Old 06-23-2014, 04:06 PM   #967
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Originally Posted by Kido1986 View Post
Those items plus header and a tune are the key items for STX. There's obviously more but those items (plus header/tune) are 80% of it.
Lighter battery would be nice.
Other items that make up the 20% would be?
BRZZZZZZZZZZ is offline   Reply With Quote
Old 06-23-2014, 04:10 PM   #968
dpgdave
Hey guys,
I have a whiteout that I built for Autocross but only tracked it one time. I just haven't had the time on the weekends. I just got engaged and need to sell the car for something larger. If anyone is interested in it, feel free to call me, david, at 210-712-3815.
Here's the link:
http://sanantonio.craigslist.org/cto/4535111500.html
dpgdave is offline   Reply With Quote
Old 06-23-2014, 04:29 PM   #969
Wepeel
Drives: '13 BRZ Ltd
Diff, suspension bushings, motor/trans bushings, lightweight brakes, seats. These may or may not make you faster but that's what would be next.
Wepeel is offline   Reply With Quote
Old 06-23-2014, 04:32 PM   #970
BRZZZZZZZZZZ
Car Nut
Diff as in a different type of LSD only? You are not allowed to change transmission and rear end ratios for STX afaik?
Old 06-23-2014, 04:34 PM   #971
Wepeel
Drives: '13 BRZ Ltd
Correct.
Old 06-23-2014, 05:25 PM   #972
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Here is a running List of my STX Build:
2013 Subaru BRZ Limited, Satin White Pearl
Suspension:
-KW Var3 coilovers 400/400
-Camber Plates
-Whiteline Adj Front 20mm Bar
-STi 18mm Rear Bar/18mm rear Whiteline Adj also.
-Kartboy Rear endlinks
-Whiteline Bushings, Diff, Steering Rack, Cradle
-Truhart Rear Lower control arms
Brakes:
-Stoptech Stainless lines
-Motul Fluid dot 5.1
-Stoptech 328mm 4 Pot Front Brakes/Subaru 2 pot rears
-Ballistic 3.5lb Lithium battery 500 CCA
-Kartboy shifter
-Kartboy Bushings
-Cusco Engine Mounts
-Kartboy Tranny mount insert
Engine:
-EcuTek Engine management... 8k Redline... tune by Nameless
-Nameless Performance Header back exhaust system
-Homemade intake with K@N filter
Rim/Tires:
-17x9 Rota Wheels (42 offset)
3 Different sets of tires depending on surface.
-245-40-17 Hankook Ventus RS-3 ver 2
-255-40-17 Dunlop Z2
-255-40-17 Federal 595RSR
Drivetrain:
-Guard Transmission LSD
Int:
-Corbeau FX1 Seat
I have some other comfort and convenience items also.. but not relavant to a STX Build really.
Hope that helps.
Bill
Scooby South is offline   Reply With Quote
Old 06-23-2014, 05:57 PM   #973
BRZZZZZZZZZZ
Car Nut
Suspension:
-Camber Plates
Brakes:
-Kartboy shifter
-Kartboy Bushings
Engine:
Rim/Tires:
Drivetrain:
Int:
-Corbeau FX1 Seat
Hope that helps.
Bill
Thanks. I have most of those major items but I am really hesitant to touch the powertrain in my car.
Old 06-24-2014, 07:55 AM   #974
piknockout
Drives: 2014 BRZ
PSA: our cars have a "sound generator" on the intake that makes it louder than it should or needs to be. If you install a Perrin inlet tube, not only do you double the horsepower, but the car is 10 times quieter. We now return to your regularly scheduled STX thread.
piknockout is offline   Reply With Quote
Old 06-24-2014, 01:29 PM   #975
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 06-27-2014, 01:40 PM   #976
connorlug
Drives: #1553 10 Series FRS
hey guys, been doing autox for a few years now but this is my first season with the frs, getting it set up as an stx car.
i've been doing pretty good for only having st coilovers and wheels/tires.
running 245/35/18 federal 595 rsr's..most recent even i came in 7th in pax out of 130 people and 4th in stx class out of 30.
the only thing i truly feel the car needs now is a tiny bit more power/throttle response, i find sometimes coming out of hard corners in 2nd it just doesn't have enough pickup. i was thinking of doing a header and tune with a drop in k&n.
I'm just on a small budget this year so i'm not looking to spend much. any recommendations for me?
connorlug is offline   Reply With Quote
Old 06-27-2014, 02:12 PM   #977
Scooby South
Conedancer
Don't know what your budget is.. but you looking at about 2k or more for a decent header/exhaust... and a Tune. EL long tube headers are what most of us are using...Nameless Header back and STX Nameless Tune with a 8k redline.. I have no issues pulling out of corners.. But as you know, the Twins are Momentum cars so you have to keep your speed up regardless. .. You might be able to get by on the cheap with a used setup..
Bill
Old 06-29-2014, 09:18 AM   #978
connorlug
Bill
Thanks for the reply exactly what I needed to confirm
The Following User Says Thank You to connorlug For This Useful Post:
Scooby South (06-29-2014)
Old 06-30-2014, 05:18 PM   #979
BRZZZZZZZZZZ
Car Nut
Perhaps I missed it but what are the rules regarding aero in STX? I am assuming functional front lips and diffusers are a no go?
Old 06-30-2014, 05:27 PM   #980
Scooby South
Conedancer
They are legal.. I plan to put the STi Stuff on my car Front lip, Side skirts and Rear Aprons from the "Blue" model ...Here is the Rule.
F. Addition of spoilers, splitters, rear wings, bumper covers, valances,
side skirts, and non-functional sccops/vents is allowed provided that either:
1. It is a production part which is standard or optional equipment of
a US model of the vehicle. (“Model” is defined in Section 12.3.)
2. It is listed in the vehicle manufacturer’s US accessory catalog
for that vehicle for normal highway use. This does not allow for
parts sold through a manufacturer’s performance catalog (e.g.,
Ford Racing, HPD, Mazdaspeed, Mopar Performance, Mugen,
NISMO, SPT, TRD, etc).
Parts must be installed as directed by the manufacturer. Exact
replicas,including weight, from alternate sources are also permitted.
The part I am not Clear about is, Is the same stuff legal for FRS's...
12.3 MODEL
A group of cars of a given make which have virtually identical bodies and chassis but are readily distinguished from other models of the same make by virtue of a major difference in body appearance and/or chassis design. The names by which the manufacturer designates these groups have no bearing on this definition even though two (2) groups may be designated identically.
Bill
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
