Old 06-22-2014, 08:33 PM   #813
BadBRZ
Drives: Subaru
More info on the 18x10 +45 with a 285/30r-18 what does it take for this to fit realisticly. No i'm not looking for hella flush or any dumb crap, i want functional rubber for my turbo build
BadBRZ is offline   Reply With Quote
Old 06-22-2014, 08:39 PM   #814
BadBRZ
Drives: Subaru
Old 06-22-2014, 09:33 PM   #815
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
From my experience with about -2.3 degrees camber (I wouldn't go much more than this, and I may go with less now that I can.)
A 265/35 on a 18x9.5+38 rubs the fender/bumper joint where that plastic fastener is.
Move that to a +44 offset and everything clears, but the bracket that kinda keeps the e-brake cable along the trailing arm is less that a finger-width from the wheel.
Seeing that, a 285/35-18 on a 18x10+45 will need some slight modifications.
First, that bracket will have to be bent further in. Wheel will be 7mm closer than my current one, which will hit those brackets. Not a big deal, they bend relatively easily. The tire will clear inside fine.
Outside, the wheel is fine, but the tire will be 3mm further out than the 265 at +38. That will mean more rubbing at that joint. I haven't looked too closely at how important that fastener is. If it isn't too important, you could dremel it and some of the bumper lip below it. If it is, you may need to do a slight pull to that area of the fender.
Now, less negative camber will mean more work on the outside.
It looks like to me that 285/35-18s are possible. But I think you could go with 275s for a lot less hassle with no appreciable loss of rear traction. Hell, if you're focused more on drag racing than AutoX/Trackdays you could probably do just as well with 265 drag radials and a lot less negative camber than you would with a wider tire and more.
Old 06-22-2014, 10:29 PM   #816
BadBRZ
Drives: Subaru
285/30r-18 not 285/35r-18 thats alot different on diameter
Old 06-22-2014, 10:34 PM   #817
Draco-REX
Corner Junkie
Draco-REX's Avatar
Very true, but the same width. I'm not sure how that would change the outside rubbing however. My tire rubbed on the shoulder between the contact patch and the sidewall. So a smaller diameter would help clearance, but the width might push it back towards a taller part of the tire.
I think it'll still rub a little bit. You might get away without having to do much of anything on the outside. The brackets on the inside will still need to be bent since it's a wheel issue.
Old 06-22-2014, 10:39 PM   #818
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
you need coilovers, an 18x10.5/11.5 +42-35 ISH i think plus a 285. obviously need control arms toe arms bolts adjustable top hats. rolled trimmed rear, rolled front.
gotta look into it some more.
Jive Turkey is offline   Reply With Quote
Old 06-23-2014, 12:16 AM   #819
BadBRZ
Drives: Subaru
You can't run 285 30's on an 18x10"?!? I prefer minimal poke and as little camber as i can get away with. Maybe a 1" drop again no slamming no super low no hella flush dat life yolo crap ;-P
Old 06-23-2014, 01:14 AM   #820
dabocx
dabocx's Avatar
Drives: Scion FRS
Going to order my Advan TC3s still debating on 265s or 275s but hopefully ill get some photos up for you all soon.
dabocx is offline   Reply With Quote
Old 06-23-2014, 09:33 AM   #821
Jive Turkey
the tuna, no crust.
you can run it on an 18x10 sure. it all depends WHAT tire.
dont get cought up in the size. from what i notice the increase in contact patch from a 265-285 isn't much more in the MPSS zII tire category...but you get a lot more weight added on. honestly with a GOOD tire you wouldn't need more than like a 275 in the rear to hook up in a boosted car.
Old 06-23-2014, 09:49 AM   #822
loogs
Drives: on cruise control
18x8.5F/18x9.5R "Semi-Staggered" with 255/35-18F and 265/35-18R.
the 255 on a 8.5 looks amazing. great job
loogs is offline   Reply With Quote
Old 06-23-2014, 10:07 AM   #823
BadBRZ
Drives: Subaru
R888's ... square set up 400whp boosted car ..
is a 18x10 285/30 r18 possible?
How would it compare to a 17x9 255/40 r17?
Old 06-23-2014, 06:55 PM   #824
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
rims are delivered today.
Iv waited for about 3 months.
Pressed Graphite color.
18X9.5 +40 .
5X100 .
18lb
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
The Following 3 Users Say Thank You to Figo For This Useful Post:
Goya (06-24-2014), Kace (06-23-2014), nlamon33 (06-23-2014)
Old 06-23-2014, 07:33 PM   #825
nlamon33
nlamon33's Avatar
Drives: 2013 SWP BRZ Limited
18X9.5 +40 .
5X100 .
18lb
Ew replicas. Should have saved and gotten some Rotas. bwahah jk I might be a tad bit envious.
nlamon33 is offline   Reply With Quote
The Following User Says Thank You to nlamon33 For This Useful Post:
Figo (06-23-2014)
Old 06-23-2014, 07:35 PM   #826
Figo
Figo's Avatar
I am using rota now and they are actually good for DD.
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
