Old 07-01-2014, 05:00 PM   #15
JasperNoone
Drives: Car
For how much we obsess about balance, the Mustang has a better F/R weight distribution according to these numbers. And that's the V8...
BRZ: 55.3/44.7
Mustang GT: 54.7/45.3
BRZ with LS swap will be closer to 50/50 than it is from the factory.
JasperNoone is offline   Reply With Quote
Old 07-01-2014, 05:06 PM   #16
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
It's actually around 56/44
http://www.ft86club.com/forums/showthread.php?p=1025230
ineedyourdiddly
Old 07-01-2014, 05:14 PM   #17
JasperNoone
Drives: Car
Not the particular swap I was thinking of, hm..
Even so, 1% further forward weight distribution < ~230whp you pick up swapping to a real engine. I will concede that my original statement has no support at this time and could very well be wrong until I find the gd picture I'm looking for.
Old 07-01-2014, 06:15 PM   #18
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Originally Posted by totopo View Post
Less weight in back means you can accelerate earlier at corner exit.
Really? That does not jibe with comments of drivers/broadcasters that I watch in the IMSA and Pirelli World Challenge Series races where they claim that the Porsche 911's massive advantage in the corners is its ability to accelerate better out of the corners due to the weight over the rear wheels. I am not arguing. I just seek enlightenment.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
The Following 2 Users Say Thank You to Rampage For This Useful Post:
chas3wba0 (07-01-2014), strat61caster (07-01-2014)
Old 07-01-2014, 06:20 PM   #19
chas3wba0
chas3wba0's Avatar
Drives: Yes
Originally Posted by DarkSunrise View Post
The difference in COG, roll-center heights, anti-dive, etc. is enough to remind me of why I bought this car...
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 07-01-2014, 11:25 PM   #20
totopo
Drives: 370z
I hear people say this all the time too... I wish i had real data or something.
So the reason why RR and MR cars neutral oversteer is because they run out of traction in the rear first. And FF cars understeer because they run out of traction in the front first. The reason for that is those tires have to move more weight. Because the extra traction from the normal force of the weight is less than the extra force needed to accelerate that mass sideways.
So when you are accelerating at corner exit after apex, you are still asking your rear wheels to turn. Because the rear wheels are helping w lateral acceleration, a rear tire on a FR car will have more available traction for accelerating than a rear tire on an MR car, which has more mass to accelerate sideways.
My suspicion why porsches accelerate better out of corners is because of it's completely 100% terrible, no-benefit RR design, it probably gets tons of bonus points in the "Balance of Performance" to make it competitive, so they probably have more hp/weight than the other cars.
totopo is offline   Reply With Quote
Old 07-02-2014, 08:57 AM   #21
DarkSunrise
DarkSunrise's Avatar
I've been wondering the same thing and as I fantasize about getting another sports car the MR2 is a strong contender, both the MK1 and MK2 are roughly 45/55, it seems like for less than the cost of a Toyobaru you can get similar straight line performance and the advantage of the MR through the twisties.
A few track guys I met have MR2s from that era. They seem to love them, although apparently those cars aren't very forgiving when pushed. From what I've heard, those cars can be a handful with no ABS and the tendency to transition from moderate understeer to snap oversteer under power. I bet they'd be a lot of fun to master though.
I feel like this is very dependent on suspension and tire setup. For example, a lot of the guys I talk to at the track who drive MR cars (MR2, NSX, Elise, Cayman/Boxster, etc.) complain about neutral understeer. But that's probably more a function of OEM-engineered understeer (staggered tires and softer rear roll stiffness) than engine layout.
And on the other end, you see a lot of serious autocross guys tune FF layout cars to rotate/neutral oversteer, through thick rear swaybars and stiff rear suspension.
With all those variables at play, it's hard to isolate what the engine layout is actually doing for handling balance IMO. Not saying you're right or wrong, just difficult to see in the real world.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
strat61caster (07-02-2014)
Old 07-02-2014, 10:14 AM   #22
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Had a mk1 mr2 I built for local rally. Traded that car 10 years ago and still miss it. Car was scary fast in the dirt and had to be driven with your brain turned up to 11.
The Following User Says Thank You to Reaper For This Useful Post:
Old 07-02-2014, 12:12 PM   #23
strat61caster
No professional GT class I can find has any 'bonus points' and European Le Mans only has a minimum weight and maximum displacement, Porsche won championships in 2012 and 2010 against Ferrari, Chevy, Audi, Ford, Aston Martin, and many others I don't know because I don't watch, it was the first series I could find rules for.
http://www.europeanlemansseries.com/..._reglement.php
A rear bias car is unstable, in simple terms that means it responds very quickly but at the risk of going out of control. It rotates very easily from a simple rigid body dynamics perspective taking into account wheelbase, mass properties, basic slip equations and steering angle. Your supposition of available grip based on normal grip and lateral force from cornering is pretty good but by understanding the basics of how the vehicle wants to or doesn't want to move you can quantify the advantages and disadvantages of mass placement.
