Old 06-29-2014, 07:37 PM   #4901
evan
Drives: fr-s
That reflect-a-gold looks PIMP (Professional Intake Management Procedure).
evan is offline   Reply With Quote
Old 06-29-2014, 08:20 PM   #4902
xjohnx
Grip>Slip
xjohnx's Avatar
haha, i'm not a huge fan of it. i need to contact nameless about one of their replacements to see how that works, and if i can't find someone to fab up a heat shield, then i'm gonna work on figuring it out myself.
Old 06-29-2014, 08:28 PM   #4903
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Originally Posted by Kodename47 View Post
AFAIK the 210+ is the 210 but with a coating on the screws allowing for more compression per RPM.
Correct, Also the coating allows for a higher rpm ceiling as well, higher boost pulleys can be run on it. The Sprintex R&D car is running 14PSI currently, it's a great drive
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 06-29-2014, 09:02 PM   #4904
xjohnx
Grip>Slip
xjohnx's Avatar
Will the 210 be upgradeable or will we have to buy a whole new SC unit?
Old 06-29-2014, 09:23 PM   #4905
evan
Drives: fr-s
Based on calls I've made about this and my own research on swapping out the 210 for the 335, only the drive snout and the rear elbow needs to be pulled off once the blower has been unbolted from the manifold. I would imagine that with the 210+ likely being the same dimensions as the 210, this should also be a simple swap. Now, what innovate and/or sprintex decide from a business perspective, I don't know.
Old 06-29-2014, 09:48 PM   #4906
Basket Case
Drives: 2013 Raven fr-s
I have tried finding a real answer, but with 200+ pages and google coming up with no results, I figured I would just ask.
How is the Innovate intercooled kit for hot climates both tracking and daily driving? I haven't tracked the car yet but plan on it. I live in sunny southwest Florida, and let me tell you, it gets hot here in the summer. My car is a daily driver and since I am a sales rep, I drive a ton. I like the idea of this kit, but I keep feeling like it will heat soak. Opinions?
Basket Case is offline   Reply With Quote
Old 06-29-2014, 10:36 PM   #4907
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
If you want, I can take a look at your engine bay and come up with something. I love working with metal.
Get an oil cooler. If you have a header, keep the hot air from getting to the intake pipe.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 06-29-2014, 10:49 PM   #4908
xjohnx
Grip>Slip
xjohnx's Avatar
Let's do it.
Old 06-30-2014, 05:05 AM   #4909
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Judging from the conversations I've had with Mark from Sprintex it we will have to replace the whole S/C hub, louvers, gears, pulley and casing
But that's sprintex, what Innovate decide to do for the US market is beyond me.
Build thread
Old 06-30-2014, 08:44 AM   #4910
Basket Case
I know Ian oil cooler is a must for any FI application. What I am more concerned with is the water/air intercooler heat soaking either in traffic or after a few laps on a track in the he florida heat causing the IAT's to raise significantly and cause detonation. Every review I read are from people loving up north complaining about 80's being hot, lol...
Old 06-30-2014, 08:53 AM   #4911
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Delicious has said that the IC is pretty much essential for hot climates. The way I see it, no matter how hot the IC system gets, it'll still be cooler than what's coming out of those screws.
Old 06-30-2014, 09:45 AM   #4912
evan
Drives: fr-s
That's interesting. None of it makes any sense. Not calling you out, just interesting that they would tell you that. I've spoken to a few sources and the swap, outside of the official channels, with the 335 for example is supposed to be a simple affair.
What really makes me doubt their answer is why the pulley has to be replaced. No logic to that at all. The Sprintex pulleys are interchangeable, even amongst different applications. That is how I found a 64mm pulley, at the smallest.
Old 06-30-2014, 10:16 AM   #4913
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Let's do it.
I'm heading out of town this weekend, how about the following weekend after C&C?
Parting out HERE
Old 06-30-2014, 11:12 AM   #4914
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Not sure how it doesn't make sense since i described the bit outlined in red in the below picture, all the parts mentioned are contained within the supercharger itself. I did mean Pulley hub not the pulley itself my mistake.
Basically that's how Sprintex will be selling the upgrade to the customer as a complete unit, unbolt the old 210 from the manifold and elbow at the back and slap on the 210+ total cost $2100 Australian, the pricing for it is on their website.
Like i said no idea how innovate would handle the upgrade to you in the USA as this only reflects buying from Sprintex directly.
http://www.sprintex.com.au/wp-conten...013_Page_1.jpg
Build thread
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
