive down the road at night without brake lights and that sort of thing.
Candlejack is offline   Reply With Quote
Old 07-05-2014, 08:04 PM   #11
Tromatic
Why they bother to kill the trees is beyond me. It is in the manual, don't know the page in the dead-tree version. From the BRZ PDF, page 390:
If the select lever cannot be shifted with your foot on the brake, there may be a problem with the shift lock system (a system to prevent accidental operation of the select lever). Have the vehicle inspected by your SUBARU dealer immediately.
The following steps may be used as an emergency measure to ensure that the select lever can be shifted.
Set the parking brake. Vehicles without a keyless access with push button start system: Turn the engine switch to the “ACC” position. Vehicles with a keyless access with push button start sys- tem: Turn the push-button ignition switch to “ACC” mode.
Depress the brake pedal. Pry the cover up with a flat-head screwdriver or equivalent. Press the shift lock release button. The select lever can be shifted while the button is pressed.
The Following User Says Thank You to Tromatic For This Useful Post:
mav1178 (07-07-2014)
Old 07-05-2014, 08:10 PM   #12
Tromatic
Originally Posted by solo View Post
No, the automatic!
An owner's manual (also called an instruction manual) is an instructional book or booklet that is supplied with almost all technologically advanced consumer products such as vehicles, home appliances and computer peripherals. Information contained in the owner's manual typically includes: Safety instructions; for liability reasons these can be extensive, often including warnings against doing things that no intelligent person would consider doing. Assembly instructions; for products that arrive in pieces for easier shipping. Installation instructions; for productions that need to be installed in a home or workplace. Setup instructions; for devices that keep track of time or which maintain user accessible state. Normal usage instructions. Programming instructions; for microprocessor controlled products such as VCRs, programmable calculators, and synthesizers. Maintenance instructions. Troubleshooting instructions; for when the product does not work as expected. Service locations; for when the product requires repair by a factory authorized technician. Regulatory code compliance information; for example with respect to safety or electromagnetic interference. Product technical specifications. Warranty information; sometimes provided as a separate sheet.
Old 07-06-2014, 03:23 AM   #13
badrad
Drives: like a maniac
Originally Posted by Tromatic View Post
... an emergency measure to ensure that the select lever can be shifted.
As far as I know basically this. I had to use it on another vehicle to get it into neutral when my battery was dead and it wouldn't shift.
badrad is offline   Reply With Quote
Push Button FRS_Sovereign Electronics | Audio | NAV | Infotainment 5 06-13-2013 03:31 AM
SPORT Button Razzle AFRICA 15 06-04-2013 06:48 AM
FS [SYD]: TRD Start Button eleu2166 Australia Classifieds 3 11-04-2012 07:31 AM
Thanks button? TuxedoCartman Off-Topic Lounge [WARNING: NO POLITICS] 17 07-25-2012 04:25 PM
ABS off button? NESW20 Engine, Exhaust, Transmission 21 04-20-2010 11:47 PM
