Old 06-18-2014, 06:19 PM   #1891
Netrunner
Newb
Netrunner's Avatar
Drives: 2014 BRZ SWP
Fair enough, is 50 miles enough to get a good log? Not trying to be difficult, just truly don't know how the ecu learns and how fast.
Netrunner is offline   Reply With Quote
Old 06-18-2014, 06:21 PM   #1892
Malt
Drives: 2015 WRX
50 is probably the minimum for a log to show information that is useful. Obviously the longer on the flash, the more time your trims will have had to stabilize.
EDIT: Also you can change what you log. It probably would be helpful to log FLKC and knock correction instead of VVT intake and VVT exhaust. If you are seeing some knock correction or FLKC then that would explain why your IAM is below 1.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
YEAHdams (07-29-2014)
Old 06-18-2014, 07:57 PM   #1893
Netrunner
Newb
Netrunner's Avatar
For the sake of science, I took another log after 40 miles total on the tune this time logging FLKC and KC. The adv multiplier is now at .72. So we're headed in the right direction. Thanks Malt for the advice, I'll log again at 75 and then 100 miles.
http://datazap.me/u/netrunner/2nd-lo...1432&mark=1257
The Following User Says Thank You to Netrunner For This Useful Post:
Old 06-18-2014, 08:09 PM   #1894
steve99
Drives: FT86
To speed up learning do about 3 easy steady partial throttle (not wide open) runs in 2nd or 3rd gear from about 2000 rpm to 5000 RPM and your IAM will get to one.
the knock looks pretty minimal, but with your driving below 2500 rpm steady throttle then just going WOT to the higher rpm the ecu is not getting to learn, it learns much faster in "closed loop mode " ie steady throttle driving/cruising (non wide open throttle) but you just need to up the rpm a bit while your cruising.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Kronos (06-18-2014), YEAHdams (07-29-2014)
Old 06-18-2014, 10:25 PM   #1895
Netrunner
Newb
Netrunner's Avatar
Steve is smart
http://datazap.me/u/netrunner/third?...1-2-10&solo=10
Does everything else look ok now?
Thanks
Old 06-18-2014, 10:47 PM   #1896
steve99
Drives: FT86
Steve is smart
Thanks
Yeah look pretty good, shiv tune always run on the rick side higher rpm your high 11's so that pretty standard for oft tunes
there is a very small amount of knock about 6400-6500 and a bit about 6700 rpm see the chompy bits out of the kc learned curve. The FLKC logging is still not working but you can work it out from kc learned. Looks like is only about -0.7 degrees so it probably ok and the fine learning knock control will probably sort that after a bit more time if it keeps happening.
http://datazap.me/u/netrunner/third?...zoom=1269-1383
Did a thread on knock control here
http://www.ft86club.com/forums/showt...ock+australian
Old 06-22-2014, 07:03 PM   #1897
k.houan
k.houan's Avatar
Drives: BRZZZ
Is it normal for my ltft to be around 15 at idle? Im on my second tank of e85 and noticed that my ltft rose compared to my first tank which stabilized to lower than 10 which Ive read would be safe. Should I reflash and start again?
k.houan is offline   Reply With Quote
Old 06-22-2014, 07:10 PM   #1898
Malt
Drives: 2015 WRX
That's not normal. Do you have an aftermarket intake? LTFT's should be +- 5%
Old 06-22-2014, 07:45 PM   #1899
BolognaWalrus
Drives: too soon junior
Just picked up my OFT today. So I'm using the B01C map, can I upload the A01C map with LC, FFS, and the rest? OFT won't even let me put the A01C map on the device itself?
BolognaWalrus is offline   Reply With Quote
Old 06-22-2014, 07:55 PM   #1900
Malt
Drives: 2015 WRX
No. You have to use the maps for your CalID.
BolognaWalrus (06-22-2014)
Old 06-22-2014, 08:03 PM   #1901
k.houan
k.houan's Avatar
Drives: BRZZZ
No stock intake, recently installed a hks drop in filter though. What should I do?
Sent from my LG-E980 using Tapatalk
Old 06-22-2014, 08:05 PM   #1902
Malt
Drives: 2015 WRX
I'm not saying you have an exhaust leak, but those trims are exactly like what I had when I was running E85 and had an exhaust leak.
Old 06-22-2014, 08:11 PM   #1903
k.houan
k.houan's Avatar
Drives: BRZZZ
Interesting. I really don't think I could possibly have an exhaust leak. Could it be the filter? I made sure it was installed correctly and sealed properly. I really don't know what to do. Can i damage the engine running this way?
Old 06-22-2014, 08:16 PM   #1904
Malt
Drives: 2015 WRX
The first thing I'd do is take some logs and post them up to datazap. People much smarter than me could look at your logs and determine if there really is an issue.
Sent from my SCH-R970C using Tapatalk
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
