Old 05-20-2013, 04:24 PM   #15
paperboy42190
Drives: 2007 Acura TL Type-S
Nice DIY but in the OP, the camber plate top hat is installed in a wrong orientation
paperboy42190 is offline   Reply With Quote
Old 08-20-2013, 01:01 PM   #16
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
How's the suspension holding up on the track?
Anthonytpt is offline   Reply With Quote
Old 08-20-2013, 02:30 PM   #17
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Great DIY! if i decide to drop my car, this will be very helpful
Old 11-18-2013, 11:51 PM   #18
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
<<<CORRECTIONS NEEDED>>>
Originally Posted by GrimmSpeed View Post
Begin by disconnecting the swaybar endlink from the strut assembly. This will require a 14mm socket and you値l make the job easier for yourself with an extension. If you find that the end link is spinning with your ratchet, you値l need to us a 14mm wrench with an allen wrench to keep the stud from spinning. Remove this on both sides at once to release any tension in the swaybar.
^^^^^ INCORRECT: this is a 17mm nut and requires 17mm socket/wrench.
The only thing holding the strut in place are the nuts on the top of the strut. Loosen these all with a 14mm socket before moving forward. If you池e by yourself, you値l want to hold the strut with one hand while you loosen the nuts the rest of the way with the other. If you池e with a friend, have him/her hold the strut for you while you remove the three nuts. Remove the strut assembly from the vehicle and set it safely aside.
^^^^^ INCORRECT: this is a 12mm nut and requires 12mm socket/wrench.
Please fix @GrimmSpeed
-alex
Old 12-08-2013, 10:13 PM   #19
Mo707
Mo707's Avatar
Anyone else had any trouble with the end links? not sure if i went full retarded but i was having the hardest time putting it back together when i did my springs...
Mo707 is offline   Reply With Quote
Old 02-11-2014, 09:47 PM   #20
flashburn
Drives: 2014 Subaru BRZ Limited 6MT
Great DIY.
About how long should I expect this to take, on average?
flashburn is offline   Reply With Quote
Old 02-11-2014, 10:11 PM   #21
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
If you've never done this before and you're attempting this on your own, give yourself at least 3-4 hours. This way you're not in a hurry and you can triple check everything, and still have enough time to adjust/set your coilovers to your liking.
Optional: you may want to take the car for a quick 5-10 min drive before setting your final ride height. I'm anal about getting the ride height perfect (to within 1mm) all around so what I do is adjust height, drive, adjust height, drive, and adjust again if necessary
Fizz is offline   Reply With Quote
Old 02-12-2014, 07:50 AM   #22
flashburn
Cool, thanks. If I do coilovers I'll give myself 6 hours then. Slow and steady wins the race.
Old 04-25-2014, 10:26 AM   #23
ecdragon
Drives: 2013 FR-S, 2014 Monogram FR-S
"25. Now, we’ll get our rear coilovers setup for installation. It’s a similar process to that of the front. This is how we set ours. Of course, you’ll be able to make final adjustments once the coilovers are installed. Remember to make sure everything is snug, or you’ll be hearing terrible noises. Take note that the rear coilovers are also unique for each side, so pay attention!"
How do i distinguish Left from Right? i only difference i see is the top piece/mount has a fatter/wider side, and a slim/thin side. should the fat side be on the inside of the car or outside of the car?
any help is appreciated, thanks!
ecdragon is offline   Reply With Quote
Old 05-10-2014, 06:24 PM   #24
GA_Dave
Drives: 2014 Dark Gray Metallic BRZ Limited
I used this today as a guide while installing my BC coilovers. Just a note, the OEM rear shocks are MUCH MUCH easier to remove if you loosen the bolt that holds the endlink into the lower control arm. This keeps the "walls" of the control arm from gripping the lower end of the shock so tightly.
GA_Dave is offline   Reply With Quote
Old 05-31-2014, 01:17 PM   #25
Wilso
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
Do your swaybar links not make a creaking sound using the stock links? I use the stock links and I get a pretty loud creaking noise from the front when I turn left/right. Was told it could be because the stock links are too long. Any ideas?
Wilso is offline   Reply With Quote
Old 05-31-2014, 08:24 PM   #26
PNW FRS
PNW FRS's Avatar
Removing Rear Struts
Great write-up... used this as a generic guide... installing my new Speed by Design Pro Street Coilovers. When it came time to remove the rear OEM struts, we had to also disconnect the rear sway bar in order to get enough "slack" to remove. And, even with that little bit of extra play, it was a bear.
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 06-25-2014, 09:49 PM   #27
HyperTech
HyperTech's Avatar
Drives: Mazda3 2013 / Scion FR-S 2015
click thanks by mistake.
anyway, you have to raise the opposite side to make them even to not have to went full retard to put it back on.
HyperTech is offline   Reply With Quote
Old 07-03-2014, 06:38 PM   #28
Jaylyons1
Jaylyons1's Avatar
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
Originally Posted by ecdragon View Post
"25. Now, we値l get our rear coilovers setup for installation. It痴 a similar process to that of the front. This is how we set ours. Of course, you値l be able to make final adjustments once the coilovers are installed. Remember to make sure everything is snug, or you値l be hearing terrible noises. Take note that the rear coilovers are also unique for each side, so pay attention!"
Did this ever get answered or did I miss it? Not trying to install them on the wrong side.
Jaylyons1 is offline   Reply With Quote
DG-5 Coilover harajukukei Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-27-2014 03:42 PM
NW Coilover Shootout DarrenDriven Northwest 14 07-24-2012 02:12 AM
Suspension Installation Warning!!!! Don@Accelerated Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 07-20-2012 06:44 PM
TRD parts installation manual Nardi330 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 05-21-2012 03:19 AM
