#71 | |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
![]() But..you think you can at least tell us which other Japanese/German coilover companies use your same parts/suppliers? (no need to tell us the actual, exact, top-secret supplier info) ...just tell us something vague, like: eg: tein uses the same upper pillowmount and shock body, hks uses the same strut mount, ohlins uses the same shims, kw uses the same shaft, etc. ...if you can't, it's cool... I just thought it woulda been cool to know which certain parts on an FA coilover were as good as other popular more expensive japanese/german coilovers. |
#72 |
Drives: 2014 brz
Dark card...any chance you have a better pic of the sheared off shaft? The type of failure I am seeing is the most likely due a crack starting the root of the thread possibly cause by a significant impact some time ago. I've seen this type of failure on other threaded shafts because it's the weakest point due having the highest moment because of its location and thus having the highest cyclical loading. I can see a part of the shaft cross section that has a small bit of corrosion and different areas that have different surface finished and textures. The finishes/textures tell the story of where the initial crack started, propagated due the cyclical loading, and finally failed.
Just my 2 cents since I didn't see a posted explanation. |
#73 | |
Drives: 1997 Eagle Talon TSi AWD
#74 | |
i'm sorry, what?
Drives: Canada
#75 |
Haha
..my bad.
#76 | ||
Drives: 2005 Toyota Camry
http://www.fortune-auto.net/termsconditions.htm Quote:
Does anyone care to clarify? Because "5 years" can be "5 minutes" as far as any prospective owners are concerned, when it comes to legal text. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | Jason@DSG (03-25-2014) |
#77 | |
I'm glad you brought this up. I'm going to have Fortune Auto clarify everything so there's no vague terms. As a side note, they've warrantied and helped for every issue (honestly, VERY few issues with FA coilovers and FA) that we've come across. They're a really great company, as you can see from their reply and the fact they are replacing the OP's set. Cheers, Jason |
#78 | |
Drives: Evo
We warranty our parts no matter where they are used. There has never been a single instance that we have not warrantied a part that was under warranty and used on the street. The only thing that we will not warranty are collisions (on track or on the street). We can immediately determine if the suspension was involved in a collision. If you have any further concerns about our warranty policies, you can call our tech support team directly and they can walk you through it. We are not trying to deceive anyone here, just covering our bases
| The Following 4 Users Say Thank You to Jenson May For This Useful Post: |
#79 | |
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
#80 |
| The Following User Says Thank You to Jason@DSG For This Useful Post: | Jaylyons1 (06-19-2014) |
