Old 06-16-2014, 10:01 PM   #15
jonzhuxD
Drives: Ultramarine FR-S
Originally Posted by Chad86 View Post
Excellent idea, thanks. Need everything wrapped with no hole cutouts. Is the antenna as straight forward as is outlined? This is on a 2014.
Yeah I've removed my antenna before (Installed GT-R antenna), 3 clips, pull down the headliner, undo the bolt (I think it was a 27 mm nut) unclip and off it goes.
jonzhuxD is offline   Reply With Quote
The Following User Says Thank You to jonzhuxD For This Useful Post:
Chad86 (06-17-2014)
Old 06-17-2014, 01:20 AM   #16
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Thumbs up
Thanks! You need to pull the top 3 clips and the sides correct?
Nice looking antenna, that GT-R style.
Anyone know of a delete option? Possibly adding a colored cap to seal the roof. ie. White plug for Whiteout
Chad86 is offline   Reply With Quote
Old 06-17-2014, 01:16 PM   #17
jonzhuxD
I believe so, it's easier done than explained, once you see it, it should be fairly straightforward
Chad86 (06-17-2014)
Old 06-17-2014, 03:33 PM   #18
Chad86
Chad86's Avatar
Drives: Toyota GT86
With the antenna removed do I need to be concerned when the shop claybars and washes the roof? Should I have the hole temporarily plugged to prevent water getting in?
Old 06-17-2014, 09:24 PM   #19
jonzhuxD
With the antenna removed do I need to be concern ed when the shop claybars and waxes the roof? Should I have the hole temporarily plugged to prevent water getting in?
Put some painter's tape from the inside to temporarily plug up the hole, that should do unless they absolutely drench the roof.
Chad86 (06-18-2014)
Old 06-18-2014, 12:18 AM   #20
Chad86
Chad86's Avatar
Drives: Toyota GT86
Cool
Looks like I am getting closer to a solution. I will have to visit the local hardware store and check out the plumbing and screw section.
Flush, threaded hole plug and a sealant washer. Will have to get a Whiteout plug.
Link to the source of someone's wiper plug solution: http://www.motoringalliance.com/foru...-delete-2.html
I will do this tomorrow night and report back...My car is getting started on on Friday morning.
When my car is finished, then it's time!
The Following User Says Thank You to Chad86 For This Useful Post:
stevesnj (06-18-2014)
Old 06-18-2014, 08:06 AM   #21
jonzhuxD
The hole left by the antenna is not a perfect circle
Old 07-30-2014, 12:58 PM   #22
rtv
Drives: Toyota GT86
I guess that helps to avoid a rotating antenna socket. Do you have any pictures of the hole? I am thinking about replacing the stock antenna with a DAB one.
rtv is offline   Reply With Quote
Old 06-05-2015, 04:52 AM   #23
tzhu07
Thanks for the guide.
I had to do this not because I had to remove the antenna base, but because I had to adjust it due to it being slightly skewed clockwise.
tzhu07 is offline   Reply With Quote
The Following User Says Thank You to tzhu07 For This Useful Post:
Packofcrows (06-12-2015)
Old 06-12-2015, 01:43 AM   #24
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Instead of removing top black bezel? Cant you just buy a shark fin that goes over it? Just wondering.
Thanks for write up though, helped my buddy not force his off.
Old 06-12-2015, 12:50 PM   #25
kch
Senior Misanthrope
kch's Avatar
Yes, but you need to remove the antenna entirely if you're doing a roof wrap.
Old 09-18-2015, 08:56 PM   #26
nyrip
It's not rasp, just Rawr!
nyrip's Avatar
Drives: Something far too loud
any wires connected to the antenna i should be concerned about?
Texas registered- no cat, no muffler, no f*cks given!
nyrip is offline   Reply With Quote
Old 03-07-2016, 08:19 PM   #27
Ashikabi
Ashikabi's Avatar
Anyone have pics of the hole in the roof?
Old 07-06-2018, 05:51 PM   #28
spicetooth
Drives: 2014 FR-S
It's a 22mm, just use a socket and ratchet.
spicetooth is offline   Reply With Quote
How do you remove factory antenna? srt4_night_rider Cosmetic Modification (Interior/Exterior/Lighting) 7 08-10-2012 07:37 PM
Stock Antenna Photo schtebie Cosmetic Modification (Interior/Exterior/Lighting) 0 07-20-2012 07:17 PM
how do you remove odor from fabric? prest1ge Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 29 07-03-2012 08:45 AM
Anyone know how to remove headlights? Memphis Cosmetic Modification (Interior/Exterior/Lighting) 25 06-12-2012 07:31 PM
