Old 06-25-2014, 11:29 PM   #4859
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by evan View Post
For those of us living in the fast lane, how about 68 or 66 (or even 64!) mm pulleys? An oil pump recirculation setup might be nice for the blower at that point. I know it exceeds manufacturer specs. Just curious about how far we can push before going 335.
It might be a good idea for some of us to learn how to rebuild the sprintex. I can't imagine that it would be too mechanically difficult. Just in case..
Funny you should ask. We are working on smaller pulleys as we speak and problem we were having was getting the correct groove angle on the actual pulley for the teeth. We actually had to source the proper tool in order to cut it properly, but now that we have it we are going to start testing smaller and letting everyone know what is possible before it breaks.
We are definitely trying to see the limits we go to on this kit while still being reliable and we have a couple other ideas in mind too.
Cheers,
William Knose
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
evan (06-25-2014), Lawnik (06-26-2014)
Old 06-25-2014, 11:30 PM   #4860
DeliciousTuning
Originally Posted by mikalem View Post
For those with the airaid, where did you get a coupler that fits? Does airaid or one of the tuners on here sell a kit directly for the 210?
Airaid actually supplies the coupler now specifically for this kit and we can order them for whoever is interested, just email me and let me know.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
mikalem (06-27-2014)
Old 06-25-2014, 11:35 PM   #4861
DeliciousTuning
You are correct. It is very very close to the oil filter. I didn't realize how close until I got it. I'm sure I can find a creative way to make it work with an oil cooler once I decide to install one.
We used a Mishimoto Oil Cooler kit on one of our race cars we sponsored with an Airaid intake. In order to get it to fit we made sure the oil line bent directly up and to the left side (drivers side in the US) of the vehicle. We also had to cut the front metal beam (where the OEM intake would mount) about 1 cm in order to get everything to fit tight. It is one small section you need to cut in order for everything to fit snug.
Cheers,
William Knose
evan (06-25-2014)
Old 06-26-2014, 01:44 AM   #4862
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by xjohnx View Post
I primarily use dashcommand, but noticed today that it is showing values well above the 5.3psi of the stock map sensor i'm running. I'm not sure where it's getting that data, but from what i can tell it looks to be correct.
I've got to install an update on my head unit and reinstall torque over the next couple days, then I'll test it out and see if the same holds true.
The stock map cannot exceed 5.3. Something wonky is going on.
Old 06-26-2014, 02:40 AM   #4863
Kodename47
Kodename47's Avatar
Drives: UK GT86
The 210+ is your friend when it finally surfaces. The IATs on the 75mm pulley go hot in the Summer here (60-70C), I dread to think what the 69 or below is like. As I run IAT based ignition retard, it starts robbing power at a decent rate.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-26-2014, 02:54 AM   #4864
evan
Drives: fr-s
I spray water/meth just before the throttle body. I'd rather upgrade to the 335 than spend money on the 210+ for another mild upgrade. I have also considered spraying post blower into each intake runner/per cylinder. Not interested in laminova.
evan is offline   Reply With Quote
Old 06-26-2014, 03:25 AM   #4865
Kodename47
Kodename47's Avatar
Drives: UK GT86
A 210+ and a ~70mm pulley will be a much cheaper option for decent power without the expense of pulling the engine. I guess it depends if your end goal is to have a built motor or not.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-26-2014, 07:38 AM   #4866
xjohnx
Grip>Slip
xjohnx's Avatar
Yeah, it struck me as odd too. I'm not sure what's up with it. Add that to the list of things to figure out.
I will say after getting a little more time with 8.59, it's spot on. Not sure how much of the improvement i'm seeing can be attributed to the 8.58 -> 8.59 changes vs the updates @DeliciousTuning made to dial in my MAF scaling to match my Perrin 3" CAI, but whatever changed certainly seems to have worked.
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
CSG David (06-26-2014), DeliciousTuning (06-26-2014)
Old 06-26-2014, 02:03 PM   #4867
DeliciousTuning
Completely correct on a non-intercooled kit. We actually do not recommend going below 75mm without an intercooler as there is no benefit to doing so. Though 69mm seems to be working well so far on 91 octane and intercooler, but we are still testing it and dialing in the tune a little more.
Then we are on to testing 67, 65 and 63. Pulleys on order. Though I am thinking these are going to be race application only.
Cheers,
William Knose
Lawnik (06-26-2014)
Old 06-26-2014, 05:02 PM   #4868
Kodename47
Kodename47's Avatar
Drives: UK GT86
My kit is with I/C. I see low to mid 50C charge temps at 7k in cold weather, but now its currently 20-25C outside I'm seeing 10+ degrees more increase. For most people the timing won't change as their IAT sensor is pre-charger.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-26-2014, 05:28 PM   #4869
DeliciousTuning
Correct the IAT is pre-charger on most kits but there will be an overall timing trim change based on ambient air temperature at the MAF sensor. That is how we have the tune setup at least.
As you have seen the ambient air temperature goes up so the charge temp goes up. With that we have an adjustment for that based on the ambient air temp.
Cheers,
William Knose
Old 06-26-2014, 10:08 PM   #4870
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Hey guys what's the maximum oil temperature you're seeing while driving on the street and or track? Also what's the normal operating temperature for the oil? This is with the intercooler.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 06-27-2014, 08:26 AM   #4871
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Finally stitched together some video from the WBM event. Enjoy the whine!
Xero-Limit is offline   Reply With Quote
The Following 3 Users Say Thank You to Xero-Limit For This Useful Post:
CK_Bladesmith (06-27-2014), Dustin (06-27-2014), xxscaxx (06-27-2014)
Old 06-27-2014, 09:32 AM   #4872
xjohnx
Grip>Slip
xjohnx's Avatar
Anyone else running @DeliciousTuning's 8.59 rom notice that almost all of that nasty rasp/resonance around 4k rpms is gone (or at least, greatly reduced?)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
