Old 04-09-2012, 02:52 PM   #57
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Originally Posted by chulooz View Post
just need to be able to reach the valve.
That is my point. If the car doesn't have the ground clearance you won't be able to without having it on a lift or ramps.
tranzformer is offline   Reply With Quote
Old 04-09-2012, 03:54 PM   #58
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
are these fumoto valve pretty solid for build?
I would hate to throw one on and have it leak within a few years
I don't know about getting one of these fumoto valve with the nipple if you are going to lower the car more since it looks like the nipples do stick out under the car
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 04-09-2012, 04:05 PM   #59
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
Actually they don't stick out, it wont affect ground clearance, at least that's the case for my car... don't know about the 86. And they seem to be quality built
A real corker - If life is simply a process of trying to keep your hands clean, this little gadget from Japan will help. It replaces your oil drain plug and has a spring-loaded valve so you can drop the dirty lube quickly and without tools. We put a sample valve through the Auto Week stress-test and discovered that the valve was a quality built item, the polished valve and tight seals, and a locking feature. It withstood many hours of opening and closing. - "AutoWeek Magazine"
I wish I was cool enough to have an FR-S
blur is offline   Reply With Quote
Old 04-11-2012, 04:34 PM   #60
ZSwierczynski
ZSwierczynski's Avatar
Drives: A hotwheels car
When you work at a dealership, you see all the "mistakes" the lube techs and techs might and sometimes do mess up. I don't want my car with anyone except me if I can do the change.
I put my car in the garage and grab some jacks to lift it in the air just a bit to get under. Then I change my synthetic(Amsoil and I rotate my tires every other change. I know I should rotate them every time but I am at 38,800(ish) miles and my thread is still pretty good. It looks like another 6-7 months left on the thread on my tires til I got to get them replace.
ZSwierczynski is offline   Reply With Quote
Old 04-11-2012, 05:49 PM   #61
Chenslee
Chenslee's Avatar
Drives: 2015 Halo FR-S
I've had my share of bad experiences at lube shops. Half-assed attempts to wash my windows with oily rags, unwanted washer fluids, loose drain plugs, and one time the guy yanked the parking brake and screeched my car back to me. Another time the oil nozzle got jammed in so hard it bent a flange under the valve cover and was rubbing on a lifter. Those are just MY examples, I've heard plenty more horror stories. With $5000+ of engine at stake and no clear way to prove that a shop caused the damage, I'll continue to change my own oil, thank you.
Chenslee is offline   Reply With Quote
Old 04-11-2012, 06:00 PM   #62
Joe@Amsoil
Drives: Evo 9
Glad to see a lot of Do It Yourselfers in here!
Joe@Amsoil is offline   Reply With Quote
Old 04-11-2012, 06:12 PM   #63
OrbitalEllipses
Drives: Attitude
You should stop the the Break-in Procedure thread in the Engine subforum, we could use input on topics like "break-in oil".
Old 04-11-2012, 06:15 PM   #64
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
I too would like to hear your feedback as well!
http://www.ft86club.com/forums/showt...?t=1036&page=8
Old 04-11-2012, 06:59 PM   #65
Joe@Amsoil
Drives: Evo 9
I'll take a look!
Old 04-11-2012, 08:44 PM   #66
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by powertrip View Post
Extremely reliable. Just get a good pair of chalks to put under the rear wheels after you drive up and set your e-brake. It's as safe as using jackstands but only takes a few seconds to get up on and less risk due to rocking. You can get a good pair for under $50 at any local auto store and they are compact sized. As always make sure you only use it on level surfaces.
Thanks for the input.
Old 04-11-2012, 08:52 PM   #67
Giccin
Giccin's Avatar
I want to get the fumoto valve for oil changes how but... I friggin' not sure if I want/need the adapter.
And... since manual in my car was taken by my dad I'm not sure what lug size the oil bolt is. Lol
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 04-11-2012, 09:14 PM   #68
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
I change my own oil because I like the satisfaction of knowing that everything has been done completely correctly, and with the high-quality components I specify.
Subie is offline   Reply With Quote
Old 04-11-2012, 09:20 PM   #69
86design
Attack By Demons
86design's Avatar
Drives: 2022 BRZ (pre ordered)
I always do my own oil change...but for some reason I'm lazy to do my daily cars....i guess its cause I dont really care for them as much...but when i get my BRZ oil changes are going to be fun!!! lol
#attackbydemons #imcomingbackbish
86design is offline   Reply With Quote
Old 04-11-2012, 09:22 PM   #70
Subie
Señor Member
Subie's Avatar
The oil filter is so easy to get to, too!
Forum owner should change the top left image of the forum Hanzo Off-Topic Lounge [WARNING: NO POLITICS] 68 01-27-2012 10:33 PM
Petition to change grey market import age to 15 years.. Dave-ROR Off-Topic Lounge [WARNING: NO POLITICS] 24 11-21-2011 06:31 PM
How do you think toyota will change in the following years. LexusFman Other Vehicles & General Automotive Discussions 19 11-08-2011 03:19 PM
is this a change in society, a revolution if you will? VenomRush Other Vehicles & General Automotive Discussions 14 05-11-2011 07:27 PM
