Old 07-03-2014, 12:54 PM   #1933
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
250 is beyond blown head gasket temps. Anything north of 215 is scary land. 220-225 is where the gaskets give out for sure. If the block is 250 there is no coolant in it (air locked?) or the coolant is not moving. On our blocks we install 250deg plugs. If it gets that hot, we know.
Infamous Performance is offline   Reply With Quote
Old 07-03-2014, 12:57 PM   #1934
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I like that idea. Where did you get those?
The Following 2 Users Say Thank You to Reaper For This Useful Post:
SmsAlSuwaidi (07-03-2014), Sportsguy83 (07-03-2014)
Old 07-04-2014, 01:16 AM   #1935
Outfront Motorsports.
Old 07-04-2014, 01:17 AM   #1936
pleong
Drives: 2013 Whiteout FR-S
Anyone have the oil cooler? My socket walls are too fat for that bolt that bolts down the spacer and sandwich plate
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 07-04-2014, 01:28 AM   #1937
PolishFrs13
building life
PolishFrs13's Avatar
Drives: Raven Black, 6MT
what's a good clutch to go with for a daily driver at about 350hp?
Sent from somewhere
PolishFrs13 is offline   Reply With Quote
Old 07-04-2014, 01:53 AM   #1938
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Are these coolant or oil temps?
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 07-04-2014, 07:00 AM   #1939
Boba_kz
Oil temp. 250 or water temp 250?
Just cruising around, tracking, driving it hard?
Water temp via Torque
Tracking
Boba_kz is offline   Reply With Quote
Old 07-04-2014, 07:01 AM   #1940
Boba_kz
Originally Posted by Dipstik-sportech View Post
Are u idling it for 4hr straight or something? Did u bleed the system? Are the fans coming on? 250° is damn near head gasket failure temps
Tracking
Yes we bleed the system
Fans are working
Old 07-04-2014, 07:02 AM   #1941
Boba_kz
Will try to use Motul MoCOOL.
Old 07-04-2014, 07:03 AM   #1942
Boba_kz
Coolant
Old 07-04-2014, 08:14 AM   #1943
Dipstik-sportech
Dipstik-sportech's Avatar
Do you have any of the exhaust wrapped or a turbo blanket? If you're tracking you may need to go to a vented hood
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Boba_kz (07-04-2014)
Old 07-04-2014, 08:59 AM   #1944
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Tracking
Really scary...
There have to be air bubbles in the system or something... 250 water is extreme.
Old 07-04-2014, 09:20 AM   #1945
M1K3
M1K3's Avatar
Drives: vrooom...
If it's not air in the system it might be a pinched coolant line or thermostat not opening all the way. You can try testing your thermostat or if this is a strict track vehicle the next time you track the car try running it without the thermostat and see what kind of temps you get.
M1K3 is offline   Reply With Quote
The Following User Says Thank You to M1K3 For This Useful Post:
Old 07-04-2014, 09:21 AM   #1946
Dipstik-sportech
I'm wondering if you cooked a headgasket and under boost it's pushing coolant causing air to get in the system. My buddy's celica did that exact thing, it would be fine driving normal and slow but when he would get three laps on the track under boost it would boil over.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
