Old 04-11-2012, 12:47 AM   #29
2fast4you
2fast4you's Avatar
Drives: 2006 Scion tC RS 2.0
remap ECU will fix that dip
However, the question is: will you lose elsewhere to fix the dip?
Brake. Turn. Accelerate. Repeat as necessary.
2fast4you is offline   Reply With Quote
Old 04-11-2012, 12:47 AM   #30
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
No doubt but what will be the unintended side effects of a reflash like that? There must be some reason the engineers left that dip there.
Sport-Tech is offline   Reply With Quote
Old 04-11-2012, 12:57 AM   #31
csaba
Drives: scion tc
Like that red!
csaba is offline   Reply With Quote
The Following User Says Thank You to csaba For This Useful Post:
blur (04-11-2012)
Old 04-11-2012, 12:59 AM   #32
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by Snoopyalien24 View Post
How much ($$) would these come out to ?
$200~$850... depends on which tune shop.
IDK, we don't have any re-map ECU for FR-S, so can't answer that... BUT I can answer this. I have iSPEED's re-mapped ECU for my Impreza & no, I didn't lose anywhere in TQ line. Only side effect for me, is I have stage 2, so it require 91 or higher octane (which require to begin w anyways).
They left it there, so aftermarket shops can profit. Like reply on 2fast4you, we don't have remap ECU for FR-S, so we don't know. From my pass experience, it doesn't lose any tq curve ('00 Impreza), it helps smooth that dip. Not 100% fully fix it, but it's noticeable difference in dip.
Old 04-11-2012, 01:02 AM   #33
OrbitalEllipses
Drives: Attitude
Cost.
Old 04-11-2012, 01:03 AM   #34
ichitaka05
Site Moderator
ichitaka05's Avatar
Cost.
That may be true... but low cost as $200 isn't bad for fixing the dip in TQ line
Old 04-11-2012, 01:08 AM   #35
OrbitalEllipses
Drives: Attitude
Probably more. Open source tunes are about ~$400. Cobb AP are about $600 and only come with a base map, add $400 for a tune. Who's to say it's a tuning issue and not a cam or intake manifold issue? We'll see once people start putting these under the knife, but I have the niggling suspicion it's a design constraint.
Old 04-11-2012, 01:14 AM   #36
ichitaka05
Site Moderator
ichitaka05's Avatar
Only time will tell. I'm just pulling those numbers from re-mapped ECU for my Impreza.
Old 04-11-2012, 01:16 AM   #37
serialk11r
Drives: '06 AM V8V Coupe
Might be remap, but I'm starting to think that the intake/exhaust headers could be playing a much larger role than previously thought.
The car has an intake cam optimized for 6500ish rpm, yet it manages to pull off nearly the same torque at 3000ish. IMO, now the picture is coming together, the car SHOULD have really bad low end torque due to the cam, but the low rpm torque manages to match the high rpm torque.
Let's look at a car that has a very good intake system, the LFA. The 3 stage intake puts the peak torque close to the maximum possible at all rpm, and you'll notice that the peak torque is dropping consistently as the rpms go down. The volumetric efficiency here is limited by the intake cam.
That's what the FA20 should look like with a variable intake, albeit more flat because it has a smaller rpm range to work with. What we're seeing is low end torque matching top end torque. So I think what may be going on is that they realized the engine had no bottom end, and thus decided to compromise the top end with an intake optimized for VE in the 2000-3000rpm range. Hi Dimman, could this perhaps be the answer to your missing torque theory?
I wonder if anyone has intake runner lengths.
Old 04-11-2012, 01:18 AM   #38
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Cost.
It was free for my car. For a stock car you can find tuned maps on osecuroms.org and you just need to borrow someone's cable to flash it (or buy one for $99). Once you have mods you need a street tune which there are guys that will do it for $150 or you can learn to do it yourself. It will take time to crack the ecu though I'm sure.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 04-11-2012, 01:21 AM   #39
ichitaka05
Site Moderator
ichitaka05's Avatar
Yes, you're correction on intake & exhaust. It's all the Subie engine have problem with. I wrote "re-map ECU" instead of port & polish in & out & cams cause those cost a lot more than re-map ECU.
Cams: $300~$750
Port & polish Manifold: $250~$450
Port & polish in & out heads: $600~up
Plus labor & down time of car
vs re-map ECU: $200~up
Old 04-11-2012, 01:32 AM   #40
serialk11r
Well IMO the cams are looking pretty good right now, they're making power at high rpm, where they should be, I think to make use of bigger cams you'd need to raise the rev limit a bit. I'm super interested in seeing what different intakes will do though, as this is the first answer I've come up with to the "missing torque question" that makes complete sense, lol.
Old 04-11-2012, 01:46 AM   #41
ichitaka05
Site Moderator
ichitaka05's Avatar
bigger cams?
Old 04-11-2012, 01:54 AM   #42
Jordo!
Enjoy it, destroy it.
Jordo!'s Avatar
Drives: Datsun Racing Hen
Not a fan either but I doubt it will be that noticeable in most driving as all it does is slow the power curve upwards movement between 3200 - 4200 rpm. Now if that dip were in the HP curve itself it would be a disaster.
A sudden loss of 20 lb/ft of torque will be noticeable.
Nice to see what appear to be dynojet numbers.
Give it some boost, the car will be legendary.
Jordo! is offline   Reply With Quote
Cobb Tuning dyno pull Tainen BRZ First-Gen (2012+) — General Topics 87 08-01-2012 07:54 PM
insideline brz sti rendering DIG1992 BRZ Photos, Videos, Wallpapers, Gallery Forum 16 04-02-2012 06:05 PM
Any publication strap this car on a dyno yet? mspeed6 Engine, Exhaust, Transmission 67 02-02-2012 05:48 PM
2013 Scion FR-S: 10 Things You Don't Know (Maybe) - Insideline rmagic Scion FR-S / Toyota 86 GT86 General Forum 56 12-15-2011 06:36 PM
