Old 04-29-2014, 09:55 AM   #323
Hima
Hello!
I install cusco final drive, and have a problem!
Error displaying the selected transmission.
1,2,3 transmission is confirmed true, but in the fourth display shows -1 transmission.на in fourth gear, he shows the third
shows the fourth to the fifth and so on.
Picking up speed over 80 miles per hour, starts operation indicator ESP.
Has anyone encountered a similar problem?
Hima is offline   Reply With Quote
Old 04-30-2014, 12:38 PM   #324
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Originally Posted by glorydays View Post
Are there any final gears that are taller?
You can order 3.91, 3.73 and 3.58 from Toyota.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 06-13-2014, 03:32 PM   #325
emirdtm
Drives: Toyobaru
Any video with the gear?
emirdtm is offline   Reply With Quote
Old 06-13-2014, 04:30 PM   #326
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Originally Posted by Hima View Post
Hello!
Hv u figured out the issue?? Can u pls update us, thx!
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 06-13-2014, 04:35 PM   #327
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
What are your revs in 6th at 100 mph?
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 06-13-2014, 04:44 PM   #328
mrk1
Drives: Sterling BRZ Ltd
cusco chart says 4500 rpm is 94.3mph and 5000 rpm is 104.7mph. In 6th.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 06-13-2014, 04:59 PM   #329
mabviper
Drives: WRB BRZ
I'm going to guess that this is due to the gear calculation. In most computers I've seen, gear number is a function of RPM, speed and/or wheel speed and gear ratios and final drive.
Was this problem for an automatic or a manual?
mabviper is offline   Reply With Quote
The Following User Says Thank You to mabviper For This Useful Post:
RehabJeff86 (06-13-2014)
Old 06-13-2014, 05:04 PM   #330
RehabJeff86
Good call, sounds like its an automatic problem, not sure, waiting for him to reply
Old 06-14-2014, 12:12 PM   #331
Top-Secret
Drives: FRS monogram
Originally Posted by 86drift View Post
I'm getting 5.1 gears and LSD from Cusco. I've been as high as 5.3 in a car before. It's the mod I'm most looking forward to. If I remember I'll try and do quarter mile times before and after.
did this ever happen? 5.1 would be pretty sick, out of what tho? cusco dont make a 5.1 for the car i think the highest i saw was a 4.7 but dont quote me
Top-Secret is offline   Reply With Quote
Old 06-17-2014, 12:57 AM   #332
jng
jng's Avatar
Drives: Toyota 86
Hello!
Am thinking of picking up the Auto Factory 4.875 for my AT 86. However my friend who had a MT one has the same "issue" with displaying the correct 4th - 6th gears.
Question:
1) Will the AT version have the same issue with either the 4.55 or 4.875 showing incorrect 4th - 6th gears due to changed gear ratios?
2) What is the "operation indicator ESP" problem mentioned?
jng is offline   Reply With Quote
Old 06-17-2014, 01:39 AM   #333
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Question:
1) Will the AT version have the same issue with either the 4.55 or 4.875 showing incorrect 4th - 6th gears due to changed gear rations?
I have an AT and maybe one of the first ones to do the cusco 4.55 FD install. I have been using it more than a year now, with several track days with no problems. It displays the correct gear on the indicator.
Tye300 is offline   Reply With Quote
The Following 4 Users Say Thank You to Tye300 For This Useful Post:
jng (06-17-2014), makesdrivingfunagain (08-10-2016), RehabJeff86 (06-17-2014), whataboutbob (06-18-2014)
Old 06-17-2014, 02:46 AM   #334
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
5.3 ftw!
http://www.weirperformance.com/finaldrivegears.html
fooddude is offline   Reply With Quote
Old 06-17-2014, 07:23 AM   #335
Top-Secret
Originally Posted by fooddude View Post
i see 5.13 for the old rolla... that wont swap in will it....
Old 06-17-2014, 02:13 PM   #336
fooddude
How much does a transmission shop/mechanic typically charge for installation of these FD gears btw, on average?
Any recommendations for tranny shops or mechanics with fd/gearbox experience in the OC area?
cusco final drive
PST Carbon Fiber Drive Shaft Installed msile Engine, Exhaust, Transmission 155 08-28-2018 07:53 PM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 02:21 AM
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 12:17 PM
Is my Cusco catch can correctly installed? wbradley Engine, Exhaust, Transmission 9 02-24-2014 09:49 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 06:54 PM
