Old 07-03-2014, 10:34 PM   #1
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
Wrapping Roof - Tips Apprecieated
As the title suggests, in the next week or two I will be wrapping my roof in gloss vinyl.
I have 3M 1080 gloss black vinyl, clay bar, vinyl squeegee, microfiber rags, and a heat gun. I have watched a few DIY's that basically contradict each other. It seems everyone has their own method of wrapping with vinyl. Is there a best practices that trained installers follow?
Anyone that has done this themselves DIY'ers or Professionals please chime in with pointers and tips, as I will be trying this myself rather then farming out to a tint / wrap shop.
My plan of attack is to remove antenna, clay and prep surface of roof, stretch vinyl over whole roof, start in center and work one side down from front to back of roof, repeat on other side, tuck in and clean up edges. Please tell me if I am way off or about to do this backwards, like lubing up after finishing the deed...
I have seen some spray down the roof with water as they position the vinyl, like a tint job, where as i have seen others position and fit vinyl dry... Is one method better than another?
Thanks for any Tips!!
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 07-03-2014, 10:42 PM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Doing so wet will allow more play if you screw up, the water helps temporarly kill the tack allowing you more time to work the vinyl smooth and squeege the buggles/air out.
The Following User Says Thank You to Kiske For This Useful Post:
Danklvr (07-03-2014)
Old 07-03-2014, 10:47 PM   #3
gramicci101
Off Topic
It's best if you remove the roof and wrap it off the car. This will let you make sure you do a proper job on the edges. The roof is attached via bolts under the head liner.
Old 07-03-2014, 11:02 PM   #4
Danklvr
Danklvr's Avatar
I'm not a teenager...The roof is actually spot welded not bolted... Your comment is 100% FAIL.
The Following 2 Users Say Thank You to Danklvr For This Useful Post:
86-tundra (07-03-2014), STS-V (07-04-2014)
Old 07-03-2014, 11:18 PM   #5
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Damn it's this easy huh?
Maybe I'll take my roof off.
Old 07-04-2014, 01:44 AM   #6
Pacific Auto
Master Installer
Pacific Auto's Avatar
Drives: Scion FRS
I am a clear bra installer but I have some vinyl experience.
I have done my roof two different times with 3M 1080 satin black.
Both times I pre-stretched the whole piece dry.
The first time, I started in the center like you said but got some stretch marks at the valleys.
The second time, I did the two outside pieces first. This creates a bridge across the whole center. Then I swipe each valley across using my hand in a micro fiber. Then I finished up the center.
Trimmed and wrapped all edges. Credit cards work great for getting underneath the seals.
Pacific Auto is offline   Reply With Quote
The Following User Says Thank You to Pacific Auto For This Useful Post:
Danklvr (07-04-2014)
Old 07-04-2014, 03:05 AM   #7
Danklvr
Danklvr's Avatar
Thanks @Pacific Audio that's great advice. I'll try starting from the outsides first as you mentioned.
Old 07-05-2014, 11:20 AM   #8
_j_anthony
Daily Driven Expert
_j_anthony's Avatar
Drives: FR-S Monogram(BLACK)
I personal have never had any issues with 3M products but I was told from someone who wraps cars professionally(just won a national award for his work) that Avery is much better, so for next time.
As to tips, watch a lot of youtube first.
- [ame="https://www.youtube.com/watch?v=hCAjIXefdhY"]2011 WRX How to Install a Vinyl Roof Wrap by JDMFanaticVinyls - YouTube[/ame]
- [ame="https://www.youtube.com/watch?v=k9q5bzODc6Y"]2015 Subaru WRX DIY Vinyl Roof Wrap Install - YouTube[/ame]
just because the wrx isn't too far off from the ft86 roof.
_j_anthony is offline   Reply With Quote
The Following User Says Thank You to _j_anthony For This Useful Post:
Danklvr (07-05-2014)
Old 07-06-2014, 12:39 PM   #9
Jcl
Drives: 2014 BRZ
Start in the center like you mentioned and work the vinyl towards the front and back. Try to not 'stretch' the vinyl, because over stretching could cause the vinyl to discolor, what you want to do is work it slowly towards the outer edges and when do you get to the edge use a little bit of heat to de-wrinkle and wrap over the edges. And when you are finished use your heat gun and go over the whole roof to 'kill' the memory from the vinyl.
[ame]http://youtu.be/_QuV3KHu5_w[/ame]
Jcl is offline   Reply With Quote
The Following User Says Thank You to Jcl For This Useful Post:
GNious (05-01-2017)
Old 07-06-2014, 01:01 PM   #10
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Then why does seibon sell a REPLACEMENT roof?
Old 07-06-2014, 01:09 PM   #11
enjoi23
12% Done with the car.
enjoi23's Avatar
Drives: FRS
Do your research, don't just assume things. the replacement roof is a replacement yes, but you have to cut the original roof out and put the new roof in. If it was that easy, I would have done it a long time ago.
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
enjoi23 is offline   Reply With Quote
Old 07-06-2014, 01:24 PM   #12
Reaper
Reaper's Avatar
Drives: violent
im sorry what did I assume by asking a question?
Old 07-06-2014, 01:39 PM   #13
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Ya I think he just assumed that you were the original "just remove it" poster.
After the roof is cut off, the "replacement" is epoxied (specialized epoxy) back on to the roof line.
The Following User Says Thank You to boredom.is.me For This Useful Post:
Reaper (07-06-2014)
Old 07-06-2014, 02:18 PM   #14
Danklvr
Danklvr's Avatar
well... my first attempt laying the vinyl dry did not fare so well... even with 2 people we couldn't get it to lay flat enough, i had way too many wrinkles and after about 30 minutes fighting with the vinyl i gave up and waxed the roof's freshly clayed surface and put the antenna back on.
All the tips and videos are a great help and i think i will try this one more time on my own. Next time i think i will try laying the vinyl down over a soapy water solution rather than trying to fit it dry.
*Groupbuy: Invidia N1 and Q300 Cat-Back Exhausts (SS tips, T.I. tips) -fteightysix* 86SPEED Groupbuys 74 11-09-2016 01:45 PM
Vinyl Wrapping Lawnik DIY (Do-It-Yourself) Guides 57 12-10-2013 11:23 PM
Wrapping The Car: Which color? xravexboix Cosmetic Modification (Interior/Exterior/Lighting) 23 01-22-2013 01:25 PM
