Old 06-13-2014, 10:59 PM   #1
diss7
Drives: AE86, 2x GT86, TE27
Help me find a 15x8 in 5x100
I'm looking to run a 15x8 +10 for track days, mainly because my race car uses 15's and it means I can then also use them on the gt86.
Ideally, I want to be around 15x8 +10, but I don't want a lot of dish, as I need clearance for the brake caliper. So a 15x8 +25 will be a better idea, then running a 15mm spacer.
But its a nightmare to find anything in 15" that is 8" wide; and in 5x100.
I've thought about just getting the wheel in a 5x114.3 and seeing as Im certain I'll need to run a spacer, I could just run a conversion spacer. But ideally I'd rather the wheel was 5x100 as I already have 5x100 spacers.
diss7 is offline   Reply With Quote
Old 06-14-2014, 12:00 AM   #2
TheMuffinMan
Slowpoke
TheMuffinMan's Avatar
Drives: FR-S Whiteout MT
They make Rota slipstreams in that size and bolt pattern, but if you want that offset you'll have to run some spacers.
TheMuffinMan is offline   Reply With Quote
The Following User Says Thank You to TheMuffinMan For This Useful Post:
diss7 (06-14-2014)
Old 06-14-2014, 03:22 AM   #3
diss7
Excellent. Just found them.
Better order some regamaster stickers
Old 06-14-2014, 04:27 AM   #4
Panman
Panman's Avatar
Drives: 86 GTS
For Rotas? Really?
I'll get some Rota caps for my Desmond Regamasters.
Panman is offline   Reply With Quote
Old 06-14-2014, 04:40 AM   #5
diss7
Originally Posted by Panman View Post
For Rotas? Really?
It was a joke...
Old 06-14-2014, 05:11 AM   #6
Panman
Panman's Avatar
Drives: 86 GTS
I thought it was out of character, hence my question.
Old 06-19-2014, 12:27 AM   #7
AutoRnD
AutoRnD's Avatar
Drives: Fast ones
16x8 FD3S OEM Wheels are extremely light. 16x8 +50 5114.3. If you can find a 20mm adapter then you should have a good fitment. Then run 245/45/16, although that tire is very hard to find now.
We can probably source some custom drilled Team dynamics wheels for this purpose as well.
HMU if you need help sourcing something relatively affordable and reputable in build quality.
For example:
http://www.team-dynamics.com/wheeldetail.php?ProRace1.2
AutoRnD is offline   Reply With Quote
Old 06-19-2014, 01:59 AM   #8
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
http://www.watanabe.com.au/page1.html
fooddude is offline   Reply With Quote
WTB: 15x8 wheel 5x100 Turbo Den Want-To-Buy Requests 2 03-11-2014 08:55 PM
Where can I find this?... Juan_Ri Cosmetic Modification (Interior/Exterior/Lighting) 14 04-24-2013 10:16 AM
[GTA] Where can I find... drei CANADA 39 12-05-2012 04:37 AM
Need to find FR-S/BRZ Acidz CANADA 5 09-17-2012 12:45 AM
Want the BRZ but can't find one kduff85 BRZ First-Gen (2012+) — General Topics 9 07-10-2012 09:33 AM
