Old 06-17-2014, 07:05 PM   #29
jdmblood
jdmblood's Avatar
Drives: white subaru brz
that evo 8...
jdmblood is offline   Reply With Quote
Old 06-17-2014, 07:58 PM   #30
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
Originally Posted by Roxy86 View Post
I thought C&R was based out of IN?
We are. I am out here lone wolfing it as a West Coast sales rep/sales engineer/design engineer.
Originally Posted by jdmblood View Post
that evo 8...
I miss her too, that car was always fun to drive. Some more of my favorite shots with her.
eric6 is offline   Reply With Quote
Old 06-20-2014, 02:49 AM   #31
eric6
eric6's Avatar
Put some time in on the computer getting the mocked up splitter ties in. Should turn out pretty nice looking once we produce them.
Windows tinted!!!! (not a good picture)
Finished the exhaust. The whole system weighs 8.4 pounds. I think I'll add some nice tips to it as well.
Old 06-20-2014, 11:55 AM   #32
Shedd22
BAMF
Shedd22's Avatar
Drives: 2014 SWP BRZ
I'm a mechanical engineer also (graduated last year). I've been working on designing/tweaking some parts too. Haven't gotten around to doing much FEA but did some vibration testing. Haven't made a build journal yet since I bought my car two months ago. I'm interested to see what you do..maybe it'll help me in my designs. Good luck!!
Shedd22 is offline   Reply With Quote
Old 06-20-2014, 09:51 PM   #33
eric6
eric6's Avatar
Sounds good, have fun with it. That's the reason I do this, I enjoy it.
I took some daytime photos of the exhaust and drove around with it for about 50 miles. It's got a nasty resonance at 2-2.5k RPM, I will be adding a helmholtz tube to stop this. Other than that it sounds pretty good and weighs 30 pounds less than stock!
Likely will be adding some tips to this, thoughts?
The Following User Says Thank You to eric6 For This Useful Post:
J. O'Grimm (07-01-2014)
Old 06-21-2014, 12:06 PM   #34
Shedd22
BAMF
Shedd22's Avatar
Yes to tips.
The Following User Says Thank You to Shedd22 For This Useful Post:
eric6 (06-21-2014)
Old 06-21-2014, 12:47 PM   #35
inertia
inertia's Avatar
Excellent welding skills man!
inertia is offline   Reply With Quote
Old 06-21-2014, 06:55 PM   #36
frsvr4
Drives: '13 FRS
Any details on the vibration testing? Frequency, acceleration levels/profiles, duration?
Eric, it looks like you use SolidWorks. Have you used it for vibration analysis beyond simply determining natural frequencies?
I <3 this thread
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135
frsvr4 is offline   Reply With Quote
Old 06-21-2014, 07:20 PM   #37
gramicci101
Off Topic
On your MR2, what's the black gear-looking thingy (technical term) between your intercooler and the RacerX manifold? Are there any drawbacks to having an aluminum exhaust? Also, if you need another bike, I'm selling mine.
Old 06-21-2014, 07:46 PM   #38
eric6
eric6's Avatar
Yes to tips.
Yep, it doesn't look finished. At first I liked the Lamborghini kinda look but it needs something there.
They're far from excellent but thank you .
I <3 this thread
I use Solidworks for home stuff, I use ProE and Creo for work. I have not used vibration analysis actually. I typically FEA parts while my friend does most of the CFD stuff. Personally, I like designing nice looking parts, I'm a design guy . My friend/partner is the true genius with CFD and other analysis.
That is the throttle cable wheel of a humongous 90mm RMR throttle body. Yes, aluminum does melt at ~1100-1200 degrees and is considerably more susceptible to cracking, corrosion, and possibly melting. If done right, I don't see an issue arising for many years to come. I would be surprised to see an issue with anything under 60k miles, but that is an estimate. Time will tell .
Please let me know what you have and how much... you aren't far from me.
frsvr4 (06-24-2014)
Old 06-21-2014, 08:06 PM   #39
gramicci101
Off Topic
Ah, for some reason a throttle cable didn't occur to me.
Ok, so it would need to be steel until the temperature dropped off enough, then switch to aluminum? Are you going to have it anodized to prevent corrosion? Since you have the ability to remake it if it breaks, it should do you very well.
bike
Old 06-21-2014, 08:41 PM   #40
eric6
eric6's Avatar
bike
Here's a few more photos. I really need to rebuild the whole intake manifold side of things to make it cleaner but no time right now. Been waiting for my engine for 1.5 years .
Correct. On the MR2 I went right after about 24" of downpipe to aluminum. No issues, but the turbo sucks a lot of energy and thus heat out of the engine. With our cars, I think everything from overpipe back could be aluminum. I want to measure temps before I go that far forward. I don't anticipate many issues with this exhaust.
Thanks for bike link.
Old 06-21-2014, 09:04 PM   #41
gramicci101
Off Topic
Will you be making a diffuser to cover the hole left by the OEM muffler and prevent any kind of parachuting effect? I read somewhere that the OEM muffler was an active part of the underbody aero on our cars.
Also, that throttle body is enormous! I can see how the original one would be a restriction.
The Following User Says Thank You to gramicci101 For This Useful Post:
sittinSideways (08-18-2014)
Old 06-21-2014, 09:37 PM   #42
eric6
eric6's Avatar
Forgot to say, if I can help make any of your parts come to life, let me know. I recently graduated as well (2013) and we gotta watch out for each other .
I haven't thought about a diffuser yet but I probably need one. With how large that muffler was, I have no doubt that it helped keep air going out the rear instead of getting lost in the bumper. It's on the very long list, I don't race the car (yet) so I'm not worried about it.
Yes, that throttle body is huge. The one it is sitting next to is 75mm (3" dia.). I "upgraded" because I got tired of rebuilding the 75mm. I don't think that throttle body was built to handle 28psi . Seals on the throttle shaft kept blowing out.
Shedd22 (06-22-2014)
Ericmpena's SWP BRZ ericmpena Member's Car Journals 32 08-28-2016 01:01 PM
Engineers Certificate needed for turbo kit? happytimetom Forced Induction 18 02-23-2014 05:47 PM
Eric @ Beat-Sonic tysoNgwaNg User/Vendor/Sponsor Reviews, Feedback, Comments 0 12-15-2013 08:33 PM
Software and electrical engineers look here jonbonazza Engine, Exhaust, Transmission 6 09-15-2013 11:06 PM
Scion test engineers can't drive (Hyundais) holmesbrz Scion FR-S / Toyota 86 GT86 General Forum 23 02-28-2012 02:11 AM
