Drives: 2013 BRZ Sport Tech White Pearl
Nameless header install
Damn rust in Atlantic Canada.
Trying to unbolt the intake manifold from the downpipe... First of all can't get my ratchet in there because of the cat and tried to take the cat heatshiekf off but that's rusted a bunch. On the way to my buddies to get a 14mm wrench while the bolt loosner soaks in a bit too. Going to try warming the car up to heat up the bolts when I get back. Any other ideas? |
#2 |
Drives: Subaru
I have no idea how your intake manifold became bolted to the downpipe but you might want to check on that first...
as far as rusted bolts, PB Blaster is above and beyond the best... |
#3 |
Err sorry exhaust manifold.
#4 |
That guy
Drives: Ultramarine mt FR-S
A ratcheting box wrench made very short work of getting the bolts loose for me.
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
#5 |
Drives: 2014 Pearl White BRZ
Swearing helps!
#6 |
Got it off with some PB Blaster type stuff .
Now to try and fix this awful exhaust leak. I'm running the stock overpipe. |
#7 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
^Those should do the trick. http://www.grimmspeed.com/grimmspeed...st-gasket-set/ ^If you want the set |
#8 |
Thanks man.
I'm going to try to use a combo of the stock gasket and ones nameless supplied tomorrow night and if that doesn't work order the grimspeed. |
| Openflash+Nameless Header | Brahsbrah | Software Tuning | 86 | 04-18-2015 06:26 PM |
| FS Nameless header in Queens NY | Imsteak | Engine, Exhaust, Bolt-Ons | 1 | 06-17-2014 02:04 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
| Nameless EL Header | LPC_FRS | Mid-Atlantic | 16 | 03-20-2014 04:42 PM |
| Header - Nameless vs JDL | Kodename47 | Engine, Exhaust, Transmission | 36 | 05-06-2013 10:12 AM |
