Old 04-18-2014, 03:23 PM   #155
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by 415FRS View Post
I got the idler pulley 38006 and its a little smaller than the one came with the kit. Did i get the correct one?
Sent from my HTC One using Tapatalk
Which dimension is smaller, diameter?
I have my old vortech pulley at home as well as a new 38006 I can measure with a caliper, but I remember all the critical measurements to be virtually identical
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 04-18-2014, 03:31 PM   #156
415FRS
Drives: Red SCion FRS
Diameter. If you stack up the two pulley, you can see the old one is a little bigger. I installed it anyway with the new belt K060970. Its running fine tho.
415FRS is offline   Reply With Quote
Old 05-06-2014, 09:04 AM   #157
sissupr
sissupr's Avatar
Drives: 2014 BRZ Premium - SWP
Can someone tell me if this right before I place some orders...
3.12 pulley w/ Gates K060966 belt + idler pulley 38006
Is there a racing or another brand belt I should consider?
sissupr is offline   Reply With Quote
Old 06-27-2014, 06:04 PM   #158
MATTrocity
Winter Is Coming
Drives: 2013 Scion FR-S Ultramarine
I replaced the belt with the blue gates belt and it's still getting tore up. My idler pulley definitely isn't melting. Could the pulleys be out of alignment?
@charged86 @Dezoris
MATTrocity is offline   Reply With Quote
Old 06-27-2014, 07:20 PM   #159
DJCarbine
Thupercharged
DJCarbine's Avatar
Remove the belt with a pair of snips, then get some good lighting and start to visually inspect the pulley alignment.
What length belt are you using? I would ditch the plastic idler pulley next to the SC while you are in there.
you don't happen to use flatfoot shifting do you?
2013 FRS
Vortech V3 11psi
Old 06-27-2014, 07:36 PM   #160
Dezoris
Dezoris's Avatar
It looks like that belt jumped or was not on Properly. Definately alignment.
Old 06-28-2014, 08:39 AM   #161
AJPG
Drives: 22RE, FA20, 4G63
Completely agree!
Even with the wrong size belt it shouldn't happen... At least for some time.
I change the pulley 3.48 to 3.125, didn't change the belt size and it would hold until every oil change, also didn't see any measurable difference in PSI... That did drop with the complete exhaust (from header to tips) +/- 1.5 PSI drop. Anyway looking for my lost PSI to be 100% sure is not a leak.
AJPG is offline   Reply With Quote
Old 06-28-2014, 04:31 PM   #162
MATTrocity
Winter Is Coming
I used the Gates K060975RB Blue Racing Micro-V Belt.
No flatfoot shifting.
Anything specific I can look for when verifying alignment? Just flush with each other? Other tips?
Thanks guys for the help of a noob.
Old 06-28-2014, 05:58 PM   #163
charged86
charged86's Avatar
might have not been on correctly the first time and then jumped a groove cut that belt off check all pulleys for wiggling and or retorque. and after that eyeball every thing to see if they are in line.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 08-01-2014, 06:48 PM   #164
kinryu
kinryu's Avatar
Drives: 2004 tsx aspec manual /FRS WHITEOUT
Hi guys I have the racing belt for the Vortech for sale. If needed please pm me
TEAM R-RYDES
1 of 1st 86 FRS
Follow my build:instagram @MIGELEO88
http://www.ft86club.com/forums/showthread.php?t=10634
kinryu is offline   Reply With Quote
Old 11-07-2014, 07:58 AM   #165
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Uh what do u mean racing belt?
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 11-07-2014, 10:24 PM   #166
kinryu
kinryu's Avatar
Its the gates blue belt. Its more durable and stronger than the original belt. Google racing belt and it'll be blue. Its size is meant for the FRS with the original Vortech set up.Gates K060975RB Blue Racing Micro-V Belt.
TEAM R-RYDES
1 of 1st 86 FRS
The Following User Says Thank You to kinryu For This Useful Post:
kiichiro (11-07-2014)
Old 11-07-2014, 10:28 PM   #167
kinryu
kinryu's Avatar
Did u make sure the bracket adapter holding the alternater to the engine is tight? It comes in the vortechvkit
TEAM R-RYDES
1 of 1st 86 FRS
Old 12-04-2014, 10:57 AM   #168
kiichiro
So far I have most success running the Dayco 89003 idler that originally came it's the kit, the metal alternative seems stout but presents heat issues in that it retains heat, is a steel pulley. The composite lets the system run cooler, check it with a ir gun and u see what I mean
I have had success running the 3.33 pulley on track, any think smaller makes me over 12 psi and allows my ebcs to build boost the way it's designed but this puts a strain on belt life under road course track conditions
You can daily drive the 3.33 and see upwards of 50k miles of belt life
The smaller pulley options are great for dyno days, but IMHO we need to go to a 8 rib setup to effectively run smaller than 3.33 on a race track, that's my feedback as a tester
I can tear up a new belt in under one session on the 2.87 and yeah I have tested this repeatedly and have no skin on my knuckles to prove it,lol
That said vortechh engineering and tech support for me have been outstanding, the new race spec compressor has held up to serious abuse
It's a amazing bit of kit, and I would go as far as saying the limit is the belt
Robispec radiator oil cooler makes heat a complete non issue in my car in phx on the track that's friggin nuts btw
So...
I strongly recommend it for anyone running hard, it's awesome with the hd bearing
The street kit is just that if you ask me, perfect for street
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
The Following User Says Thank You to kiichiro For This Useful Post:
MyRx (12-04-2014)
Kartboy Crank Pulleys 95.00 tom@kartboy Engine, Exhaust, Bolt-Ons 16 06-11-2013 01:06 PM
Crank,Alternator,Waterpump Pulleys etc..? fareastbrz Engine, Exhaust, Transmission 6 05-28-2013 08:46 PM
Titan Performance second batch of pulleys Amalgamo User/Vendor/Sponsor Reviews, Feedback, Comments 0 07-30-2012 09:57 PM
