Old 07-01-2014, 12:37 PM   #1
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
Rear axle click when entering the car?
For about a month I have noticed a clicking sound (almost like a torque wrench click) when entering or exiting the car. I dont think its a broken axle because there is no clicking when I accelerate or brake. I have had no modification but I have done 3 track days.
any ideas?
kurbkilla is offline   Reply With Quote
Old 07-01-2014, 01:19 PM   #2
aakash
Drives: Asphalt FRS
I have an auto FRS (13'), I noticed the same sometimes when I put up my e-brake and exit the car. it could be coming from the part of the rotor that touches the e-brake mechanism, in this case It could be rubbing or something when the car slightly moves when entering or exiting. I weigh about 200 pounds, Iv had my mother try to replicate the sound when exiting the car (I think she weighs in around 100-130 lbs) who knows? and it never makes a sound. I have never heard it when the e-brake is all the way down.
Iv never really thought too much of it, even when my e-brake is half way up or like 75% up, no sound. only when its fully engaged. (meaning the lever is pulled all the way up) and even then, it only happens sometimes...
I have never "ripped" my e-brake to drift, only if im on a hill or trying to look cool while stationary.
aakash is offline   Reply With Quote
Old 07-01-2014, 01:35 PM   #3
sluflyer06
Drives: 2014 BRZ Ltd - DGM
Most cars I've been in make noise when you get in if the ebrake is 'on'. Some cars are louder than others, some times its a groan or a creak or in some cars you can hear the e-brake cable stretch as the suspension compresses.
Its normal.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
The Following User Says Thank You to sluflyer06 For This Useful Post:
kurbkilla (07-01-2014)
Old 07-01-2014, 01:42 PM   #4
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
This noise is coming from the E-Brake.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
The Following User Says Thank You to Tt3Sheppard For This Useful Post:
Old 07-01-2014, 01:59 PM   #5
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
This is the passenger counter. It makes sure you do not try to carry more than 4 passengers (including driver). If you do, you will be charged double occupancy and it will charge you for that porno that you "accidentally ordered".
Old 07-01-2014, 02:08 PM   #6
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I get that click when I put it into reverse for the first time in the morning.
Last year I did have a drivers side axle replaced under warranty. At that time it was doing in acceleration and deceleration.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 07-01-2014, 02:22 PM   #7
aakash
Drives: Asphalt FRS
You notice a new clicking sound since your previous axle was replaced? how noticeable is it? do you need to have the windows down and music off to hear it? or is it noticeable all the time for cold starts?
Old 07-01-2014, 02:59 PM   #8
kurbkilla
kurbkilla's Avatar
Thanks all for the replies. I try leaving it in gear as opposed to using the e-brake. I'll update later.
Old 07-01-2014, 04:33 PM   #9
feldy
feldy's Avatar
I always hear it. My car is in the garage so its really easy to hear. Its always had a little clank if you will when putting it into reverse. Its the same sound as when the axle broke. Did it before the axle and with the new one. So Im not worried. Its when I take off from a stop sign and hear it then I will be worried.
Old 07-01-2014, 05:32 PM   #10
johnnyfast11
Drives: none yet
try looking underneath the car and turning the wheels?
johnnyfast11 is offline   Reply With Quote
Old 07-01-2014, 08:38 PM   #11
aakash
Drives: Asphalt FRS
My car sits in a garage too, I think this is normal
Rear driver side clank and click spyingwind Issues | Warranty | Recalls / TSB 11 04-04-2014 11:26 PM
click, clank click sounds when cooling down and more? leaking oil? Boofneenee Issues | Warranty | Recalls / TSB 19 10-02-2013 11:27 AM
Click sound from left rear Tt3Sheppard Issues | Warranty | Recalls / TSB 1 09-25-2013 05:58 PM
Picture of the BRZ entering the Eisenhower Tunnel 6/15/13 mav1178 BRZ First-Gen (2012+) — General Topics 10 06-24-2013 03:49 PM
