Old 06-27-2014, 09:58 PM   #1891
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
@Reaper would a proper setup be a dual catch can setup like the radium cans and a check valve located between the pcv can and the intake manifold? With the breather can connected before the turbo intake?
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 06-27-2014, 10:06 PM   #1892
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
We need to back up a second here. There are two ways to deal with this; you can vent to atmosphere (I prefer this and use the fullblown can) which will run the breather and the pcv line into one can with a filter/vent on top. NO PCV VALVE.
Or you can run a system that vents back into the motor. Crawford and a few others make a system like that. Youll need an upgraded pcv valve for this as this style uses vacuum from the intake to vapors from the crankcase. When under boost you are trying to force air INTO THE CRANKCASE that's bad and why you need a pcv valve specifically made for boost. This system also reburns all the vapor. Which means the can doesn't need to be drained much if at all. I'm on e85 which sucks up water so I want all that vapor out and into a vent to atmosphere can and not back into my combustion chamber. That's another reason I went vta and used the fullblown can.
The Following 2 Users Say Thank You to Reaper For This Useful Post:
Dipstik-sportech (06-27-2014), FullBlown (06-27-2014)
Old 06-27-2014, 11:22 PM   #1893
Reaper
Reaper's Avatar
Drives: violent
You dont want anything before your turbo or you will fill your intercooler with oil if you do it wrong.
Old 06-28-2014, 10:03 AM   #1894
blackfireball5
If i run a vented can, will I have a problem passing strict emissions? Ohio is very strict which is why I've been opting for a closed setup.
I was at the track a few days ago and someone had a boosted frs with a different kit. But the concept should still be the same. You can see where the breather tube can connects in front of the turbo. You are saying this is incorrect?
Wheelwell Profile
Old 06-28-2014, 10:37 AM   #1895
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
You can re-route back to the intake tract before the turbo, just make sure you have a proper can and the lines are run correctly. If they're not, you may as well not even have a catch can.
A boost specific PCV valve isn't necessary if you install a 1 way check valve between the catch can and intake manifold.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
blackfireball5 (06-28-2014)
Old 06-28-2014, 11:07 AM   #1896
mike the snake
I'm running the Crawford catch can, but it is set up to vent to atmosphere.
The line that normally goes to the intake has a small filter on it.
The FB turbo intake tube does not have the fitting for the line that runs from the CC to the intake to reburn gasses.
The Following User Says Thank You to mike the snake For This Useful Post:
Old 06-28-2014, 11:26 AM   #1897
xwd
Attachment 83482
That setup is basically setup like the stock system, but ideally you would want another can between the breather and the line going into the turbo or a setup where both the breather and PCV run through a can. N/A no oil really comes through the breather line. Radium makes a really nice dual can setup otherwise there is the Crawford AOS as well.
Also listen to Reaper with regards to the PCV valve. Either take the valve out, get a turbo one which is actuated by vacuum (shuts under positive pressure) so you aren't pressurizing the crankcase, or get an inline valve like this:
https://www.modernperformance.com/pr...o_oilcatchcans
That one is really meant to replace a weaker "turbo" PCV valve, you can get a much cheaper plastic one also. The Vortech kit supplies one.
The Following 3 Users Say Thank You to xwd For This Useful Post:
504 (08-04-2014), blackfireball5 (06-28-2014), Reaper (06-28-2014)
Old 06-28-2014, 11:30 AM   #1898
Reaper
Reaper's Avatar
Drives: violent
Doesn't the ford gt500 run a vta can?
Old 06-28-2014, 01:00 PM   #1899
blackfireball5
If you look closely, there is a second can between the breather tube and turbo inlet. That is actually the radium setup. I like it a lot.
If a vented can setup would pass emissions in Ohio, I'd opt for that since it is more simple. But if it won't, that won't work for me. Can someone c confirm that emissions doesn't worry about a vented catch can setup? I'd grab the full blown can if so.
Wheelwell Profile
Old 06-28-2014, 01:09 PM   #1900
blackfireball5
Is that on the pcv side or the breather side?
Wheelwell Profile
Old 06-28-2014, 01:13 PM   #1901
Reaper
Reaper's Avatar
Drives: violent
google, or call the dmv of the town you live in. Im emissions exempt so I am of no help.
The Following User Says Thank You to Reaper For This Useful Post:
Old 06-28-2014, 05:17 PM   #1902
Dipstik-sportech
Dipstik-sportech's Avatar
Lol. I'm no help either, my catch can is a water bottle with a hose in it lol
Old 06-28-2014, 06:58 PM   #1903
blackfireball5
Haha, that's what mine is right now. :-P best solution when you're in a pinch. Haha.
Wheelwell Profile
Old 06-29-2014, 12:57 PM   #1904
Dipstik-sportech
Subaru BRZ 11.68 @126mph: [ame]http://youtu.be/He52jxUhrAQ[/ame]
The Following 2 Users Say Thank You to Dipstik-sportech For This Useful Post:
blackfireball5 (06-29-2014), Reaper (06-29-2014)
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
