Old 06-13-2014, 10:22 PM   #99
celek
Resident Gear Head
celek's Avatar
Some low low mileage parts for the build.
Have to ship it all back out to some shops
celek is offline   Reply With Quote
Old 06-13-2014, 10:51 PM   #100
w00t692
Drives: 2008 Civic Si
Originally Posted by celek View Post
HP is not always the only reason
I plan on exceeding 9000 RPM
Have you tested the stock water pump to see where it cavitates? I guess i'm just used to honda water pumps, them bitches are fine for pretty much anything except the drag cars turning 10.5k lol
w00t692 is offline   Reply With Quote
Old 06-14-2014, 02:23 AM   #101
Fear
Drives: Ft86
Custom rods and custom pistons to retain a good rod to stroke ratio. (Which the HKS kit can not do and that's probably a $4500 kit
And how can you claim that a multimillion dollar corporation cant retain a good rod to stroke ratio to a stroker kit but you can?!? Are you machining the block?
Fear is offline   Reply With Quote
Old 06-14-2014, 09:20 AM   #102
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
since you have them in pieces it'd be great if you could bench flow the heads. ive been wanting to know how efficient these heads are. I gotta find out why we dont make much power with these engines
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 06-14-2014, 10:41 AM   #103
celek
Resident Gear Head
celek's Avatar
the HKS kit is designed to be dropped into a stock block. I am going to extreme limitations with 3.5mm overbore which will have more clearance
Old 06-14-2014, 12:36 PM   #104
Fear
Drives: Ft86
Want...
Old 06-16-2014, 08:47 AM   #105
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Originally Posted by Monogram View Post
You define 120hp per liter naturally aspirated as not making much power?
hm well the stock 100 hp per liter would be alright in a lighter car. But with all the technology in this motor, its should really be more impressive.
IG-Joey_Soul
Old 06-16-2014, 12:39 PM   #106
arghx7
Drives: car
Regarding the heads: you'd be hard pressed to find a DI engine with higher flowing heads than any Toyota D-4S engine. DI heads are going to be more restrictive than a PFI head, because mixture motion is created inside the cylinder. This isn't an S2000.
Small problem there trying to work a pump at slower speed/votlage against fluid is not going to work.
So all the BMW's out there with ECU controlled variable speed electric water pumps don't work?
The best way to gain power with an electric pump is to control the coolant temperature with the thermostat and set the coolant temperature and pressure delta across the engine by changing the pump flow rate. This is exactly how mass produced with OEM throttled pumps (electric or mechanical) do it.
Old 06-16-2014, 02:26 PM   #107
celek
Resident Gear Head
celek's Avatar
Sure when you are working with a BMW pump that costs a fortune specifically engineered into the car, they can do it. My particular case I can not drop below 9v or the pump will not turn the water I already had the schematic drawn up with a FET to change voltage based off the ECT input value. Problem is the table of data tolerance would be so tight with the coolant temp sensor operating range of (</= 1.0v) - (>/=2.0v) = 9v-12v output.
Basically scaling a 1 vt temp range change for a 3v difference in range output
Could be done maybe this is how BMW is doing it.
Old 06-17-2014, 01:00 AM   #108
Marco_86
Drives: 14' Frs Raven
lol you sound like a needy gf. surprised you don't expect the car to fly you to your destination
Marco_86 is offline   Reply With Quote
Old 06-17-2014, 01:17 AM   #109
AlphaMotorsports.ca
Drives: Rocket Bunny BRZ, Track FRS
Excited to see this build come to life. Sub'ing.
Will you be running a dry sump oiling system or do you plan on making modifications to the factory Oil pump to accommodate 10K+ rpm.
AlphaMotorsports.ca is offline   Reply With Quote
Old 06-17-2014, 09:27 AM   #110
Grip Ronin
The Mechanic
Grip Ronin's Avatar
im needy because id expect more from a advanced engine? oh shots fired lmao you sound like a dumb ass but lets not get that started
IG-Joey_Soul
Old 06-17-2014, 12:03 PM   #111
Marco_86
ouch
Old 06-24-2014, 06:50 AM   #112
BadBRZ
Drives: Subaru
And then we are where?!?
BadBRZ is offline   Reply With Quote
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
