#141 |
Senior Addict
Drives: 86 GT
Thanks....that's reassuring. Yeah I've informed James and he's just sent me an updated map with slightly richer AFR to err on the side of caution.
#142 | |
Drives: FT86
#143 |
I never trust dyno widebands. I've seen them read anywhere from 0.5-1AFR point lean. Never seen one actually read the same as an installed sensor. No knock on that tune... still need to do some tweaking though. E-tuning OFT is a major PITA, very hard to 'get right' fwiw lol.
| The Following User Says Thank You to jamesm For This Useful Post: | Fizz (06-20-2014) |
#144 | |
Drives: White 2014 BRZ
Curious how accurate is the AFR reading from the ECU via the ODB port? Is it narrow band or wide? For example if you ran the torque app... |
#145 |
This isn't true, it stays in cl much much longer, changes over to ol from 5600rpm onwards. Interesting.
#146 | |
Drives: FT86
Re The E tuning with OFT (NA car) is something lacking in logging/parameters or accessible tables (but thats Romraider) ? or it it just E tuning in general as you have to wait for results and you carn't just fix things on the fly as soon as you see/hear/feel it like when car is on dyno or your driving it ? |
#147 |
Drives: 86 GTS
Did some logging of my stock tune on 98 (Shell), start of it is a 3rd into 4th gear run onto the freeway. Unless I'm looking at it wrong, this is showing the slight knock you talk about on stock tunes?
http://datazap.me/u/tech86/stock-tune-a01g-trimmed-log http://datazap.me/u/tech86/stock-tune-a01g-full-log (same thing with more parameters) |
#148 | |
It is actually adding timing back in.
#149 |
Drives: 86 GTS
The entire log was 5mb, have to do some more later with smaller windows.
#150 |
Senior Addict
Drives: 86 GT
Stock tune is very prone to knock even with 98 RON. It gets worse in summer....knocking everywhere. But a good tune can greatly reduce this. Alternatively you can run on 100 RON as this is known to improve things as well.
#151 | |
Drives: FT86
If your car is manual just flash the 98 ron tune in first post or 100 ron if you use United 100, if your auto just copy across the Base timing B table to your auto OFT tune That will pretty much eliminate the knock
| The Following User Says Thank You to steve99 For This Useful Post: | tech86 (06-23-2014) |
#152 |
Drives: gt-86 2013
torco octane boost
steve99 just wondering if using torco octane boost to bring up the octane ratting of my fuel would help with this fuel problem here in australia. That way might save a bit of knocking in these engines or am i incorrect.
![]() Thanks john |
#153 | |
Drives: FT86
Have you tried united 100 octane fuel ?? If you have non-ethanol 98 octane you can add 10% or so of E85 this can boost your octanne rating a couple of points. |
#154 |
Drives: gt-86 2013
we cant get e85 or your ron100 up here in cairns so my only option is to boost up the bp ultimate that we can get . might log a run then add torco when i get it and do another log then compare them.
| The Following User Says Thank You to myioz86 For This Useful Post: | steve99 (06-24-2014) |
| Knock Correction vs Knock Correction Learn values? | swift996 | Software Tuning | 19 | 11-03-2015 11:09 PM |
| Dynosty Fuel System Upgrades- Billet Fuel Rails!!! | Dustin@Dynosty | Forced Induction | 4 | 10-08-2014 11:00 AM |
| FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. | MmmDieselFumes | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 02-02-2014 09:19 PM |
| Fuel gauge misreading actual fuel in tank. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 10-09-2013 04:39 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 05:53 PM |
