Old 06-24-2014, 01:05 PM   #15
Dezoris
Dezoris's Avatar
Originally Posted by glamcem View Post
Are you guys referring to the overheating or heat cycling? This is the first time I am hearing a 200 rated street tire having heat cycling issues Heat cycling generally applies competition tires and heat cycling process is also offered for racing/competition tires. Most of the time people over heat their tires and think they are heat cycled out
Also the initial heat cycling process extends the life of the tires. FYI, many people run their NT01 to the cords ( they typically flip them on the wheel after the outer tire is worn out) and they claim the tires perform better (possibly after the tread is gone)
Here is a good read about the heat cycling if you're interested:
http://www.tyre-technology.com/index.php/heat-cycling
I think what they are seeing is a combo of both, as the tire compound for the Dunlops dont seem to be consistent down to the bottom half of the tread where rubber seems to be much harder. Add on some nasty heat cycling and you have a dead tire.
It's hard to make a tire work for street and hard core competition without some trades off for street or track/autox.
Old 06-24-2014, 01:18 PM   #16
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
yes, and that's the reason why I don't feel the "compromise tires" especially when we can fit an extra set of wheels in our cars (and many other things)
Nitto NT01s cost nothing unlike the more expensive R compounds (such as pirelli trofeo R or Michelin Sport Cup/Cup 2)
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
MINOCIN (06-24-2014)
Old 06-24-2014, 01:25 PM   #17
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by forwallblakmail View Post
Is there a way to tell if a tire is hear cycled out? Is that a thing? I don't know if my Z2's just got too hot today but my last autocross run they seemed to fall off a bit. I only ask because I have a slightly fresher set I can get mounted on before next weekend's ProSolo.
The tires in question have approximately 21 autocross runs on them and 1 track day with 4 20 minute sessions (1.6 mile course, pushed pretty hard).
I realize this is vague, but a shot in the dark for anyone who may have insight.
Thanks!
Do you know about durometers?
http://www.saferacer.com/longacre-tire-durometer
Old 06-24-2014, 09:40 PM   #18
forwallblakmail
Troll Level: Expert
forwallblakmail's Avatar
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
Originally Posted by Pat View Post
Never seen or used one before. Looks like it could be a good buy though.
Slight deviation from topic, what kind of pressures are you guys running in the RS3? I know it will need to be higher than the Z2
Nick K.
NASA ST5/TT5 #130
Southeast Region
forwallblakmail is offline   Reply With Quote
Old 06-25-2014, 02:14 AM   #19
CSG Mike
CSG Mike's Avatar
Don't cook your street tires. The grip will never quite come back.
If you lose grip without the tires making noise, they're heat cycled out.
Luckrider (06-29-2014), Speedy Nick (12-15-2016)
Old 06-25-2014, 03:06 AM   #20
juliog
juliog's Avatar
Drives: 86
I usually shoot for 37F/36R hot, because it feels right, but it might not be ideal. I need to get a pyrometer and do some testing..
juliog is offline   Reply With Quote
Old 06-25-2014, 03:28 AM   #21
CSG Mike
CSG Mike's Avatar
You can use ours.... but if you break you buy :p
Old 06-25-2014, 05:37 PM   #22
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I hear the rs3 v1 cycle out pretty rapidly loosing most of it grippiness with more than 50% left. Ever hear of people running tire Warmers on cars at trackdays? I've seen them on go karts.
Old 06-25-2014, 10:39 PM   #23
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
I have heard ZIIs give way more warning before breaking loose than RS3's ... true or false?
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 06-25-2014, 10:45 PM   #24
CSG Mike
CSG Mike's Avatar
RS3 is more slip angle tolerant, so some people perceive the Z2's lack of tolerance as being more progressive.
Don't cook your tires. Most people on RS3 do not know how to preserve their tires.
Combating the heat toekneehair Forced Induction 823 12-23-2021 08:06 PM
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
