Old 06-18-2014, 04:49 PM   #15
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
You will be good with KW V3. Looks at mine. I even have a body kit, which affects front clearance.
You will be good if you just want your car looks like the one in the pic. You can drop more, and you will not have any problem once you learn how to drive a dropped car.
For wide front tires you need more negative camber, so u might need top mounts.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 06-19-2014, 12:52 AM   #16
AutoRnD
AutoRnD's Avatar
Drives: Fast ones
The KW V3 can go really low if you use your stock uppermounts. If you go with aftermarket uppermounts you might lose some drop. My suggestion would be to go with a manufacturer like RCE who has likely designed their mounts to retain suspension travel rather than limit it.
AutoRnD is offline   Reply With Quote
Old 06-19-2014, 09:13 AM   #17
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
no, you dont need aftermarket top hats, all of mine have been OEM (group-N)
i run a 265 RE11 square
Jive Turkey is offline   Reply With Quote
Old 12-29-2014, 02:51 AM   #18
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Preferred adjustment on kwv3, stock wheels, no spacers ....
mswbrz is offline   Reply With Quote
Old 01-21-2015, 12:47 AM   #19
FRSGT86
FRSGT86's Avatar
Drives: 2013 Raven FR-S, 2005 Dodge Ram
KWv3 Max low
Here's mine on V3s
This is with stock top hats and rear LCAs, so no camber adjustment.
I just put RaceSeng CasCam plates on the front and SPL adjustable LCAs on the rear and I'm hoping to get an alignment this weekend. The show stopper will be whether or not my car can get on the alignment rack.
2013 FRS 6AT in Raven!
FRSGT86 is offline   Reply With Quote
Old 01-21-2015, 01:06 AM   #20
Koa
Originally Posted by Jive Turkey View Post
let me chime in here as i had v3's on my BRZ. at my lowest height i had no gap in the front and was almost tucking tire (i have 265's). i recommend other suspension ad ons if you want to drive the car at that height and have any kind of good handling characteristics.
now, driving this car low isn't that hard, just angle EVERYTHING. with that said, KW isn't really hte slam your car coild over, as posted above get taiwanese stuff for slamming a car.
with all that said, the v3's will get you pretty low, i had maybe another 1/2" to go in the front if i wanted to be cool
here is a picture of how my car sat for a week or two being "low"
the frs you posted looks like its on 17's though. i'm on 18's with a big tire (i dont believe in stretch)
p.s. my kw's are actually for sale if you're looking for a good deal/a mint set. look up my threads if you have more questions, i was running whiteline com-c tophats, with other tophats you will probably be able to go lower...
clean, clean car
FS: Socal: KWV3 YDNA Brakes, Suspension, Chassis 16 05-15-2014 10:09 PM
KWV3 | Vossen 19" CV3 | Subaru BRZ danielle@vossen Wheels and Tires 12 03-03-2014 01:17 AM
kwv3 settings bjun Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 02-28-2014 10:23 PM
kwv3 coils bjun Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 11-27-2013 01:17 PM
WTB: KWV3 Coilovers wahsaihin Canada Classifieds 2 10-28-2013 02:37 PM
