Off-Topic Lounge [WARNING: NO POLITICS] For all off-topic discussion topics. |
06-16-2014, 11:59 AM | #57 | |
And thanks for the advice on honing. I planned on doing it about once a year, and stropping before and after shaves to keep everything sharp. Sound about right, or should I hone it more often? I think it's around $20-$40 local to me to hone. |
06-16-2014, 01:06 PM | #58 |
Off Topic
I'd only hone it if it's really necessary. As long as you strop it and avoid doing things to mess the edge up like dropping it in your sink, you should be able to go for quite a while without actually honing it. Once a year is fine for preventive maintenance.
Look up proper stropping technique. I would recommend getting a cheap strop to start, because you're going to nick it and cut it up a bit. You don't want to do that to a nice strop. Go for a 5/8 or 6/8 blade to start with. You may find that you want something larger and more solid, so you could step up to a 7/8 or 8/8 blade then. Stepping down to a 4/8 or 3/8 is more for fine areas, say if you wanted a specific mustache trimming razor or you planned to shave your junk with it. |
The Following User Says Thank You to gramicci101 For This Useful Post: | suaveflooder (06-16-2014) |
Similar Threads | ||||
Crazy Cart from Razor (Check it out!) | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 11-02-2013 12:57 AM |
Straight from the Shop! | Mishimoto | Announcements, Contests, Giveaways | 0 | 10-11-2013 04:58 PM |
Sirius XM - Straight Up | Jertronic | Electronics | Audio | NAV | Infotainment | 2 | 08-15-2013 11:31 AM |
BRZ to be AWD, straight from SOA (fail) | Laika | BRZ First-Gen (2012+) -- General Topics | 22 | 03-05-2012 10:09 AM |
