#29 | |
#30 | |
Drives: AE86, 2x GT86, TE27
Some people are working to a budget. I certainly was when I had my first couple of silvias. Spending $1500 on a mechanical LSD was the last thing I was going to buy, when I could weld it up for effectively nothing. Having my welded diff chirping around a car park was a small compromise in my eyes, for the realiability and predictabilty it gave while using it for drifting. |
#31 | |
![]() However, comparing that to a mechanical clutch type LSD was a very nice experience as well. While Torsen works great for what it does, I do desire more at times, hence the recommendation of the clutch type LSD.
#32 |
Drives: '23 BRZ
Tight diff in general requires more rear roll stiffness to counter the understeer, which unloads the inside rear more, which requires still more diff tightness! Can be kind of a vicious circle.
I remember pushing a friend's ITS 240Z with a "Kennesaw locker" (welded diff) in the pits, when he cranked in a little steering, the car just stopped! This cannot be good for handling, thought I... Point: there's more than one way. I don't think a tight clutchtype diff is necessarily necessary for putting the power down at the track. Some approaches and some driver preferences will lead that way though. |
#33 | |
In this case, we have actual data that proves the settings we were looking for worked exactly as intended. The OTS settings in the past locked up a little harder than what we wanted.
#34 |
I did do some circuit days with mine prior to the 2 way.
I'm no CSG level driver (not a dig, I'm not) but I noticed almost straight away the 'auto-lsd' type aid the car has. Definitely not good for corner exit speed. A few of us in NZ have 2 ways now, and what becomes apparent when you go from a torsen equipped car to a mechanical equipped car, is how much more the mechanical equipped car seems to spring out of corners better. Where as in realty, its the torsen equipped cars that are being held back by the car. |
#35 | |
Drives: '23 BRZ
#36 | |
#37 |
Realistically, having a CSG spec'd diff is a golden opportunity for most. Because its going to be based off real world data, using the good drivers and this car.
Its a not brainer to get it if you.. Are a circuit guy Not really sure how to set a diff up (most poeple don't) Don't have the time/money/desire to pull the diff out and try different settings (almost NO one does) If I was going to focus on circuit I would buy a pre specced CSG diff, purely for the R&D put into it's settings. |
#38 |
i'm sorry, what?
Drives: Canada
how much would an autocross spec dif differ from a circuit type, I wonder?
would one aim to have more lockup for easier rotation by throttle?
#39 |
That Guy
Drives: 2013 asphalt FRS MT
After reading Mikes first post my only question was, 'why aren't you trying to load up the unloaded tire to prevent the wheel spin instead of ****ing around with the diff? CSG already has the ability to adjust rear roll stiffness.'
Of course, my question has already been answered in that it comes down to personal preference. But along the way I've learned yet more about the artistic side of suspension setup. Thanks guys! |
#40 | |
Drives: '23 BRZ
Which is one reason I'm kind of philosophically opposed to tightening up the diff. You're adding work to the tires that is trying to make the car go straight. My approach would be to try to make the car work with as little diff preload/tightness/lockup as possible. |
#41 | |
But past apex, you want to get the power down, and being able to do that is more important than a little more push understeer at that point; because more often than not you'll be able to accomodate it. |
#42 |
With a low powered car, you'll spend a lot of time trail braking to rotate the car and get on the gas as long as possible. Many times the car may be experiencing a slip angle and potentially lifting a wheel just enough so the contact on the pavement is not as well loaded as it should be. In these times, data has shown that a true clutch type LSD has allowed us to grip and power through those corners. The experiences we've had with the Torsen is that you get times when the engine suddenly just revs up kind of awkwardly indicating a certain level of slip. Usually these places are off-camber corners or sudden uphill/downhill drops that cause an off balance of weight transfer. With the proper suspension setup, the wheel still maintains contact with the pavement, but it's still not as loaded as it should be. We say proper because many well known setups have notorious pictures of cars 3-wheelin' or 2-wheelin' through these corners.
![]() With that said, driving with a 2-way, 1.5-way, and 1-way all require a slightly different driving style and setup. You can almost say that the 2-way and welded diff setups require you to "drive harder" while feeling incredibly stable. It's actually a pretty cool feeling if you get the car to dance properly.
| Tags |
| uberstupid |
| High-G Cornering Fueling Solution | EAGLE5 | Tracking / Autocross / HPDE / Drifting | 24 | 02-22-2017 08:04 PM |
| cornering-on-rails feeling | notout86 | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 09-20-2015 07:00 PM |
| Engine cutting power after hard cornering... | CSG Mike | Tracking / Autocross / HPDE / Drifting | 19 | 07-04-2015 08:40 AM |
| Traction control light comes even when not hard cornering? | Yamajee | Issues | Warranty | Recalls / TSB | 26 | 04-10-2014 01:04 PM |
| Anyone have the radio switching modes during hard cornering?? | silvercar | CANADA | 4 | 07-08-2013 12:49 PM |