Rear weight bias got it's wicked reputation in the 50's and 60's (James Dean certainly didn't help) but in the 60+ years since has continued to be successful from a performance standpoint. Look at just about any modern supercar and they all have a noticeable rear weight bias (>45/55).
From wiki:
http://en.wikipedia.org/wiki/Car_han...Center_of_mass
If that doesn't win you over to at least respecting a rear weight bias car all I can do is suggest a couple years calculus and a vehicle dynamics course, worked for me.
ineedyourdiddly
Old 07-02-2014, 01:45 PM   #24
totopo
Drives: 370z
From wiki:
I may respond more later. I didn't say bad things about rear bias, but rear engine. No reason to put the engine behind the rear axle. Re-read that page you posted, the air restrictor size is based on engine placement. I bet the rear engine Porsches get larger restrictors.
They apparently also now use fia gt3 homologation. I can't seem to find specific specs, but the fia gt3 are not all equal, they have some weird "balance of performance" crap to try to make the cars performance more equal.
I think the big benefit with mr over fmr is weight, why most super supercars are mr. But the supercar busting gtr is fmawd and the zr1 is fr or fmr. I really am curious if with equal weight and equal hp at the tires (Mr has less drivetrain loss) if fmr or mr is faster
Old 07-02-2014, 01:51 PM   #25
totopo
Drives: 370z
Yes , you can force a car to be more or less over/understeer, but you loose overall traction. You have a set amount of weight shift to distribute, and the more equal it is between front and rear the more lateral traction you can develop. You can seriously skew it one way, like ff cars that pick up the inside rear, but that decreases overall lateral traction. Sometimes it is worth it though, like in those ff cars where the better slip angles and more traction in the front for accelerating out of corners is worth the loss of pure lateral traction.
Old 07-02-2014, 01:54 PM   #26
frsvr4
Drives: '13 FRS
Those lift numbers are really interesting. I wonder how much down force the stock spoilers generate @ 70 mph. Given the weight of the car, those lift forces seem negligible.
It looks like you could manipulate the lift equation to find an approximate lift coefficient and planform area... then you could approximate the f/r lift at higher speeds.
Thanks for sharing!!
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135
frsvr4 is offline   Reply With Quote
Old 07-02-2014, 02:04 PM   #27
strat61caster
Sorry, I misread "100% terrible" as being against engine behind driver as opposed to engine in front of driver, don't care much for 'FMR' technicalities. I am missing the 'air restrictor' as it relates to engine placement, care to point that out? I see a weight and configuration mention which generally corresponds to piston number and arrangement (6-8-10-12, I-V-H) which very well may give the flat 6 a level shot against a V12 of the same displacement.
Page 7 of this allows for a -5% hit to a cars horsepower, +30kg ballast or -10L fuel capacity at the regulators discretion:
http://www.europeanlemansseries.com/...V11_140514.pdf
Racing aside the discussion is on weight distribution, as I said, if my post didn't convince you all I can do is recommend some calculus and dynamics courses.
ineedyourdiddly
Old 07-02-2014, 03:13 PM   #28
Skurge
Drives: 84 RX-7/13' FR-S
For going around a track and trying to nail down a great time? Definitely, there's power in being able to swing the back end around a corner and have the traction to seriously power out of a corner, for all the shit Porsche gets it's been effective for over 50 years at many levels of racing. Most of the major supercars in the last 10 or so years have been around there or even more rear weight biased.
traction, traction, traction...i agree
1984 RX-7 GSL
2013 FR-S
Skurge is offline   Reply With Quote
The Following User Says Thank You to Skurge For This Useful Post:
install cruise control coz for me roll connector / steering sensor fail aagun Issues | Warranty | Recalls / TSB 15 11-14-2013 09:29 AM
Gearbox Stiffness? pevangelista Issues | Warranty | Recalls / TSB 3 05-08-2013 01:00 AM
Roll stiffness: Springs vs anti-roll bars? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 07-24-2012 05:44 PM
Steering wheel stiffness? j4m35ly Scion FR-S / Toyota 86 GT86 General Forum 6 06-20-2012 02:51 PM
Dealership to Dyno: Our FR-S gets measured Arsenal Autosport Engine, Exhaust, Transmission 21 05-30-2012 06:55 PM
