Old 02-13-2014, 10:22 AM   #43
retrosmiths
Drives: Scion FR-S Whiteout
Hand-tightened them cause my torque wrench won't fit..
I may have exaggerated, it's not vibrating, but a bit like a warble noise when light braking, at that last second before the full stop.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 02-15-2014, 03:14 PM   #44
retrosmiths
help bump
2013 Scion FR-S
Old 02-15-2014, 05:33 PM   #45
FastWhite
Drives: Subaru BRZ Limited M/T
I'm hoping that when you say hand tightened only that you used a wrench and then hand tightened to an unspecified torque. Good n tight.
You wouldn't just hand tighten your wheel lug nuts now would you.
If the torque wrench doesn't fit, use a crowfoot and an extension, maybe use an extremely long extension, were there is a will there is a way.
Oh and you should answer yes to above question.
FastWhite is offline   Reply With Quote
Old 06-07-2014, 03:05 PM   #46
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Bump for updates!
How do you guys feel about your PMu pads? I wouldn't mind rebedding occasionally.
unsurety is offline   Reply With Quote
The Following User Says Thank You to unsurety For This Useful Post:
CSG Mike (06-07-2014)
Old 06-07-2014, 08:33 PM   #47
troek
troek's Avatar
Drives: 2012 Toyota 86
I have the HC-CS pads, and i love them. the pedal control is awesome. and i have zero noise on the street, 99% of the time.
troek is offline   Reply With Quote
Old 06-07-2014, 09:08 PM   #48
fstlane
fstlane's Avatar
Drives: BRZ Limited
Originally Posted by unsurety View Post
Bump for updates!
Here's my review which I updated today.
http://www.ft86club.com/forums/showp...8&postcount=18
fstlane is offline   Reply With Quote
Old 06-07-2014, 10:36 PM   #49
CSG Mike
CSG Mike's Avatar
Bump for updates!
Let us know when yuo're ready
Old 06-23-2014, 01:36 PM   #50
spitz
spitz's Avatar
Drives: '13 SWP BRZ-L
Hi everyone - thought I'd give a quick update on these pads. While I have been very happy with them on the street and track, they wore out after 3-4 track days (5 session days) and 5k street miles. For what it is worth, I consider myself an intermediate to advanced track day driver. I am hard on my brakes, but I don't abuse them.
Overall great brake pads - but I've learned that I should really separate my street and track pads. Moving forward, I'll be using stock pads for the street (maybe switch to a more aggressive pad once they run out) and swapping in CSG's WinMAX W4 pads for the track. I'll write a review about the WinMax pads once I get a chance.
spitz is offline   Reply With Quote
The Following User Says Thank You to spitz For This Useful Post:
unsurety (06-24-2014)
Old 06-23-2014, 02:04 PM   #51
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I feel the same. Mostly because I don't think I'll take full advantage of semi-race pads like these. Plus I've come to realize track days are expensive, and I may want to hold off on that. I love the bite they have though.
The main thing is the squealing. I still have to re-bed them, but I could not for the life of me get them to fade. At least not until traffic started showing up.
I'll be going to Winmax W2s for my next pads. For autocross and daily driving, they are perfect.
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
spitz (06-23-2014)
Old 05-19-2015, 01:20 AM   #52
DarkSunrise
DarkSunrise's Avatar
Did a track weekend with these pads and they were just ok. Initial bite felt soft. I think I was also getting pad fade a few laps in, as I'd have to press the brake pedal very hard to get adequate response. On the plus side, they never fell completely away, despite getting hot enough to smoke a bit after sessions. I was coming from Stoptech pads which had better hot bite, but faded noticeably and eventually smeared on the rotors.
It's not an issue tracking with these once I got used to them, but I was hoping they'd be more effective. I'll probably go a different direction once these pad are done.
Oddly I love them on the street. Great cold bite - they'll quickly engage ABS with minimal effort.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
hmong337 (10-07-2015)
Old 10-05-2015, 11:14 PM   #53
In1t
In1t's Avatar
Drives: Black Limited JDM BRZ
nice review, thanks!
In1t is offline   Reply With Quote
Old 10-06-2015, 10:09 PM   #54
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I also have an issue with noise with these pads. They've been great, but I'm having an issue bedding them in.
What have you guys done to bed them in? Mostly the 60 to 30 four times with 30 seconds in between works for most pads...
Old 10-06-2015, 11:01 PM   #55
troek
troek's Avatar
nooooooo, i went full throttle to 120kph full brake(no abs) to 20kph and repeat with no delay. I did this until i get brake fade then did 1 or 2 more.
The Following User Says Thank You to troek For This Useful Post:
CSG Mike (10-06-2015)
Old 10-07-2015, 01:35 AM   #56
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
My .02
I have used these for the street only for the last 2 years. I just replaced the front pads because they were just about down to the metal, but the rear pads still had 2/3 left so I'll replace them next time. I've never bedded them in, and simply used them normally. They carved so much metal off the stock rotors, there was a 1/16" lip on them, front and rear. Mine don't squeak, but they do make a scrubbing noise of rotor being sanded off with every stop. I replaced my stock rotors with Stoptech Sportstop drilled rotors from Tire Rack because grooved rotors eat the pad quicker then drilled rotors and they allow cooling airflow through the rotor in addition to braking better than stock, plain, rotors. They also look much cooler than grooved or plain rotors. I probably have about 20% more braking power than the same pads on stock rotors. I have an AT, so I won't be seeing the track anytime soon, but these work as a great street pad for me. I can live with the dust since my wheels are mostly black anyway. It's worth it to have brakes that work so much better than stock. I don't know how you people can go back to stock pads after using racing pads. There's just no comparison.
KoolBRZ is offline   Reply With Quote
The Following User Says Thank You to KoolBRZ For This Useful Post:
CSG Mike (10-07-2015)
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
Project Mu HC+800 Pads Anthonytpt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 04-08-2013 02:48 PM
Street/Clubsport brake pads for your BRZ and FR-S HP Autowerks Brakes, Suspension, Chassis 4 02-20-2013 01:34 PM
Street/Clubsport brake pads for your BRZ and FR-S HP Autowerks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 10-15-2012 07:03 PM
Different pads for street and track Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 08-01-2012 02:55 PM
