Old 06-25-2014, 05:06 PM   #4845
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by xxscaxx View Post
No problem. Hopefully it gets pushed out, and then I can purchase the 69mm pulley.
We are currently revising the tune for the 69mm pulley upgrade as the load values are a fair bit higher then the 70mm pulley. Also working on some dyno charts comparisons to show the differences for 91 and E85.
Currently we have a version update, 8.59 to tackle the drivability under light loads in all RPM's (and many other improvements). Just email me about it and I will work on getting the updates out, just do not expect quick responses right now but we will do our best to get them out in a timely manner.
The new version of the tune after the current 8.59 version will be able to handle pulley sizes from 80-69mm, on 91-94, E85 and Flexfuel.
Cheers,
William Knose
The Following 4 Users Say Thank You to DeliciousTuning For This Useful Post:
brianhj (06-25-2014), CK_Bladesmith (06-25-2014), Dustin (06-25-2014), Lawnik (06-25-2014)
Old 06-25-2014, 05:33 PM   #4846
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Email sent.
Dustin is offline   Reply With Quote
Old 06-25-2014, 06:14 PM   #4847
whataboutbob
AutoX-10/10ths every run
Picked up a used Air Raid intake and one of these http://www.shop.footworkautosport.co...S-LS8B2020.htm
that I plan to put on the car after this weekend.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
evan (06-25-2014)
Old 06-25-2014, 07:54 PM   #4848
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Is there any way to show more than 5.3psi of boost off of the stock map sensor while using torque pro?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 06-25-2014, 08:02 PM   #4849
evan
Drives: fr-s
No. You either use a "bigger" map sensor and scale for it in your tune (might not be etuner friendly with the innovate) or you can drill into the map plate and install a boost sensor. You can then ignore the ECU value.
I run a 3bar on my brzedit tune and it seems fine. Driveability on the stock map sensor and etune may be better, based on the comments around here.
evan is offline   Reply With Quote
The Following User Says Thank You to evan For This Useful Post:
Old 06-25-2014, 08:10 PM   #4850
evan
Drives: fr-s
I have airraid. Good choice. I am looking to get a plexiglass cover fabbed to replace the metal one. Good for hard parking. I'd skip the aftermarket snorkel personally. I plan on just removing my stock one.
Old 06-25-2014, 08:18 PM   #4851
evan
Drives: fr-s
Cheers,
William Knose
For those of us living in the fast lane, how about 68 or 66 (or even 64!) mm pulleys? An oil pump recirculation setup might be nice for the blower at that point. I know it exceeds manufacturer specs. Just curious about how far we can push before going 335.
It might be a good idea for some of us to learn how to rebuild the sprintex. I can't imagine that it would be too mechanically difficult. Just in case..
Old 06-25-2014, 08:24 PM   #4852
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I think I'm going to have to stay with the stock air box. Looking at the AirRaid box, it doesn't look like it would clear the Robispec oil lines.
Old 06-25-2014, 08:28 PM   #4853
evan
Drives: fr-s
You are correct. It is very very close to the oil filter. I didn't realize how close until I got it. I'm sure I can find a creative way to make it work with an oil cooler once I decide to install one.
Old 06-25-2014, 08:30 PM   #4854
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
For those with the airaid, where did you get a coupler that fits? Does airaid or one of the tuners on here sell a kit directly for the 210?
mikalem is offline   Reply With Quote
Old 06-25-2014, 08:33 PM   #4855
Draco-REX
Corner Junkie
Draco-REX's Avatar
I have a silly idea... But I need to do some mocking up to see if it's viable first..
Old 06-25-2014, 08:33 PM   #4856
evan
Drives: fr-s
The only one I could find (which I use) is the HPS 3" to 3.5" model (6" length). I use it with a custom aluminum intake pipe that has approx the same dimensions as the innovate pipe.
Make sure you pick up some bigger diameter worm clamps too. Got mine at Home Depot or Lowe's.
mikalem (06-25-2014)
Old 06-25-2014, 09:35 PM   #4857
xjohnx
Grip>Slip
xjohnx's Avatar
I primarily use dashcommand, but noticed today that it is showing values well above the 5.3psi of the stock map sensor i'm running. I'm not sure where it's getting that data, but from what i can tell it looks to be correct.
I've got to install an update on my head unit and reinstall torque over the next couple days, then I'll test it out and see if the same holds true.
Old 06-25-2014, 09:38 PM   #4858
whataboutbob
Bill had mentioned to me that the stock snorkel could be modified (removed?) to help improve the intake with the SC, but after seeing what TRD did on the Griffon I wanted to get something that would allow cool air to flow in from in front of the radiator and IC to keep the air temps down as much as possible. I'm pretty sure I'll be the first one to run this part with the Innovate SC.
Build thread:Here
evan (06-25-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
