Old 06-12-2014, 02:00 PM   #1
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
Tony's Budget Turbo Build
Here is my 2013 BRZ purchased November 15 2012.
I initally wanted to keep everything na and relatively stock for the first 6 years of ownership, Warranty and all that business. Then I drove an actual fast car and my little BRZ's 157rwhp just wasn't cutting it anymore. So i took it to a local shop to spitball some ideas and came up with this...
Oil return
Specs:
Precision built Garrett GT3076R with a Precision DSM .48 turbine housing.
Tial 38mm wastegate recirculated
Turbosmart Vee port pro BOV
Blacked out FMIC (retains washer bottle)
Omni 3 bar MAP
Blowthrough MAF
AEM failsafe Guage mounted in ac vent
PTuning cam plate for gravity fed oil return
Lots of heat shielding
VMS vacuum block
2.25in. SS Wrapped Up and down pipe
OEM header
OEM front pipe
OEM midpipe
OEM tail pipe
Tuned via Ecuflash
I'm currently on a extremely conservative base map that is map sensor limited. There are still a few kinks to work out but im very satisfied with what we were able to accomplish in 7 days. Huge thanks goes to Beast coast customs in Watertown NY for helping me put this together.
glorydays is offline   Reply With Quote
The Following User Says Thank You to glorydays For This Useful Post:
B-R-Z (06-26-2014)
Old 06-12-2014, 02:01 PM   #2
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Nice build. Good looking color ��
AVodka14 is offline   Reply With Quote
The Following User Says Thank You to AVodka14 For This Useful Post:
glorydays (06-12-2014)
Old 06-12-2014, 03:09 PM   #3
glorydays
Remember me?
glorydays's Avatar
Just drove it 1000+ miles from NY to Atlanta with no drama. I removed the weather strip on the wiper cowl which helped get rid of any heat. Thinking of creating a vent where the turbo sits to really expel some heat.
Old 06-12-2014, 03:25 PM   #4
charged86
charged86's Avatar
i would say so. maybe a turbo blanket is in order
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following User Says Thank You to charged86 For This Useful Post:
glorydays (06-25-2014)
Old 06-25-2014, 11:56 AM   #5
glorydays
Remember me?
glorydays's Avatar
Update: So all in all Ive spent something around $2k to turbocharge my own BRZ. Im an e4 in the military so obviously I dont have a whole lot of extra dough to toss around on one of the existing kits. To be honest, while I know my kit isnt as pretty as the ones you can buy off the shelf, it is MINE, which means its unique. I think its a bit boring when you go to a meet and everyone's got the same business under the hood... no fun. So if youre a purist, youre not gonna like me
Impressions: with my current map... its still slow lol. but thats ok because im safe. I can boost to about 3psi before the map sensor says "no". It does pull a little harder than stock but I wont wring it out so i have no idea what it can actually do nor do i care to find out. I'll accept any help on tuning that I can get honestly and ill be getting an oft soon as finding someone with a tactrix cable seems to be impossible...
Because the exhaust is ultimately stock the car is amazingly quiet. All you hear is spool then a little flutter then some blow-off whoosh. it almost feels as if everything is OEM. I'll make some vids soon...
thanks for viewing!
The Following 2 Users Say Thank You to glorydays For This Useful Post:
OmarGC (01-23-2015), raven1231 (06-26-2014)
Old 06-25-2014, 01:03 PM   #6
raven1231
2k?
Old 06-26-2014, 01:28 PM   #7
glorydays
Remember me?
glorydays's Avatar
yep and would have been less if id gone with my original turbo but i got the gt30 hybrid for a decent price. i should end up around $2500 after tuning.
Old 06-26-2014, 02:18 PM   #8
raven1231
Want to do mine?
Old 06-26-2014, 02:27 PM   #9
glorydays
Remember me?
glorydays's Avatar
@raven1231 well I am thinking of reproducing the kit but right now id just like to get it all tuned correctly. if i do have the exhaust piping redone for myself i wouldnt be opposed to selling the original version. then you could find a good 16g or 18g for really cheap.
Old 06-26-2014, 02:43 PM   #10
Synack
Boosted
Synack's Avatar
Drives: Sideways
Welcome to the turbo-by-battery club!
I actually made the mistake of going Precision and not Garrett when I went turbo. I'm saving up for a GTX turbo currently and the car should be beastly(er) very soon.
If I had known you were in Atlanta I'd let you take a look at my setup if you needed any ideas or hints or inspiration or just basic routing, etc.
** What was that you were saying about the weather strip? My turbo needs more cooling and anything helps.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
The Following User Says Thank You to Synack For This Useful Post:
glorydays (06-26-2014)
Old 06-26-2014, 02:58 PM   #11
glorydays
Remember me?
glorydays's Avatar
well thank you sir! your car was my inspiration actually. but yea i was only there for about three days visiting family so I didnt really get out much. so far the precision is holding up well but i need to hurry and replace the oem header with a non catted version so it doesnt eat it. @Synack have you done so already? im also starting to wonder if the pre turbo cat is affecting the af ratios that my wideband sees. im really not sure.
as far as the weather strip, i removed it completely and it works tremendously. at stops I can see the heat venting out. Im not sure whats happening at speed but as far as i can tell, its relieving a lot of heat. also no water gets into the engine bay when it rains. so ditch it!
Old 06-26-2014, 03:35 PM   #12
Synack
Boosted
Synack's Avatar
Drives: Sideways
Please please please show pics of exactly what you did for the weather strip. (I'm not sure exactly which piece you're referring to)
We actually ditched the cat a LOOOOONG time ago. It blew out during dyno runs and just stopped working altogether. It was screwing up the car's idle and other things too. DITCH IT!
I also put a new header in there, I believe the Agency Power ($400 from Dynosty) unequal length one. Do it all at once so you only have to tune for one setup.
Dude my turbo is roasting in this Atlanta heat so I need it to vent ASAP. I wonder if we can remove the 86 side vent logo and make a DIY thing to help it get more air.
Old 06-26-2014, 05:26 PM   #13
glorydays
Remember me?
glorydays's Avatar
Just peeled it off.
Old 06-26-2014, 05:28 PM   #14
glorydays
Remember me?
glorydays's Avatar
You get a nice gap there for the heat to escape
Synack (06-27-2014)
turbo, turbo brz
Tony Angelo breaking in his new FRS HATED1 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 41 08-15-2014 11:13 AM
WTB Tony Angelo RPF1 Ev@n Wheels and Tires 0 02-25-2014 11:14 AM
Tryong to reach Tony from FA20club infanterene Forced Induction 2 07-31-2013 08:16 PM
Thumbs UP for Tony an FA20Club jflogerzi User/Vendor/Sponsor Reviews, Feedback, Comments 0 07-10-2013 12:44 PM
Tony Hawk Jumps Over LFA M-17 Other Vehicles & General Automotive Discussions 5 05-16-2012 02:35 PM
