| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#57 | |
Drives: '13 Raven FR-S
I had my HPFP replaced at a Scion dealer about 2k miles ago and up until about 2 weeks ago was cricket-free. When it started to re-appear the chirping wasn't as bad as with the factory pump before the replacement. I remembered MTS's post here and decided to give Blendzall "Power Booster"/Octane Booster a try which is reportedly 1/2 castor. I re-fueled with Shell 93 octane and mixed in the Blendzall @ 2 oz. per gallon. After the 5 mile drive home, no more crickets--and none at all until after my next re-fuel (using same Shell 93). Since the refuel the crickets are back--not any better or worse than before the Blendall. Last edited by longhornjoe; 06-09-2014 at 06:30 PM. Reason: quotes |
#58 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Currently on my third fill up with using 2oz per tank (~10 gallons) of Walmart's TCW3, ashless synthetic. On all 3 of my fillups I have the same experience as rice_classic; the crickets come occasionally but are barely audible, almost as if they are dying. I might try not using it on the next fillup and see if I can get away with every other fillup incase this stuff ends up being terrible for the engine.
Besides the crickets shutting up I have not noticed any other side effects in mpg or drive.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
#59 |
Drives: 2014 Scion FR-S
I'm on my third tank of 640:1 ratio of Walmart SuperTech TCW3 (that's 2oz per 10gal). For my purposes, I use a 2oz (~60cc) syringe and draw the oil out of a bottle and add a little bit every 2 gallons during the fillup (just to help it mix better).
The first time I added the oil I saw a pretty significant improvement - not necessarily in the cricket noise, but definitely in the butt-dyno and sound factor. When I added the TCW3 to the gas, it seemed like the engine really liked it. Valve/injector noise was reduced by a fair amount, and the high-RPM, what I call "racket", was reduced as well. It's still loud, don't get me wrong, it just sounds a lot healthier. However, the crickets have come back with a vengeance...it may be due to a number of factors (mileage, for one...since I just rolled over 3k). See here: http://www.ft86club.com/forums/showthread.php?t=67807 DO NOT...I repeat...DO NOT put the Synthetic/Semi-Synthetic 2-stroke oil in your car. Baaaaaad idea. There's no reason to do it, as it offers no additional benefit in our application, and it's more expensive. In addition, there's a good chance it could gum stuff up, since some of the oil does not burn completely away. It's a-whole-nother animal, and there's hardly any empirical data on it. |
#60 |
Drives: 2013 Argento FR-S
I've been using TCW3 for the past 8 months. I haven't had crickets since. I put in 50 ml at every fill up.
Sent from my XT912 using Tapatalk |
#61 |
Drives: 2014 Pearl BRZ Limited
Filled up with 93 from my local Super Test, 11 gallons on the dot, and added 60ml of SuperTech TCW3 for the first time. ~10mi in, and Im fairly certain I am beginning to notice the difference. It seems as though the engine has quieted down quite a bit, all throughout the rev range. The crickets are still present, however, even they seem to be less noticeable. Hopefully this stuff is as good as everyone is claiming. I know I'm gonna try it out for the next couple of tanks, and see how it goes. Might end up buying it in bulk, we'll see....
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully | | Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns | |
#62 | |
Drives: Skoda Yeti DSG diesel 4x4
You could go to 1:500 which would have been 100ml and that might be enough to finally shut them up. 8ml per [US]gallon is close enough. I just look at the trip and do a quick mental calculation before I fill up. My diesel ratio is 1:200 and I average about 6.2L/100km. If the trip is somewhere around 600km I know it will take less than 40L and chuck in 200mls, 750km = 250mls. You could do the same. Say 30mpg and 300miles on the trip = 10g so add 80ml. Then simplify it to 1/4 of the miles = 75ml |
#63 | |
Drives: 2008 Civic Si
#64 | |
Company results that boost sales should be viewed with scepticism because the motivation is money but in this case there is no financial motivation and it's been done for many years. |
#65 | |
This stuff seems almost too good to be true..
#66 | |
My crickets got louder but I think it's either A) the gas I put in it has more ethanol than usual and/or B) due to the increased mileage. I did just change the oil to ENEOS 0W-20 but I highly doubt that has anything to do with it, since it seems most people report changing the oil from the factory fill to something else made the crickets go away. |
#67 | |
#68 |
I want so bad to tell my other brz/frs friends about this(the ones who don't frequent this forum), but I just KNOW they will call me crazy. I put some in my 2012 Legacy today, and it exhibited the same results. It's magic..
#69 | |
It just got a bit convoluted but I thought, 'what the hell, you'll understand'. |
#70 | |
even more impressive. Much quieter, smoother, less or no smoke, more grunt and better mpg. Lots of reports of high oil consumption being reduced or stopped, theory is it cleans out the piston ring grooves and frees up the rings. On top of that it reduces emissions. I'm an addict! |
| Adding a Photoshop subforum! | srt4_night_rider | Site Announcements / Questions / Issues | 5 | 09-02-2012 10:48 PM |
| Adding a sub enclosure yet ? | rikdrt1 | Electronics | Audio | NAV | Infotainment | 10 | 06-08-2012 09:28 PM |
| Adding navi to FRS | Pake1 | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 06-04-2012 10:14 AM |
| Adding Navi to the FRS? | Pake1 | Electronics | Audio | NAV | Infotainment | 3 | 06-01-2012 01:26 PM |
| Consequences to Adding Regular Gas? | iff2mastamatt | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 12-06-2011 12:52 AM |
