Old 06-11-2014, 11:11 AM   #183
ModBargains
ModBargains's Avatar
Drives: FRS, M3
This is looking sweet! Keep us updated
ModBargains is offline   Reply With Quote
The Following User Says Thank You to ModBargains For This Useful Post:
Dustin (06-11-2014)
Old 06-11-2014, 11:15 AM   #184
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Originally Posted by Dustin View Post
Fixed my one and only vacuum leak but still having issues. It is somewhat reassuring though that I'm not the only one. It seems that quite a few people with the intercooled setup running a 70mm pulley on pump gas are having the same problem. On E85, the problem could not be duplicated. So Bill @ Delicious Tuning is working to resolve this issue. It gonna suck driving an extra 40 minutes every time I have to fill up just to get E85 so my car runs right.
really hoping Bill gets it figured out - even on E12 I'm seeing some sputtering but it's not outright throwing codes, just doesn't sound pleasant. been babying the car everywhere I go til I see the update.
mikalem is offline   Reply With Quote
Old 06-11-2014, 12:08 PM   #185
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
I know, and it sucks because I need to get my inspection done but every time I get close to where I can get it, it will throw the code even with babying it. So It's E85 for now until I get the inspection.
Dustin is offline   Reply With Quote
Old 06-15-2014, 12:39 AM   #186
wallace03
wallace03's Avatar
Drives: WRB BRZ
Any plans to Dyno your beast?
wallace03 is offline   Reply With Quote
Old 06-15-2014, 11:26 AM   #187
Dustin
Twin Screw You
Dustin's Avatar
In the process of setting a date. Just trying to find a day when I have available that they have time.
Old 06-22-2014, 04:20 PM   #188
Dustin
Twin Screw You
Dustin's Avatar
Finally getting my car dyno'd this Tuesday. Can't wait to see what it puts down!!
Old 06-23-2014, 12:47 PM   #189
ModBargains
Drives: FRS, M3
Love what youve done man
Old 06-24-2014, 05:14 PM   #190
Dustin
Twin Screw You
Dustin's Avatar
285 hp & 219 lb/ft torque and so smooth.
Stock vs mine
The Following User Says Thank You to Dustin For This Useful Post:
frsvr4 (07-18-2014)
Old 06-25-2014, 11:14 AM   #191
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Great numbers. Impressively smooth graph for Smoothing of 0. Would rather see SAE and Smoothing of 5 though.
Old 06-25-2014, 03:32 PM   #192
Dustin
Twin Screw You
Dustin's Avatar
I'm not sure what that means. First time at a dyno for me. What would SAE and Smoothing of 5 show differently than STD and Smoothing of 0?
Old 06-25-2014, 03:43 PM   #193
King Tut
NASA SpecE30 Racer
King Tut's Avatar
STD and SAE are two correction factors that take temp, humidity, and elevation into account to correct the horsepower/torque numbers. STD is always higher than SAE. The dyno only collects x amount of data points during the run and with the smoothing set to 0 it plots each of them and then connects a line to each point. With smoothing set to 5 it tries to smooth out the line and goes between points no different then when you plot a line in Excel and have the options of a smoothed line or not. Forgot to add that if you ask the dyno shop for the dyno run files you can go home and plot them however you want in the free Dynojet WinPEP software.
Dustin (06-25-2014)
Old 06-25-2014, 03:51 PM   #194
Dustin
Twin Screw You
Dustin's Avatar
Cool, cool. Thanks for the info.
Old 07-27-2014, 07:57 PM   #195
Dustin
Twin Screw You
Dustin's Avatar
Well I trashed my first belt the other day. I was showing someone how the launch control worked and not even 2 minutes down the road I heard the belt, partially shredded, knocking around inside my engine bay. It's hard to understand why launching at only 3k RPMs would do that to a belt. I think I've only used LC like 3 times. Next time I'm gonna go with the samller Gates belt to see if that helps.
Haven't been doing much with my car. Added up how much I've spent in extras on the car since I've owned it and realized I could've paid off my truck................or my house.............or all my credit card debt............or my personal loan..........you get the idea, so I've held off any extra spending for the time being. But I started desiging a new piece similar to Perrin's steering rack lockdown. I think that should be easy enough to find some scrap material for free and try to make something nice out of it.
Old 07-28-2014, 05:00 PM   #196
wsites
Drives: 08 STI|15 BRZ|95 L Coupe
Sorry if this is a dumb question, but where did you get the Nameless intake tube. I checked their site and even tried googling it and I couldn't find one for sale anywhere.
Originally Posted by cantholdanymore View Post
People wants moar pawar
Kit provides moar pawar
Kit needs engine build to support moar pawar.
People call it fault
wsites is offline   Reply With Quote
BRZ Limited Backup Camera Step by Step (WARNING long post, many pictures) runny_yolk Electronics | Audio | NAV | Infotainment 120 01-29-2021 06:18 PM
step 1 :buy frs in phx, step 2: drive to pikes peak haymaker FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 08-21-2012 10:44 AM
[StreetFX] License Plate LED light upgrade, and DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 11:38 AM
[StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 11:27 AM
