Old 06-24-2014, 08:26 PM   #85
zuko
Drives: 2014 Limited WRB BRZ
Not sure how similar this is to what everyone else is experiencing, but here's 2 short videos I took of a rattle I've been having in the ~dash area. At first I thought it was that the speaker wasn't level, because I was able to push it down and have it click, but driving around with it depressed doesn't solve the issue. In fact, it sounds as if it's inside the dash more than anything...
You might need earbuds to hear it, was taken on an iphone. The rattle can be anywhere from slightly noticeable to pretty significant (can hear it over the radio) depending on the road (or how the car feels that day apparently).
[ame]http://youtu.be/9SX5UPjXl6g[/ame]
(second is still processing)
Also, sitting at a light this morning it was rattling the whole time, which leads me to believe it's not necessarily related to rough roads. Perhaps there's something bouncing around inside? The inconsistency of the rattle also lends itself to that theory, where that piece or whatever it is sometimes finds a resting place where it can't move around as easily.
Anybody seen/heard anything like this?
zuko is offline   Reply With Quote
Old 06-28-2014, 01:08 PM   #86
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Originally Posted by Gary in NJ View Post
Yup, that's the noise. I see that you were driving around 78-80 mph...I don't notice it unless I'm over 70 and it's most likely to happen on concrete roads rather then black top.
Like you, I'm not likely to try accelerator isolation fix until it's warmer out. It's 16F as I type this.
Ahhh mine came back too. Maybe the climate reflects the noise? So far I think we can rule out:
-Felt unlikely the solution
-Does not involve doors
-Does not involve gauge cluster
I still have a feeling it's the speakers... I can create the sound by letting off the gas around 65-70mph.
Old 06-28-2014, 01:21 PM   #87
BRZnut
Drives: BRZ DGM Limited
Make sure you check the lower pillar where the drivers side seat belt attaches to (the plastic below it). That was one for me
Old 06-29-2014, 01:14 PM   #88
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
Padded the blue circled area with some 3m tape and foam. Reduced some metal to plastic panel noises.
The rattle noise sounds like it is coming from the steering column in red highlighted area. Sometimes the rattle is barely noticeable but the past couple days it's really bad over minor bumps/imperfections on the road.
God help me.
sprintertrueno86 is offline   Reply With Quote
Old 06-29-2014, 08:42 PM   #89
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
I agree, I heard it mostly during night time driving.
Anyone brought theirs to the dealership yet to get it fixed ?
Thanks
ucsmfu is offline   Reply With Quote
Old 07-01-2014, 07:35 PM   #90
Ethan
Drives: Subaru BRZ
I have the same intermittent buzzing sound as recorded by Prog and Odd. The car is at the dealership now and I'll let everyone know what they find. So far, several hours has been spent on it to no avail.
Ethan is offline   Reply With Quote
Old 07-03-2014, 01:39 AM   #91
Ethan
Drives: Subaru BRZ
Update: I had the same buzzing sound as Prog and Odd. good news, bad news. My dealership fixed it (knock on wood) but they do not know how. They took a bunch of parts off the around the drivers side dash and under the instrument panel but could not get the buzzing to stop. They put the pieces all back on and POOF, it does not make the sound anymore. So my best guess is the buzzing is coming from something to which the dash or parts under the dash attach.
The Following User Says Thank You to Ethan For This Useful Post:
the new guy (07-03-2014)
Old 07-05-2014, 12:40 AM   #92
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
anymore details ? was it wiring ? or the panels ?
Old 07-05-2014, 04:24 PM   #93
Ethan
Drives: Subaru BRZ
According to the dealership, "we have no idea what it was." But that is a bit of an overstatement. They took off a bunch of dash parts and parts under the instrument panel (exactly what parts, I do not know) and the sounds did not stop. But when they put the parts back on, it stopped. So, I infer that it had to have been something to which the parts they removed had attached to.
Old 07-05-2014, 06:04 PM   #94
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
do you know the exact parts that they removed ?
thanks
Old 07-06-2014, 11:23 PM   #95
Ihartc4
Ihartc4's Avatar
Drives: Series 10 FRS
I've got the same sound as Prog. It's getting worse, particularly on the ludicrously noisy I-5 south of Seattle.
I'll be taking it in to the dealer, does anyone know a good one that won't give me the runaround around Tacoma of Olympia?
Thanks
Ihartc4 is offline   Reply With Quote
Old 07-07-2014, 09:05 PM   #96
Turbo95eg6
Turbo95eg6's Avatar
My money is that it will come back.
Old 07-11-2014, 12:03 AM   #97
Ethan
Drives: Subaru BRZ
It did. But not as frequent now. I presume it will get worse.
Old 07-12-2014, 01:40 PM   #98
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
so tired of the buzzing noise
The Following User Says Thank You to ucsmfu For This Useful Post:
initialrt (07-12-2014)
Light buzzing sound from driver-side dash BRZprime Issues | Warranty | Recalls / TSB 51 08-21-2015 09:34 PM
Driver Side Window Rattle RiceCooker Issues | Warranty | Recalls / TSB 23 08-18-2015 10:20 AM
Rattle from driver's side door lock. Mandy Issues | Warranty | Recalls / TSB 0 07-10-2013 08:44 PM
BRZ Driver side mirror rattle with stock speakers slawdio Issues | Warranty | Recalls / TSB 2 07-01-2013 12:23 PM
Driver Side Speaker Housing Rattle Lefty Scion FR-S / Toyota 86 GT86 General Forum 2 06-12-2012 10:32 AM
