Old 06-19-2014, 09:41 AM   #1569
FR-S Matt
So in regards to the whole checkvalve thing as I tried to read it again. Is this something I need with the Radium dual can setup? I read they are pressurized already. Also, did we confirm the size of the valve we need and this is on the hose from the crank to the intake? I'm about to install my catch cans, hose clamps this weekend before the SC goes on.
This may be worthy of another thread, honestly.
Old 06-19-2014, 11:14 AM   #1570
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It isn't a question of whether the catch can can take being pressurized, the question is whether you want to pressurize the crank case. I would say no.
FR-S Matt (06-19-2014)
Old 06-19-2014, 11:25 AM   #1571
TmP
TmP's Avatar
Drives: A bunch of 'em...
If a check valve is needed, why isn't there one in the kit?!
TmP is offline   Reply With Quote
Old 06-19-2014, 11:29 AM   #1572
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
You'll want to place the check valve between the intake manifold and catch can. Make sure the valve is allowing air to flow from PCV to Intake Manifold and not the other way around.
Like tut said, the purpose is to stop your crank case from being pressurized. You could technically place the check valve on the other side of the catch can, but I don't think many cans are designed with taking positive pressure in mind. It's easier to just put the check valve after the can and not worry about it.
As for size, I think it's 1/2" inside diameter at the intake manifold but steps up to 5/8". I could be mistaken about that though.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
Old 06-19-2014, 12:38 PM   #1573
FR-S Matt
Thanks for the clarification! I'll be adding this in with the install.
Like @King Tut said, I think this is more of a precautionary measure, not a requirement. Kind of like the hose clamp solution. It makes sense as long as the valve does its job.
Now to make sure I put the valve in the right direction.
The Following User Says Thank You to FR-S Matt For This Useful Post:
protpibe (06-19-2014)
Old 06-19-2014, 12:42 PM   #1574
Freeman
Freeman's Avatar
Which kit? The catch can kit?
Freeman is offline   Reply With Quote
Old 06-19-2014, 12:47 PM   #1575
protpibe
protpibe's Avatar
It being needed is kind of debatable.
A lot of people don't run them, but I chose to personally. The OEM PCV valve is not meant to handle boost so it will let pressurized air into the crank case. The Vortech kit comes with a check valve but others don't, for whatever reason. They're only a few bucks so it's not that big of a deal to pick one up on your own
Old 06-19-2014, 12:57 PM   #1576
TmP
TmP's Avatar
Not that it's a big deal, it's just curious why KW doesn't think it's needed.
Old 06-19-2014, 02:05 PM   #1577
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Just a quick FYI for those that purchased their kits from the group buy, Skunk2 has released their Pro-C Coilovers for the BRZ/FRS. Your discount/coupon/promo code is valid on them... call or email them for pricing.
We're not trying to "thread jack" and/or turn this into a suspension discussion... Just a heads up. Back to the topic at hand, BOOST!
KraftWerks is offline   Reply With Quote
The Following 4 Users Say Thank You to KraftWerks For This Useful Post:
86SPEED (06-20-2014), lightdir (06-21-2014), NCItaly (06-19-2014), Taino-BRZ (06-19-2014)
Old 06-19-2014, 03:33 PM   #1578
ST-A
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
we also just finished installation of the KW kit, but we had to make a few mods.
because we are located in Europe , the GT86 comes with HID lights stock and so is equiped with a high pressure washer system.
Things we needed to modify:
- KW washer bottle, we needed an extra hole for the headlight washer pump
- intercooler cold side was hitting the washer nozzle, it was either the ic pipe or the nozzle, so we modified the intercooler piping
now we need to figure out a custom tune because we are using the OFT.
we also have SARD header, SARD cat pipe, milltek exhaust and mishimoto low temp thermostat.
pictures of the build can be found on our fb page:
https://www.facebook.com/media/set/?...8047905&type=3
Any tips on priming the rotrex oil system? did you guys really deconnected all injector clips like the manual says ?
For the tune, do we NEED an upgrade map sensor like they come with the ecutek package or can we just go with stock MAP and rescale MAF ?
ST-A is offline   Reply With Quote
The Following User Says Thank You to ST-A For This Useful Post:
The Sentinel (01-15-2015)
Old 06-19-2014, 03:56 PM   #1579
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Prime the rotrex by putting 100% gas pedal down and attempt to start the car. This is anti-flood mode and the car WILL NOT START. This will allow you to turn it over without flooding it. Do not take your foot off of the gas when attempting this, keep it pegged to the floor. Let it turn over a couple of times and turn it off. Let the starter cool down.
post_break is offline   Reply With Quote
The Following User Says Thank You to post_break For This Useful Post:
Old 06-19-2014, 04:04 PM   #1580
TmP
TmP's Avatar
If this isn't a joke, it's good info
Old 06-19-2014, 04:09 PM   #1581
post_break
post_break's Avatar
[ame="https://www.youtube.com/watch?v=hyFAnJbsoXM"]Caliber SRT4 Clear Flood Mode - YouTube[/ame]
Obviously not our car, but it's the same thing. If you're too scared to do that pull the HPFP fuse, yellow 20 amp under the hood.
Old 06-19-2014, 04:12 PM   #1582
ST-A
Master Tuner
thank you
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
