Old 07-03-2014, 01:52 PM   #43
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Originally Posted by SkAsphalt View Post
Someone just NEEDED to go faster lol. 400 was not enough? Damn your car has certainly changed, but it is still one of my favorites. Colour matched TRD fins look great!
Nah, time to go higher lol. No point in keeping it low with the new block. Doing the block for reliability reasons
The Following User Says Thank You to spitfire481 For This Useful Post:
SkAsphalt (07-03-2014)
Old 07-03-2014, 02:10 PM   #44
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
This build is silky smooth!
Old 07-03-2014, 02:34 PM   #45
Roxy86
Roxy86's Avatar
Drives: Diesel daily / FR-S
399whp wasn't enough eh?
Roxy86 is offline   Reply With Quote
Old 07-03-2014, 02:48 PM   #46
spitfire481
Drives: 2JZ FRS
Never enough! Might as well put the new block to use
Old 07-06-2014, 03:44 PM   #47
Herndon
Herndon's Avatar
Drives: 2014 SWP BRZ
what was the setup when you put down the 399whp?
Herndon is offline   Reply With Quote
Old 07-07-2014, 01:51 AM   #48
solus
Drives: 2014 Scion FRS (Ultramarine)
IS you TRD kit real TRD or PU replica? If replica where did you order it from?
solus is offline   Reply With Quote
Old 07-07-2014, 11:27 PM   #49
spitfire481
Drives: 2JZ FRS
Avo base kit
Dw700 injectors
Avo 8psi wastegate actuator
Boost solenoid controlled with ecutek
K&N drop in filter
Avo 2.5" overpipe
Tanabe catless front pipe 2.5"
Perrin 2.5" non res cat back
Dw65 fuel pump
Flex fuel, dyno at e81
Spec 2+ clutch
The Following 4 Users Say Thank You to spitfire481 For This Useful Post:
Herndon (07-08-2014), kanundrum (07-07-2014), RiderFromLao (04-09-2016), yourboyvic (12-09-2018)
Old 07-07-2014, 11:29 PM   #50
spitfire481
Drives: 2JZ FRS
TRD front/sides and sti style rear spats are reps from Bayson R. I had zero issues and this is coming from someone who does body/paint for a living. The TRD fender aero trim are oem
hmong337 (03-20-2015)
Old 07-23-2014, 08:31 PM   #51
spitfire481
Drives: 2JZ FRS
Turbo kit, radiator with fans and shroud, down pipe wrap is here. Stock motor is at full blown and heads are being installed on the built short block. Doing fererra valve springs and retainers as well now. Maybe shipping before the end of the week/early next. Clutch masters fx725 twin disk clutch is ordered and being built by CM currently
SkAsphalt (08-14-2014)
Old 07-23-2014, 08:32 PM   #52
spitfire481
Drives: 2JZ FRS
Also my avo setup with upgrades and my spec 2+ clutch is for sale. Should be removed within the next month and ready to go
ftc~brz (07-30-2014)
Old 07-29-2014, 06:18 PM   #53
spitfire481
Drives: 2JZ FRS
Just waiting for the motor to get back now
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
ftc~brz (07-30-2014), IBill4You (06-26-2015)
Old 07-30-2014, 07:47 AM   #54
M1K3
M1K3's Avatar
Drives: vrooom...
Oooo Shiny and New... I call shot gun!
M1K3 is offline   Reply With Quote
Old 07-30-2014, 12:11 PM   #55
ftc~brz
Done
Drives: WRB BRZ
fapfapfap to that gray counter
ftc~brz is offline   Reply With Quote
Old 08-14-2014, 01:06 AM   #56
forwallblakmail
Troll Level: Expert
forwallblakmail's Avatar
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
got these in last week. resistored the airbags, transferred the weight sensor from the factory passenger seat into the recaro. no warning lights ftw
Did you have to destroy the stock passenger seat to get the sensor out? Car looks great by the way
Nick K.
NASA ST5/TT5 #130
Southeast Region
forwallblakmail is offline   Reply With Quote
God's Build GodSays Member's Car Journals 13 04-17-2013 01:31 PM
My build... well some of it cruzinbill Electronics | Audio | NAV | Infotainment 41 04-01-2013 04:02 PM
STX build Evil86 Tracking / Autocross / HPDE / Drifting 2 01-08-2013 03:40 PM
My BRZ build brztj Mid-Atlantic 3 09-08-2012 05:52 PM
