Old 11-24-2013, 05:48 PM   #365
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
hit the p0351 code Automatic build date 3/12 19k miles. Going to the dealer in the morning. Will post again once I know more.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 11-27-2013, 08:54 PM   #366
feldy
feldy's Avatar
They replaced coil one under warranty. I was also had the supposed fix since the summer.
Old 03-18-2014, 02:41 PM   #367
Carwhisperer
Drives: A lot of supercars.
I blame my heat issues from choosing raven. Anyone else have asphalt or raven with the issues
Carwhisperer is offline   Reply With Quote
Old 05-21-2014, 10:18 AM   #368
bakerr6
Drives: 2013 raven black fr-s
I'm having this issue, I'm thinking about buying the tool and renting it out to people for the cost of shipping, if anyone is interested
bakerr6 is offline   Reply With Quote
Old 06-16-2014, 11:42 PM   #369
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by feldy View Post
Having the dealer pull the cylinder 1 injector and plug on my own dime. If there bad I'm making them fix it. Otherwise ill pay for the peace of mind. No codes. But little fire cracker sounds when crusing on the highway. Cant pinpoint it while I'm doing 75 down the highway. We will see what happens. On a automatic wondering if this maybe the first case. Currently on a 3000 mile road trip with 1800 out of the way so far.
how much did they charge?
Sent from my LG-D800 using Tapatalk
Astroboy is offline   Reply With Quote
Old 06-24-2014, 07:25 PM   #370
Margovincent_22x
Margovincent_22x's Avatar
Drives: Lightning Red BRZ MT Limited
I also have the exact problem.. so far i changed:
Spark Plug - Still piping in acceleration
Port Injector Seals - Replaced all seals and problem persist
BTW its normal to have 30 deg Celsius here where i live
next plans are to change coil packs and port injectors.
Margovincent_22x is offline   Reply With Quote
Old 10-03-2014, 01:22 AM   #371
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by trueno86power View Post
P0351 came back yesterday with a noticable POP sound. Car stored in the garage and I'll bring it to the dealer soon... I'll update the process.
What exactly did this pop sound like? I'm having a hard time hearing noises under my hood due to the avo turbo and straight pipes I installed... I mean I hear like these constant tapping noise that sounds like miniature bubbles of some sort..
Old 10-03-2014, 01:26 AM   #372
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by romin View Post
To recap:
My engine started popping in February.
I brought it to Subaru dealer #1 and they refused to look into the issue.
They said the noise was due to my mods.
I then brought it to Subaru dealer #2 with a video of my cold start popping sound, photos of other bad injectors, and even had the seals preorder so everything was ready to go. They also said there wasn't a problem and told me if I left the car there for a couple weeks maybe they would start it a few times and see if they could reproduce the sound. When I pushed the service adviser more he said it was likely due to my mods and probably wouldn't be covered under warranty. After one more follow up call that ended with the service advisor hanging up on me, I decided to fix the issue via a my own mechanic.
My mechanic pulled the engine apart and found exactly what we expected:
My cylinder #1 injector was so pitted that we couldn't even push a new seal on it using the "special tools". Every attempt resulted in a damaged seal. We ended up putting new seals on injectors #2, #3, and #4 but chose to completely replace injector #1.
From this we learned a few things:
These seals are very hard to replace without damaging them even when using the "special tools".
If you order a new injector they come with factory installed seals.
I therefore believe many of the technicians are damaging the new seals during warranty replacement which later results in another failure.
The "we're ordering you new special improved injectors" trick is just to avoid the manual seal replacement. They can just unwrap and plug them in.
I didn't see any difference in the seal on the ordered injector and the seals provided via Subaru parts.
You stated you showed your suabaru dealership a video? Where is this video?
The Following User Says Thank You to Astroboy For This Useful Post:
TofuJoe (06-22-2017)
Old 10-12-2014, 05:49 PM   #373
blown
Drives: ft86
did anyone reuse the single use parts?
blown is offline   Reply With Quote
Old 03-15-2015, 03:00 PM   #374
rvidxxr86
Drives: 2013 scion frs
Ok guys so new here,having similar issues popping noise rough start up rough idle and then stalls at red lights, I'm automatic and stock no tune nothing,any insight?
rvidxxr86 is offline   Reply With Quote
Old 03-15-2015, 03:01 PM   #375
rvidxxr86
It's also 20 degrees this winter average where I live l
Old 10-22-2018, 05:29 AM   #376
Gt86Force
Drives: GT86 Supercharged
Sorry to bring an old thread back...
I have the DI seals problem again...
First time happened 3 months ago, after insalling the supercharger. The second track day the seals failed.
I've replaced them and everything was ok untill this weekend :@
Same symptoms (popping noise)
Has anyone had the same problem twice?!?
I bought the car in 2015, i don't know the orginial firmware version but now the cal id is ZA1JF10G.
This happende 3 months after the supercharger install (but I thought that is a coincidence, maybe the old firmware version was not ok) and now again so it is clear that i have an unsolved issue.
The transient tables are ok.
The first time i've replaced only the seals, not the injectors. One was completely gone.
Now i will change all 4 injectors, but i don't want to spend 800$ every 2 track days....
Anyone found the possibile cause (beside wrong ecu firmware/map). What should i look for?
Gt86Force is offline   Reply With Quote
Old 12-11-2018, 09:52 AM   #377
ollepellijeff
Thule Dude
ollepellijeff's Avatar
Drives: Scion FR-S
P0304 Cylinder 4 misfire
Lost one 2013 stock engine to injector seal failures and oil starvation.
After costly crate engine replacement my second engine is acting up again.
Getting codes
P0354 Ignition coil D primary/secondary circuit
P0304 Cylinder 4 misfire detected
Diagnosed as shorted coil. Will have it replaced but suspect the underlying cause is bad injector seals again.
I track the car about once a month and try to avoid hot weather after my first engine failure but that evidently wasn't enough. The Toyota rail definitely doesn't seem to play well with this engine.
ollepellijeff is offline   Reply With Quote
Old 04-24-2020, 02:26 PM   #378
im.rocketeer
Drives: 2013 Toyota-86
Hi guys! im having some problems relating the injectors.
1.identifying the type of injector I have so that I can find some instructions on google. I have uploaded some pictures of my injectors.
2.I ordered few parts including the seal but im having some confusion in knowing where does the O-ring like part actually fits in my injectors
would be great help if anyone can help me with this..
Cheers guys!
im.rocketeer is offline   Reply With Quote
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 04:26 PM
Need Help - 2 codes thrown jpit Issues | Warranty | Recalls / TSB 3 04-20-2013 12:41 AM
Bulb codes JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 1 02-17-2013 03:25 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 05:03 PM
