Old 06-18-2014, 01:59 PM   #281
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
Hey @DSOmegaX, can you post your alignment settings when you have a chance? I'm just curious what they're set at.
SuperDave is offline   Reply With Quote
Old 06-24-2014, 10:23 AM   #282
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by DSOmegaX View Post
HI,
How much for the STI BBK? Where did you buy them?
Is rear can direct fit without any modify?
Any different after upgrade? (I am still debating that our car need
BBK (benefit) for daily driver or is just mainly for look)
Thanks.
cslntuee is offline   Reply With Quote
Old 06-24-2014, 10:27 AM   #283
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by cslntuee View Post
HI,
Thanks.
It is solely for looks on a daily driver. There has yet to be any proof that the STI breaks actually improve any facet of braking other than heat capabilities.
(I have them up front, they look great and work fine)
I want to add more answers here.
1. Price ranges, $600USD and up for front calipers, but then you need rotors and pads, full kits are over $1,200 probably
2. There is a kit for sale on the forums right now
3. I got stainless steel lines, so I feel it more in the pedal now, a bit more dive it feels like (could be from added nose weight with everything else I have)
4. Rears are not direct fit, need custom mounting bracket and modifying dust shield
Also, DSO does do things with his car that may benefit from bigger brakes, I do not.
Old 06-25-2014, 04:16 AM   #284
DSOmegaX
DSOmegaX's Avatar
HI,
Thanks.
For just daily use, the BBK is more than overkill especially if you're at stock power to minimal gains. I use my car for canyon/autox more than track but even in those conditions, an actual BBK isn't needed, so it's mostly cosmetic. In terms of actual stopping performance, the other areas I did have more of an effect: stainless steel lines, new brake fluid, upgraded pads, and adding a master cylinder brace. The overall effect is more bite and firmer pedal travel.
As for where you can get a set, you have a couple options. The obvious, but most expensive route is buying the actual BRZ tS brake kit from japanparts...which is $5k for the front set alone...so yeah. Otherwise, for the calipers, you have two options here: go down to your local Subaru dealer and just buy a new set of calipers from a WRX STi. Otherwise, you want to look for a used set of calipers from any WRX STi that is 08+. You can also use any set from 02-07 but it takes a little more work (more on that later). The best way to find a used set is to just lurk on nasioc.com. Look at the part out/salvage FS section especially.
It's easier to get a 08+ set because the rears actually just bolt on, no mounting brackets required (02-07 need the brackets). You just need to cut the dust shield off.
For reference, I paid around $1000 for a set of '13 calipers used for 30k miles, pretty much in perfect working condition. Around $400 for a set of rotors, $100 for stainless lines, $80 for new fluid, and $180 for new pads. So a little less than $2000 in parts for a full set.
@dsomegax.cars
Old 06-25-2014, 10:15 AM   #285
cslntuee
Is there any balance issue, if only upgrade the front?
Thanks.
Old 06-25-2014, 10:24 AM   #286
cslntuee
HI,
Is there any different between the BRZ STI TS BBK and the 08+ WRX?
I just curious why the BRZ STI ts one is so expensive.><
By the way, could you describe more detail related to "dust shield off:?
Do you mean there will no dust shield in the rear?
Thanks.
Old 06-26-2014, 02:44 AM   #287
DSOmegaX
DSOmegaX's Avatar
HI,
Thanks.
Probably just rarity? No idea really. The calipers are the same, rotors are upgraded from stock but nothing you can't easily find. The rear dust shield is sized specifically to fit the stock rotor in the rear, so it will have to cut out in order to fit larger sized rotors
@dsomegax.cars
Old 06-27-2014, 02:38 AM   #288
DerHauptDigga
DerHauptDigga's Avatar
Drives: 2016 FRS
Subbed. So clean, nicely done sir.
DerHauptDigga is offline   Reply With Quote
Old 06-28-2014, 06:31 AM   #289
DSOmegaX
DSOmegaX's Avatar
Ready for Subaru Summer Solstice!
@dsomegax.cars
Old 06-30-2014, 02:34 AM   #290
DSOmegaX
DSOmegaX's Avatar
@dsomegax.cars
Old 06-30-2014, 12:41 PM   #291
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Ugh! Do want!
Oh... wait... almost have. Still, looks good to see it in pictures and pretty much completed. Good job, Sir! Any more plans for interior mods?
Old 07-01-2014, 03:49 PM   #292
ModalSoul37
ModalSoul37's Avatar
Drives: 2014 Limited WR Blue Brz
Lame, the rear struts + springs aren't on japan parts anymore
ModalSoul37 is offline   Reply With Quote
Old 07-01-2014, 08:26 PM   #293
DSOmegaX
DSOmegaX's Avatar
Bah! Yeah Japanparts just revamped their whole website...looks like I'll have to fix all the links
@dsomegax.cars
Old 07-01-2014, 08:37 PM   #294
ModalSoul37
yeah i noticed it today, I asked them over facebook if they still had em, just waiting for the response.
Completed build JK21 Member's Car Journals 46 12-11-2014 09:48 AM
Completed!! FBM 700+HP Build Dyno graph & Vid inside FullBlown Forced Induction 214 03-31-2014 01:56 PM
Vinyl wrap completed!! laley81 Southern California 14 08-30-2013 11:10 PM
Nearly Completed my Firstorm Build - Lots of Pics msile Member's Car Journals 52 03-10-2013 10:25 AM
Turbo FRS completed! Philly CANADA 24 09-03-2012 09:18 AM
