Old 06-25-2014, 01:37 PM   #519
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
@DeliciousTuning I just wanted to say how much better the new innovate update is. It's a hundred times better than before, especially while the car is cold. Damn fine job you did Bill. Thanks again
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 06-25-2014, 03:19 PM   #520
Dezoris
Dezoris's Avatar
Originally Posted by DeliciousTuning View Post
I will be back in my office on Tuesday but going to see if I can get some updates out to a few fellows over the weekend. I know there are a few of you that have been incredibly patient and I thank you. Please understand I have not forgotten about you and all the tuning I have been doing lately is also for the benefit of those who have been waiting patiently.
I have been focusing on low end throttle response, cruising, partial throttle acceleration to make everything smoother and easier to drive. Also we have been working on idle quite a bit and been working with EcuTeK on a new table that helps with idle control under heavier loads, such as lights ON, AC ON and automatic and it seems to be doing the job.
Anyway that is the update for the few of you waiting for updates. I have been focusing a lot of my energies on these small areas but they take a little time to dial on on these pure Speed Density tunes as I do not have a test vehicle in our shop, BUT we are working on that. Custom turbo kit on the way for R&D.
Cheers,
William Knose
Thanks for update, bet you will be happy to be back home.
Old 06-25-2014, 08:34 PM   #521
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
This launch control is pissing me off. Sometimes it works and sometimes it doesn't. Is there a particular technique to it?
texasbound972 is offline   Reply With Quote
Old 06-25-2014, 09:48 PM   #522
whataboutbob
AutoX-10/10ths every run
Thanks for your time and help with the car and tunes Bill. The 8.59 map is working nicely.
Build thread:Here
Old 06-25-2014, 10:52 PM   #523
xjohnx
Grip>Slip
xjohnx's Avatar
you have to activate it within x seconds of putting the clutch in. I found if i'm sitting with the clutch in for a few seconds, THEN try to activate LC, it won't work. but if you put the clutch in then immediately floor the accelerator, it would work.
that's just my experience, though.
Old 06-25-2014, 10:54 PM   #524
texasbound972
USMC
Thanks xjohnx! I'll give it a shot!
Old 06-25-2014, 10:55 PM   #525
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
You also need to mash the throttle. Needs to be 100% wide open
Sent from my HTC One using Tapatalk
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 06-25-2014, 11:41 PM   #526
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
xjohnx and protpibe,
Thanks for clearing that launch control up. We have quite a people ask how to get it to work and seem to be having problems getting it activated. We have even gone and reviewed the maps sent to everyone and made sure that everything is active.
One thing we will also note with regards to autoblip and might affect launch control. In order to get things to work immediately as it does not always seem to, after the car has been reprogrammed or reset, start the car and let it idle for 5 minutes and do not touch the throttle. This will help the throttle control learn and also make the autoblip work immediately.
Cheers,
William Knose
Old 06-26-2014, 12:20 AM   #527
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
@sales@delicioustuning.com @DeliciousTuning:
Do you happen to do NA tunes for LSx engines too??? Or do you only focus/specialize in tuning import motors?
Like say... if someone swapped in an LS3 in the FRS/BRZ. I wonder how much xtra power you skilled guys can milk from a stock 430hp LS3 NA engine?
fooddude is offline   Reply With Quote
Old 06-26-2014, 07:18 AM   #528
xjohnx
Grip>Slip
xjohnx's Avatar
Cheers,
William Knose
Bill -
Speaking of auto-blip, I never have been a fan of it because every implementation I have seen has applied a static amount of throttle for every downshift, as opposed to an intelligent system that would take into account the desired RPM and the current RPM then apply the precise amount of throttle necessary to rev-match. Is there any hope of implementing the latter with ECUtek custom maps? or do our cars simply lack the hardware (i'm assuming cars like the 370z use shift gate sensors or something of the like) to make that happen?
Old 06-26-2014, 02:05 PM   #529
DeliciousTuning
Sorry we do not work in domestics. Though we could we specialize in Japanese only and that is enough work in itself. Though that would be a crazy build. LOL
Cheers,
William Knose
Old 06-26-2014, 02:11 PM   #530
xxscaxx
Drives: 2013 SWP BRZ
Bill - I sent you an email about the new update for the Innovate map 8.59, but do you want us to also put a request in on the site? Just want to stay in protocol and not annoy you too much, lol.
@DeliciousTuning
xxscaxx is offline   Reply With Quote
Old 06-26-2014, 02:40 PM   #531
Calum
That Guy
Drives: 2013 asphalt FRS MT
Try elemental tuning.
Old 06-26-2014, 03:10 PM   #532
DeliciousTuning
Originally Posted by xjohnx View Post
Bill -
Seriously great question. I will need to look into this but as for how the system works now it is a time based throttle percentage opening at a specific RPM. So If you are at say 4000 RPM and downshifting, the vehicle will open the throttle X % (ex. 25%) for Y amount of time (ex. .2 seconds). So it does not hit s desired RPM target.
Here is an image of what the table looks like.
Now having a desired RPM Target when downshifting based on current RPM and gear selection to provide the correct amount of throttle input would be trick. Definitely something to look into.
Cheers,
William Knose
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
