Old 06-12-2014, 09:40 PM   #1
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
Air Oil Separator Teaser Pictures
Been working on a catch can set-up for these cars for the better part of this year and finally think we have a design and mounting more or less nailed down. Figured we would share some photos and see what you guys think about it.
Everything is in the prototype phase, so bare aluminum and welded brackets. Finished product will likely be all black anodized, the bracket will be bent aluminum and also anodized black, or that is the plan.
What separates this Air Oil Separator (AOS) from others is that it utilizes a filter media that is specifically designed to separate water and oil from air down to 5 microns! 5 microns is 0.00019". The filter media is still capable of flowing approximately 50 SCFM at 100 psi, so no restriction there. Basically these ensure that no oil will get from the crankcase to the intake manifold or the intake pipe.
These are photos of the first prototype in design phase and prototype billet pieces.
This is the second design. It features dual filters, a machined baffle, and will not need any welding. We came up with this design to ensure all oil and water get filtered out and to reduce overall costs of the can. Yes it is better and will be cheaper .
Current mounting is shown above. The little intake manifold cover can be used with both can placements and the bracket. The bracket will look a lot nicer and cleaner when finalized as well.
Thanks!
eric6 is offline   Reply With Quote
The Following 5 Users Say Thank You to eric6 For This Useful Post:
350zgoingFRS_lol (06-13-2014), FearBoy (06-13-2014), GT86_PRAGUE (09-24-2015), Malt (06-12-2014), sato (06-14-2014)
Old 06-12-2014, 09:50 PM   #2
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Looks good, got an ETA for those in the market?
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 06-12-2014, 10:34 PM   #3
gramicci101
Off Topic
How easy is it to access the drain port? What do you think about including something like a Fumoto drain valve with a nipple instead of just a drain plug? Might be easier and cleaner to drain it that way. Or make the threads the same as the oil pan drain plug, so people could make that change on their own.
Old 06-12-2014, 11:43 PM   #4
eric6
eric6's Avatar
Drain port is easy to access. It is a internal wrenching hex drain with an o-ring seal (-4 AN to be exact) and can be unscrewed with a 3/16 hex bit. We can look into utilizing a coolant drain petcock like this if that is what more people are interested in having. Our ETA is a month or two out.
Old 06-12-2014, 11:53 PM   #5
gramicci101
Off Topic
How easy is it to catch the oil as it comes out of the AOS? I was thinking that something you could connect a hose to might make it quicker and cleaner to drain. Just an idea.
http://i.imgur.com/l2rmhvh.jpg
Old 06-13-2014, 12:53 AM   #6
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
The filter media can it eventually get plugged / dirty and present any issues in this design? I like the fact of being able to see what's been collected vs just going back to crankcase and placement looks decent to.
Old 06-13-2014, 01:37 AM   #7
s2d4
s2d4's Avatar
Can the weld on fittings be replaced by non weld on ones?
Old 06-13-2014, 04:47 AM   #8
eric6
eric6's Avatar
Thanks for the idea. We will look into it or maybe have it as an option. We try to consider cost in everything we design and build as we are constantly striving to bring you guys the most potent products for the lowest price.
I assume that eventually the filter media could clog and go bad, but I have no way of telling when. It would have to be tens of thousands of miles. The AOS is fully rebuildable and easily disassembled/reassembled, so this could be checked every 30k if it is a concern.
I used a system with this same media device in it on my Evo IX for 20k, it worked flawlessly the entire time and the media never changed really. I was very happy to not be shoving the oil back into the intake manifold as well.
You will have to clarify your question as I don't exactly know what you're asking. The newest catch can that has been designed does not require any welding at all.
Old 06-13-2014, 05:40 AM   #9
s2d4
s2d4's Avatar
Apologies, I couldn't tell just by your prototypes then the drawings that indicates this since there doesn't appear to be any threads for the fittings to screw on to.
Old 06-13-2014, 06:17 AM   #10
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Drain petcock would be a plus for me.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
OICU812 (06-14-2014), unsurety (06-14-2014)
Old 06-13-2014, 07:34 AM   #11
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I'm surprised you didn't have a field day with that one.
Old 06-13-2014, 08:33 AM   #12
Captain Snooze
Drives: Red Herring
^^lol
yeah, I thought about it
Old 06-13-2014, 08:44 AM   #13
mid_life_crisis
Drives: FR-S 10 #103 AT
^^lol
His ambition in life was to be one for somebody from the first time he heard the term. Imagine his disappointment when he learned what it really meant.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 06-13-2014, 08:48 AM   #14
z3ro
$400.
I'm still not sure why these things are so expensive. It's literally about $30 worth of aluminum and fittings
z3ro is offline   Reply With Quote
Air/Oil Separator - ST legal? derek1ee Tracking / Autocross / HPDE / Drifting 2 04-08-2014 09:31 PM
Air Oil Separator? Do I need one? hmong337 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 21 12-31-2013 11:14 PM
Crawford Air / Oil Separator - 13+ BRZ/FRS/GT-86 ngabdala Engine, Exhaust, Bolt-Ons 11 06-10-2013 10:22 PM
Crawford Air Oil Separator JPxM0Dz Engine, Exhaust, Transmission 2 04-16-2013 10:33 PM
Crawford Air/Oil Separator Installed. Hippophobia Engine, Exhaust, Transmission 22 10-09-2012 01:01 AM
